114992055
114992055
    SEEED(矽递科技)
    箱 丙烯酸 黑色,灰色 手持,分叉式双侧 X
114992055 数据手册
      Argon ONE Raspberry Pi 4 Case SKU 114992055   This is a new case for Raspberry Pi 4B,the base of the case is plastic and the upper shell is aluminum alloy. It  can protect and dissipate heat. Designed by Argon40.    Sleek Aluminum Enclosure Made with aluminum alloy and polished with a modern Space Grey finish for stunning aesthetics and functionality. Passive and Active Cooling The whole case top acts as passive cooling for the Raspberry Pi. And a software controllable fan is added inside the case for better temperature management. Easy Assembly & Neat Cable Management Assembling the case with the Raspberry Pi is easy. Installing the Argon ONE Script that unlocks the full functionality of the Argon ONE in one line. All of the ports are accessed at the back, making the mini‐computer manageable with minimal cable clutter and easy cleaning. Proper System Shutdown A proper power button is installed on the case to prevent file damage. It safely Shutdowns, Reboots, and Forced Shutdowns functions are built in features. Magnetic Removable Top & Access to GPIO The PCB Board built into the case provides separate power sources to the fan and power switch, as well as extending the GPIO pins to use the case in multiple projects. Clean, Stylized Design The Argon One Case is the ergonomic and aesthetic case for people to get into computers and electronics. Made with aluminum alloy and polished with a gray finish, the case makes mini computers look modern, sleek, and stylish, easily attracting anyone into computers. Its minimalist design keeps cables in one area and offers great cooling with properly placed vents. Ultimately, the Argon One Case combines functionality and futuristic aesthetics all in one package. Amazing Cooling The aluminum alloy case doesn’t just make the computer look cool, but it also cools the computer too. The case has an extension that connects to the processor with a thermal cooling pad so that heat from the processor is transferred to the case. This means that the case becomes a heatsink passively cooling the motherboard so that the computer can work without building up much heat. To top it off, the case comes with a built‐in PCB board with a fan attached to actively cool the computer further. These two cooling systems combined guarantee long‐lasting use without overheating. The fan speed can be configured anytime via the terminal, as well as the conditions for changing the fan speed passively. Minimal Clutter All the ports of the Raspberry Pi are accessed at the back to ensure that Cable clutter is at a minimum. This also makes the computer easy to tidy and pack up when on the move without compromising any ports of the motherboard. Easy to Assemble The case comes with a top and bottom, 4 screws, a built‐in PCB Board, a silicon cooling pad, and a PCB Board that extends the audio and micro HDMI ports. Assembling the raspberry pi with the case though is as easy as 1, 2, 3 or A, B, C. Combining the parts together is simple and intuitive. All that’s needed is a four‐way screwdriver, and that’s just to tighten the screws to the bottom of the case. No special tools needed at all. After assembling the computer and installing the OS on the SD Card, a one‐line script needs to be typed into the terminal so that the power button and fan can be used. Accessible GPIO pins The case was designed with one main purpose, protecting the Raspberry Pi without compromising the full functionality of the motherboard. The built‐in PCB board extends the GPIO pins of the Raspberry Pi. When the pins aren’t in use, they’re covered and protected by a magnetic removable top. This makes the Pins accessible at all times, allowing the computer to be used in various electronics projects. Safe Power Button The case comes with a simple power button to turn the computer on and off while ensuring that the files stored are safe. When the one‐line script is installed, the power button has multiple functions depending on how the button is pressed. Features        Aluminum Alloy Top Clean Power Shutdown Active and Passive Cooling Controllable Fan Speed Neat Cable Management Easy Installation Access to GPIO Pins Compatibility:  Raspberry Pi 4 Part List: 1 x Argon ONE Pi 4 Case 1 x Instruction Manual 1 x HDMI ‐ Audio PCB Extender 1 x GPIO ‐ Fan PCB HAT 1 x Silicon Thermal Pads ECCN/HTS HSCODE  UPC  3926909090                  https://www.seeedstudio.com/Argon‐ONE‐Raspberry‐Pi‐4‐Case‐p‐4250.html/10‐3‐19
114992055 价格&库存
很抱歉,暂时无法提供与“114992055”相匹配的价格&库存,您可以联系我们找货
