114991685
114991685
    SEEED(矽递科技)
    REFLOW OVEN 3 HEATING ZONES
114991685 数据手册
      Desktop 3 Heating Zones Reflow Oven  SKU 114991685        Product Feature:  Adopt the latest streamlined design, the appearance of the whole machine is integration, the  upper, middle and lower can be arbitrarily disassembled and assembled to facilitate customers  upstairs and downstairs, all configuration interface using plug‐in type, to facilitate  future maintenance.  Built‐in rotating flywheel, free to transfer. Without trouble by power outages, making the  temperature of the heating zone fully radiating, the thermal expansion coefficient of  the stainless steel mesh belt are same, effectively extend the service life of the equipment.  Alarm protection function, independent temperature zone protection device. When the  temperature is ultra‐high or ultra‐low, the alarm signal light would send the  information to the intelligent temperature controller, let it do automatically temperature self‐ preparation.  The biggest feature of this machine is power saving. Adopting imported intelligent temperature  controller and unique PID digital fuzzy control function, can make the machine reach the setting  temperature (accuracy within 1 Ԩ), when the real‐time temperature reaches the setting  temperature, the temperature control can enter the power saving mode, which greatly save  production costs.           Heating Element: Vacuum Super‐long Life Ni‐Cr Heater.  Heating Method: Turbocharged full hot air temperature zone independent cycle forced heating,  heating quickly, saving energy.  Control Mode: The operation panel button + microcomputer intelligent meter PID closed‐loop  control / touch screen control.  Touch screen control type with a set of temperature recording function, can test the panel  actual temperature.  The touch screen can store 8 set of different types of temperature curves for choice and usage.    Technical Details  Dimensions 1500mm x 610mm x 670mm  Weight  G.W 120000g      Battery  Exclude  Heating Zone    Heating Length  Upper 3 Zones/ Down 0 Zone  Heating Element  1000mm  Heating Method  Vacuum Super‐long Life Ni‐Cr Heater  Control Mode  Full Forced Hot Air Heating  Control Mode  Operation Panel Button + Intelligent micro computer  meter PID Close Loop Control  Warm‐up time  20min  Cooling Zone Quantity  2 Air Cooling Zones (Plasma DC fan)    Cooling Method  Transverse Flow Forced Air Cooling  Temp. control precision  ±2Ԩ  Temp. deviation on PCB  ±2Ԩ  PCB Max. Width  Mesh belt width 300mm  Component Permitted Height  30mm  Transmission Direction  Left→right (right→le  op onal)  Transmission Net Height  300±20mm  Transmission Method  Stainless steel mesh belt  Conveyor Speed  0‐1500mm/min  Abnormal Alarm  Extra‐high / extra‐ low temperature alarm  Power Supply  AC220V 50Hz  Staring/Normal Power  5KW/1.5KW  Part List  Desktop 3 Heating Zones Reflow Oven 1  ECCN/HTS  ECCN Not Available                      https://www.seeedstudio.com/Desktop%203%20Heating%20Zones%20Reflow%20Oven‐p‐3208.html 12‐4‐18
114991685 价格&库存
很抱歉,暂时无法提供与“114991685”相匹配的价格&库存,您可以联系我们找货
