114991177
114991177
    SEEED(矽递科技)
    液体 PMIC - 栅极驱动器 1 ~ 25 LPM 铜
114991177 数据手册
Water Flow Sensor YF-B7 SKU 114991177 Water flow sensor consists of a copper body, a water rotor, and a hall-effect sensor. When water flows through the rotor, rotor rolls. Its speed changes with different rate of flow. The hall-effect sensor outputs the corresponding pulse signal. This one is suitable to detect flow in water dispenser or coffee machine. Life is longer than plastic body. Features • Compact, Easy to Install • High Sealing Performance • High Quality Hall Effect Sensor • RoHS Compliant Part List YF-B7 water flow sensor 1 ECCN/HTS HSCODE 9026100000 USHSCODE 90261060 Technical details Dimensions 0mm x0mm x0mm Weight G.W 134g Battery Exclude Mini. Wokring Voltage DC 4.5V Max. Working Current 15mA (DC 5V) Working Voltage DC 5V~15V Flow Rate Range 1~25L/min Frequency F=(11*Q)Q=L/MIN±3% Load Capacity ≤10mA (DC 5V) Operating Temperature 0 ~ 80℃ Liquid Temperature ≤120℃ Operating Humidity 35%~90%RH Water Pressure ≤1.75MPa Storage Temperature -25~+ 80℃ Storage Humidity 25%~95%RH Interface Dimensions G1/2Inch Error Range (1~30L\MIN) ±3% Material Description H57Copper+POM Output Pulse High Level >DC 4.7V (Input Voltage DC5V) Output Pulse Low Level
114991177 价格&库存
很抱歉,暂时无法提供与“114991177”相匹配的价格&库存,您可以联系我们找货
