114992052
114992052
    SEEED(矽递科技)
    ALUMINUM CASE FOR NVIDIA JETSON
114992052 数据手册
    Aluminum Case for Nvidia Jetson Nano SKU 114992052    This is an all‐metal functional enclosure specifically tailored for Jetson Nano. Its honeycomb vents reduce the heat generated by your device while it’s performing neural network training or running machine vision programs. And the internal super quiet fan will be good auxiliary heat dissipation, beautiful workmanship of the outer casing, perfect interface opening for each connector. In addition, in order to consider the equipment that Jetson Nano may use, such as the camera, it especially provides the camera holder for Jetson Nano. The metal bracket makes your visual neural network learning device more convenient to use. At the same time, it provides two perfect wireless network expansion antenna interfaces for the Jetson Nano on the outer casing, so that you can avoid Metal shielding interference when it accessing the network via extending network interface card, such as intel network card. A switch button with backlight is provided on the front of the panel. In order to prevent mistakenly touching, a reset button is provided on the back of the panel. Four anti‐skid rubber pads are added to the bottom of the case to prevent a skid. Note The camera is not included. If you need, you can click here to purchase   Features        Easy to assemble Camera holder Extended Antenna Base for the network interface card Honeycomb vents style Super quiet fan Good quality Anti‐skid rubber pads Assembly guide Part List 1 x Metal case with pre‐installed 4010 fan 1 x 4020 5V 4‐wire speed regulating fan 1 x Reset button with stripline 1 x 5V Blue Backlight metal switch with a trip line 1 x Antistatic tweezers 4 x Rolled strip 4 x M2.5*5 semicircular head screw 4 x M2.5*20 Screw 4 x M2.5 Nut 3 x Jumper cap 1 x Camera Bracket 4 x M2 screws (for the camera) 4 x Acrylic washer (for the camera) 1 x Screwdriver 1 x Instructions ECCN/HTS ECCN  ERA99  HSCODE  8414599060  UPC        https://www.seeedstudio.com/Aluminum‐Case‐for‐Nvidia‐Jetson‐Nano‐p‐4218.html/9‐16‐19
114992052 价格&库存
很抱歉,暂时无法提供与“114992052”相匹配的价格&库存,您可以联系我们找货
