ICE Tower CPU Cooling Fan for Raspberry Pi (Support Pi 4)
SKU 114991948
Tower structure, 5mm copper tube, multi‐layer heat sinks, 7 blades powerful fan, all the above combinations
make this super radiator for Raspberry Pi 4 and 3. In the case of overclocking, it can reduce the temperature
of the Raspberry Pi from 80 to 40
Meet this super ICE Tower CPU Cooling Fan for Raspberry Pi! Tower structure, 5mm
copper tube, multi‐layer heat sinks, 7 blades powerful fan, all the above combinations make
this super radiator for Raspberry Pi. In the case of overclocking, it can reduce the
temperature of the Raspberry Pi from 80 to 40 . What amazing! Best of all, this cooling
fan supports the new Raspberry Pi 4 Model B. In our actual use, we found that Raspberry Pi
4 has a large amount of heat. with the help of this super fan, the powerful performance of
the Raspberry Pi 4 will be fully released.
This super fan is designed by 52Pi, 52Pi is a world's leading Raspberry Pi accessories
manufacturer, specializing in the design and production of various hats, screens, and
accessories for the Raspberry Pi.
Mounting Guide and Evaluation
https://youtu.be/l5IFD2wq_gA
Special thanks for ETA PRIME to share this video with us.
Attention
In the heat dissipation test mentioned above, the temperature was lowered from 80 ° C to 40 ° C. The
test conditions are as follows: 1‐Room temperature 25 ° C / 2‐ Apply silicone grease directly to the heat
sink and processor chip / 3‐ Raspberry Pi 4 processor overclocking
The final cooling effect may vary depending on the test conditions. Due to shipping restrictions, we
did not equip the accessories with silicone grease. If you use the cooling sticker(thermal paste) in
the accessory, you can reduce the temperature from 80 ° C to 48 ° C under the same conditions. It
can be seen that the use of silicone grease is better. If you want to achieve the best heat dissipation,
we recommend that you purchase silicone grease yourself.
Tip
This product does not include the Raspberry Pi, the product image is only for the effect display, if you
need the Raspberry Pi, please click here to buy.
Features
Support Raspberry Pi 4 Model B/ Raspberry Pi 3 Model B /Raspberry Pi 3 Model B+
DC 5V Power in (Can be powered by the Raspberry Pi)
Ice Tower Structure
5mm copper tube
Super heat dissipation
Rated power 0.4W @5V, 0.08A
Part List
Brackets * 3
Ice tower CPU fan *1
M2.5x6 copper columns *4
M2x4 screws *2
M2.5x4 screws *4
Nuts *4
Cooling sticker(thermal paste) *3
Screwdriver *1
Dimensions
ECCN/HTS
ECCN
ERA99
HSCODE
8414599060
UPC
https://www.seeedstudio.com/ICE‐Tower‐CPU‐Cooling‐Fan‐for‐Raspberry‐pi‐Support‐Pi‐4‐p‐4097.html/7‐17‐19
很抱歉,暂时无法提供与“114991948”相匹配的价格&库存,您可以联系我们找货
