114991686
114991686
    SEEED(矽递科技)
    DESKTOP 2 HEADS PICK AND PLACE
114991686 数据手册
        Desktop 2 Heads Automatic SMT P&P Machine  SKU 114991686    Product Feature:          Desktop 2 Heads Automatic SMT P&P Machine is the classic of desktop dual‐head SMT pick and  placement machine. High precision, more reasonable mechanical design, easy operation, stable  running, adapting air‐operated feeder, automatic vision system, automatic detection materials  shortage. Suitable for mounting most of the SMD components, such as 0402 0603 0805 1206  1210 3528 5050 SOP QFN, etc.  Drawer type computer and driver integrated, could pull out lightly, convenient for later  maintenance.  Disassembled chassis, easy to handling.  HD industrial camera, precisely identify 0402, 15*15mm and other electronic chips.  Intelligent remounting design, when pick materials failed, software will instruct to continue  mounting no‐stop, record  and unify remounting. It could improve the mounting efficiety.  Component auxiliary box design, make components programming and position revising more  precisely.  Software is easy to understand and use, free upgrade permanently.        Technical Details    Dimensions 1045mm x 850mm x 650mm  Weight  G.W 168000g      Battery  Exclude  Max. Circuit Board Area  295x420mm  XY Max. Movement Range  530x550mm  Z Axis Max. Movement Range  20mm  Max. Mounting Speed  6000 cph  Avarage Mounting Speed  5000 cph  Positioning Accuracy  0.01mm  Nozzle Buffering Range  8mm  Power Supply  AC220V,50Hz  Compressed Air  0.5~0.7Mpa  Avarage Power  300W  Support Feeding Method  Tape feeder,tube feeding,tray IC      Applicable Components  0402, 0603, 0805, 1206, 3528/ 5050/ 3014, diodes,  transistors,QFN/SOP/SOT/BGA/ Chip 100 pin or  15mm*15mm  Feeder No.  25  Moter  Stepper Moter  Mounting Head  2 Heads  Motion Driving System  High speed digital high pressure driver  Component Angle  0~360°,synchronized rotation in motion  Programming Mode  Point‐to‐point programming,visual  programming,etc.  Vision Operating Mode  Built‐in PC,automatically recognize,correct and  remount  X/Y Running Mode  A new generation of linear interpolation linkage  Air Source  Reversal positive and negative pressure switch  Visual Programming Camera  Ultra high pixel color infrared  Visual Display  15'' Color HD display      Part List  2 Heads Automatic SMT P&P Machine 1  PC  1  Tools bag  1  ECCN/HTS  ECCN Not Available                                        https://www.seeedstudio.com/Desktop%202%20Heads%20Automatic%20SMT%20P&P%20Machine‐p‐3209.html/12‐4‐18
114991686 价格&库存
很抱歉,暂时无法提供与“114991686”相匹配的价格&库存,您可以联系我们找货
