114991549
114991549
    SEEED(矽递科技)
    CRAZYFLIE FLOW V2 DECK TOF
114991549 数据手册
    Crazyflie-Flow v2 deck SKU 114991549       The Flow deck gives the Crazyflie 2.X the ability to detect its motions in any direction. The VL53L1x ToF sensor measures the distance to the ground with high precision and the PMW3901 optical flow sensor measures movements of the ground. This creates a flying 3D robot that can be pre‐programmed to fly distances in any direction or act as an aid for beginners as it creates a very stable flying platform. Features Fast, accurate distance ranging Measures absolute range up to 4m Eye‐safe Measures horizontal movement Creates a 3D robot that can be pre‐programmed Aided flight    Specifications VL53L1x ToF sensor to measure distance up to 4 meters within a few millimeters (depending on surface and light conditions) 1‐wire memory for automatic expansion deck detection PMW3901 optical flow sensor (works best on matt surfaces Mechanical specifications    Weight: 1.6g Size (WxHxD): 21x28x4mm Designed for mounting under the Crazyflie 2.X Compatibility: See Conpatibilitity Matrix Part List: 1 x Flow v2 Deck ECCN/HTS ECCN  EAR99  HSCODE  9031900090 USHSCODE  9027904500 UPC                                    https://www.seeedstudio.com/Crazyflie‐Flow‐v2‐deck‐p‐2936.html/4‐24‐19
114991549 价格&库存
很抱歉,暂时无法提供与“114991549”相匹配的价格&库存,您可以联系我们找货
