97mm Mecanum Wheel kits
SKU 114090045
The Mecanum wheel is a special kind of wheel that can be moved in different ways by
controlling the direction and speed of the four wheels.
You can try to DIY a Mecanum wheel car and try to control him by programming. You can
see that he can move freely, whether it is a horizontal translation or straight walking, it can
be easily solved.
You can DIY your car by learning the contents of the wiki.
The Mecanum wheel is one design for a wheel which can move a vehicle in any direction. It
is a conventional wheel with a series of rollers attached to its circumference. These rollers
each have an axis of rotation at 45° to the plane of the wheel and at 45° to a line through
the center of the roller parallel to the axis of rotation of the wheel. There are two types of
Mecunum wheels, left-handed and right-handed Mecunum wheel; the difference between
them is the orientation of rollers. For left-handed Mecunum wheel, as shown below, rollers
are orientated from lower right to the upper left. Rollers for right-handed wheels are
installed in the opposite way.
The installation of the 4WD Mecanum Wheel kit should demand some carefulness. A
correct configuration requires each of four wheels is set in the way as shown below, where
the rotation axis of each wheel’s top roller points to the center of the platform.
Product picture is as follows:
Part List
2 x Left Mecanum Wheel Φ97mm (plastic)
2 x Right Mecanum Wheel Φ97mm (plastic)
4 x Brass coupling
1 x Screw pack
1 x Allen wrench
ECCN/HTS
ECCN
ERA99
HSCODE
9023009000
UPC
https://www.seeedstudio.com/97mm-Mecanum-Wheel-kits-p-4123.html/8-14-19
很抱歉,暂时无法提供与“114090045”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+384.622271000+49.99965
