114090050
114090050
    SEEED(矽递科技)
    直流电机 标准 210 RPM 3 ~ 7,2VDC
114090050 数据手册
      TT Motor Dual output shaft (1:48) SKU 114090050   The TT motor is mainly used in robots, DIY projects, it can convert electrical energy into rotational force, you can use Seeeduino to control it, but you also need a motor drive to control, because Seeeduino can not directly control high‐power devices. In this way you can easily control the motor, you can make a car or a fun rotating toy. Motor parameters: 48:1 Rated voltage DC(V) Rated current MA No‐load speed rpm/min Load speed rpm/min Torque kg.cm 3 160 120 100 0.45 6 220 200 175 1.0 7.2 250 250 210 1.5 Part List 1 x TT motor ECCN/HTS ECCN  ERA99  HSCODE  8501101000  UPC          https://www.seeedstudio.com/TT‐Motor‐Dual‐output‐shaft‐1‐48‐p‐4128.html/8‐14‐19
114090050 价格&库存
很抱歉,暂时无法提供与“114090050”相匹配的价格&库存,您可以联系我们找货
  • 1+11.339471+1.46694
