114991371
114991371
    SEEED(矽递科技)
    散热片 Raspberry Pi 2,3,B+ 铝 插件板级
114991371 数据手册
    Raspberry Pi Ultimate Cooling Dual Fan   SKU 114991371    Description    Is your RaspberryPi overheating? Whether it’s in a hot environment or your RPi is crunching non‐stop we  have a solution – the Raspberry Pi Ultimate Cooling Dual Fan!  This heatsink is high‐speed yet low noise and includes a heat sink. 3M thermal tape is included to help  ensure  efficient  and  swift  cooling  of  the  processor.  We  tested  this  heatsink  on  the  Raspberry  Pi  ourselves,  and  it  passed  our  test!  It’s  ideal  for  your  Raspberry  Pi  3  Model  B  as  it  was  designed  to  be  compatible with the most popular cases. We know this will bring you a fantastic user experience!  Note: Please put the heat sink (with adhesive paper) to in the position shown above. Be sure to leave  room for the GPIO, and keep the heat sink away from the capacitor.  How to use it:            GPIO Connection:    Features  •Easy to install  •Fast Heat dissipation  •Silence Fan without noise  •Smooth and straight aluminum material  •3M tape makes install easier      Technical Details  Dimensions  56mm x 25mm x 15mm  Weight  G.W 40.5g      Battery  Exclude  Test Report  Test Environment Temperature  26.8°C  Hardware Environment  Raspberry Pi 3 Model B  TF card  8GB Class 10   Software Environment  Raspbian(OS)  Testing Softwares  Vcgencmd measure_temp ,sysbench  Testing Hardware’s Freq  1200MHz  Testing Time  10 minutes  Result  Without Heatsink  83.5°C  With heatsink  77°C  Dual Fans with heatsink  62°C  Part List  Ultimate Cooling Fan Kit  1  3M tape  1  Instruction  1        https://www.seeedstudio.com/Raspberry‐Pi‐Ultimate‐Cooling‐Dual‐Fan‐p‐2926.html 9‐7‐17
114991371 价格&库存
很抱歉,暂时无法提供与“114991371”相匹配的价格&库存,您可以联系我们找货
