114991175
114991175
    SEEED(矽递科技)
    液体 PMIC - 栅极驱动器 1 ~ 30 LPM 铜
114991175 数据手册
  Water Flow Sensor YF-B5 SKU 114991175 Description Water flow sensor consists of a copper body, a water rotor, and a hall-effect sensor. When water flows through the rotor, rotor rolls. Its speed changes with different rate of flow. The hall-effect sensor outputs the corresponding pulse signal. This one is suitable to detect flow in water dispenser or coffee machine. Life is longer than plastic body. Features •Compact, Easy to Install •High Sealing Performance •High Quality Hall Effect Sensor •RoHS Compliant Specifications •Mini. Wokring Voltage: DC 4.5V •Max. Working Current: 15mA (DC 5V) •Working Voltage: DC 5V~15V •Flow Rate Range: 1~30L/min •Frequency: F=6.6*Q(Q=L/MIN) •Load Capacity: ≤10mA (DC 5V) •Operating Temperature: ≤80Ԩ •Liquid Temperature: ≤120Ԩ •Operating Humidity: 35%~90%RH •Water Pressure: ≤1.75MPa •Storage Temperature: -25~+ 80Ԩ •Storage Humidity: 25%~95%RH Part List 1 x YF-B5 water flow sensor Technical Details Weight G.W 131g Battery Exclude https://www.seeedstudio.com/Water-Flow-Sensor-YF-B5-p-2882.html 6‐26‐17
114991175 价格&库存
很抱歉,暂时无法提供与“114991175”相匹配的价格&库存,您可以联系我们找货
