114992054
114992054
    SEEED(矽递科技)
    ARGON NEO RASPBERRY PI 4 CASE
114992054 数据手册
      Argon NEO Raspberry Pi 4 Case SKU 114992054   This is a new case for Raspberry Pi 4B, this case is made of Acrylic material. It can protect and dissipate heat.  Designed by Argon40.    Minimalist Design The Argon NEO is designed specifically for the needs and functionality of the Raspberry Pi 4 Model B. Slim Aluminum Enclosure Made with aluminum alloy and polished with a modern Space Grey finish for stunning aesthetics. Passive Cooling The case acts as passive cooling for the high demands of the Raspberry Pi 4 Model B. Robust Yet Portable Assembling the case with the Raspberry Pi is easy. With the case's small form, it's easy to bring anywhere. Sliding Magnetic Top The case has a magnetic top to keep the ports safe when not in use. Access To All Ports All the ports of the Raspberry Pi 4 while keeping the Pi safe. Features:       Sliding Magnetic Top Robust aluminum Enclosure Passive Cooling Raspberry Pi Camera Mount Access to GPIO Pins Easy Installation Compatibility:  Raspberry Pi 4 Part List: 1 x Argon 1 Neo Case 1 x Instruction Manual ECCN/HTS HSCODE  3926909090    UPC                      https://www.seeedstudio.com/Argon‐NEO‐Raspberry‐Pi‐4‐Case‐p‐4249.html/10‐3‐19
114992054 价格&库存
很抱歉,暂时无法提供与“114992054”相匹配的价格&库存,您可以联系我们找货
  • 1+142.267981+18.27033
库存:49
