114990772
114990772
    SEEED(矽递科技)
    Module
    RF TXRX MODULE BLUETOOTH/WIFI
114990772 数据手册
ESP-32S Wifi Bluetooth Combo Module SKU 114990772 Xtensa® 32-bit LX6 Dua-core processor, up to 600 DMIPS 448 KByte ROM, 520 KByte SRAM SDK Firmware for on-line programming ESP32‐S Wifi Bluetooth Combo Module has no difference with ESP3212 Wifi Bluetooth Combo Module,  ESP3212 is replaced with ESP‐32S. ESP-32S Wifi Bluetooth combo module is ultra high performance and ultra low-power consumption Wi-Fi and Bluetooth combo wireless platform based on ESPRESSIF ESP32 chipset. ESP-32S integrates dual-core processor, 448 KByte ROM,520 KByte SRAM,16 KByte SRAM in RTC, 802.11 b/g/n/e/I Wi-Fi, Bluetooth v4.2 BR/EDR & BLE, clocks & Times, abundant peripheral Interfaces and sercurity mechanism. ESP-32S Wifi Bluetooth combo module provides SDK Firmware for fast on-line programming and open source toolchains based on GCC for development support. It is designed for Generic low power IoT sensor hub, loggers, video steaming for camera, Wi-Fi & Bluetooth enabled devices, Home automation and mesh network applications, aimed at makers, hardware engineers, software engineers and solution provides. ESP32 is a single chip 2.4 GHz Wi-Fi and Bluetooth combo chip designed with TSMC ultra low power 40 nm technology. It is designed and optimized for the best power performance, RF performance, robustness, versatility, features and reliability, for a wide variety of applications, and different power profiles. ESP32 is the most integrated solution for Wi-Fi + Bluetooth applications in the industry with less than 10 external components. ESP32 integrates the antenna switch, RF balun, power amplifier, low noise receive amplifier, filters, and power management modules. As such, the entire solution occupies minimal Printed Circuit Board (PCB) area. ESP32 is designed for mobile, wearable electronics, and Internet of Things (IoT) applications. It has many features of the state-of-the-art low power chips, including fine resolution clock gating, power modes, and dynamic power scaling. CPU and Memory: Xtensa® 32-bit LX6 Dua-core processor, up to 600 DMIPS. 448 KByte ROM 520 KByte SRAM 16 KByte SRAM in RTC. QSPI can connect up to 4* Flash/SRAM, each flash should be less than 16 Mbytes. Supply Voltage: 2.2V~3.6V 802.11 b/g/n/e/i 802.11 n (2.4 GHz), up to 150 Mbps 802.11 e: QoS for wireless multimedia technology. WMM-PS, UAPSD MPDU and A-MSDU aggregation Block ACK Fragmentation and defragmentation Automatic Beacon monitoring/scanning 802.11 i security features: pre-authentication and TSN Wi-Fi Protected Access (WPA)/WPA2/WPA2-Enterprise/Wi-Fi Protected Setup (WPS) Infrastructure BSS Station mode/SoftAP mode Wi-Fi Direct (P2P), P2P Discovery, P2P Group Owner mode and P2P Power Management UMA compliant and certified Antenna diversity and selection Compliant with Bluetooth v4.2 BR/EDR and BLE specification Class-1, class-2 and class-3 transmitter without external power amplifier Enhanced power control +10 dBm transmitting power NZIF receiver with -98 dBm sensitivity Adaptive Frequency Hopping (AFH) Standard HCI based on SDIO/SPI/UART ? High speed UART HCI, up to 4 Mbps BT 4.2 controller and host stack Service Discover Protocol (SDP) General Access Profile (GAP) Security Manage Protocol (SMP) Bluetooth Low Energy (BLE) ATT/GATT HID All GATT-based profile supported SPP-Like GATT-based profile BLE Beacon A2DP/AVRCP/SPP, HSP/HFP, RFCOMM CVSD and SBC for audio codec Bluetooth Piconet and Scatternet Internal 8 MHz oscillator with calibration Internal RC oscillator with calibration External 2 MHz to 40 MHz crystal oscillator External 32 kHz crystal oscillator for RTC with calibration Two timer groups, including 2 x 64-bit timers and 1 x main watchdog in each group RTC watchdog 12-bit SAR ADC up to 18 channels 2 × 8-bit D/A converters 10 × touch sensors Temperature sensor 4 × SPI, 2 × I2S, 2 × I2C, 3 × UART 1 host (SD/eMMC/SDIO), 1 slave (SDIO/SPI) Ethernet MAC interface with dedicated DMA and IEEE 1588 suppor CAN 2.0 IR (TX/RX) Motor PWM, LED PWM up to 16 channels Hall sensor Ultra low power analog pre-amplifier IEEE 802.11 standard security features all supported, including WFA, WPA/WPA2 and WAPI Secure boot Flash encryption 1024-bit OTP, up to 768-bit for customers Cryptographic hardware acceleration: -AES-HASH(SHA-2) library-RSA-ECC-Random Number Generator (RNG) SDK Firmware for fast on-line programming Open source toolchains based on GCC Generic low power IoT sensor hub Generic low power IoT loggers Video streaming from camera Over The Top (OTT) devices Music players - Internet music players - Audio streaming devices Wi-Fi enabled toys - Loggers - Proximity sensing toys Wi-Fi enabled speech recognition devices Audio headsets Smart power plugs Home automation Mesh network The size of ESP-32S Wifi module is 18mm x 25mm x 3mm. The ESP-32S deploys 4MB SPI Flash with WSOP-8 package. It also uses 3DBi PCB antenna on board. PART LIST • 1x ESP-32S Wifi Bluetooth Combo Module Copyright © 2008-2016 Seeed Development Limited All rights reserved
114990772 价格&库存
很抱歉,暂时无法提供与“114990772”相匹配的价格&库存,您可以联系我们找货
