114991588
114991588
    SEEED(矽递科技)
    ARMOR CASE FOR RASPBERRY PI 3 MO
114991588 数据手册
      Armor Case for Raspberry Pi 3 Model B+ SKU 114991588 Description As we know, Knights of old had to wear armor in battle! Do you know about that the Raspberry Pi can have an Armor too! Here it is! This armor case is designed to arm your raspberry Pi and let it have a cool combat armor. In fact, it is a very cool radiator shell, with a super quiet dual fan, an aluminum shell, carefully carved by CNC. Can be very effective to protect your raspberry Pi and the biggest feature is to reduce the temperature of the raspberry Pi. Features:       Dual Fan Ultimate Cooling Aluminum Alloy CNC Machining Easy To Mount Super quiet We also provide Raspberry pi 3 B version, you can check here. Assembly drawing Technical Details Dimensions 100mm x 65mm x 35mm  Weight  G.W 135g      Battery  Exclude  Part List Armor case with dual fan 1  screw  4  thermal tape  3  Instructions  1  ECCN/HTS ECCN EAR99  HSCODE  8414599060  Documents  Mechanical Drawing https://github.com/SeeedDocument/forum_doc/raw/master/reg/Dimension.pdf                                     https://www.seeedstudio.com/Armor%20Case%20for%20Raspberry%20Pi%203%20Model%20B+‐p‐3120.html 9‐7‐18
114991588 价格&库存
很抱歉,暂时无法提供与“114991588”相匹配的价格&库存,您可以联系我们找货
