114991131
114991131
    SEEED(矽递科技)
    RF EXPLORER UPCONVERTER
114991131 数据手册
      RF Explorer Upconverter  SKU 114991131            Description  RF  Explorer  Upconverter  is  a  high  performance  RF  frequency  mixer  to  enable  input  frequency  ranges  from 100KHz to 250MHz in RF Explorer Spectrum Analyzer and other devices such as SDR and wideband  radios.        RF Explorer Upconverter is a multi‐purpose device:  * Includes an Upconverter Mixer to enable frequencies 100Khz ‐ 250MHz in your  RF Explorer Spectrum Analyzer or other devices such as RTL‐SDR and converts into 530.1‐780MHz  *  Internal  selectable  Low  Noise  Amplifier  of  25dB  gain  nominal,  to  increase  sensitivity  of  receivers,  Spectrum Analyzers, Oscilloscopes and Near Field antennas in frequencies 100KHz ‐ 4GHz  * Internal selectable Attenuator 30dB nominal to enable large signal measurement    Features  • Internal LNA amplifier and selectable attenuator  •In Mixer mode convert frequencies from input 100KHz‐250MHz up to 530.1‐780MHz output  •In Bypass mode it can work in frequencies from 50KHz to 4GHz including LNA and Attenuator  •Compact size and light weight  •Solid aluminum metal case  •Mini USB port is used for powering the unit DC 5V, easy connection to a PC, wall wart or even portable  power bank battery.  •Easy connection to RF Explorer with included RF adapter SNA Male‐Male  •Ideal device to amplify weak signals using RF Explorer Near Field antennas        Technical Details    Dimensions  120mm x 77mm x 26mm  Weight  G.W 95g      Battery  Exclude  Input Frequency band Mixer Mode   0.1 – 250MHz  Input Frequency band: Bypass Mode   0 – 4GHz  LNA Frequency band  0 – 4GHz  Attenuator Frequency band  0 – 4GHz  Internal selectable LNA   25dB gain  Internal selectable Attenuator  30dB  Connectors  Standard SMA 50 ohms RF connectors  Absolute Max input power Bypass and Attenuator mode  +30dBm  Absolute Max input power LNA mode  +5dBm  Mixer stability and accuracy (typical)  +‐10ppm          Part List    RF Explorer Upconverter  1  SMA Male‐Male adapter  1        https://www.seeedstudio.com/RF‐Explorer‐Upconverter‐p‐2991.html 11‐3‐17
114991131 价格&库存
很抱歉,暂时无法提供与“114991131”相匹配的价格&库存,您可以联系我们找货
