RF Explorer IoT Touchscreen Kit For
Raspberry Pi
SKU 114992066
This advanced kit provides a cost effective solution for a high performance, color touch screen Spectrum
Analyzer covering 15MHz to 2700MHz
Product description:
screen Spectrum Analyzer covering 15MHz to 2700MHz. Included in the package kit are
these these items:
RF Explorer 3G+ IoT module
Raspberry Pi official 7" Touch Screen
Acrylic custom designed holder
RF Explorer 3G+ IoT modules are ready to use, advanced Spectrum Analyzer devices you
can configure and control easily with Raspberry Pi using a compatible Touch Screen and
free RFETouch software.
These modules are cost-effective platforms to develop your own customized Spectrum
Analyzer, Power Detector, RF activity alarm, RF sniffer, RF QA test bench, etc.
Programmability and network capabilities of the hosting platform enables remote control
and diagnosis scenarios, fully automated RF alarm systems, advanced assistance for
unattended detection requirements such as those of radio operators, cell towers and HAM
stations.
Additional items required but not included in the kit are:
Raspberry Pi model 2, 3 or 4
USB power source for Raspberry Pi and Touchscreen
These items can be reused from other experiments or ordered together with the kit.
Specification:
Includes the advanced 3G+ MWSUB3G RF Explorer Module
Frequency band coverage
15-2700 MHz
Antenna connector
Standard SMA 50 ohms
Advanced selectable internal input stage
Normal, LNA, 30dB attenuator
Amplitude resolution
0.5dBm
Dynamic range
-130dBm to +10dBm
Absolute max input power
+30dBm
Average noise floor level (typical with LNA enabled)
-120dBm
Frequency stability and accuracy (typical)
+-10ppm
Amplitude stability and accuracy (typical)
+-3dBm
Frequency resolution
1 KHz
Resolution bandwidth (RBW)
Automatic 3KHz to 600KHz
Power consumption
100 - 500mW
All modules are factory calibrated
Features
Design and customize your own Spectrum Analyzer, RF Detector, RF Sniffer, etc
Open source design, open source libraries and examples
Supported by all Raspberry Pi boards.
Can update IoT firmware directly from Raspberry Pi no other accessories required
Flexible board: can be connected to a Raspberry Pi by soldering a compatible female
header
Recommend to select SMA antennas for specific application
IMPORTANT: In Raspberry Pi 3, WiFi should be shutdown to avoid interference with the
analyzer.
Raspberry Pi Touch Screen
7" Touchscreen Display.
Screen Dimensions: 194mm x 110mm x 20mm (including standoffs)
Viewable screen size: 155mm x 86mm
Screen Resolution 800 x 480 pixels
10 finger capacitive touch.
Connects to the Raspberry Pi board using a ribbon cable connected to the DSI port.
Adapter board is used to power the display and convert the parallel signals from the
display to the serial (DSI) port on the Raspberry Pi.
More information:
Please visit www.rf-explorer.com/iot
Contents:
Raspberry Pi Touchscreen
Touchscreen acrylic holder
ECCN/HTS
HSCODE
8543909000
UPC
https://www.seeedstudio.com/RF‐Explorer‐IoT‐Touchscreen‐Kit‐For‐Raspberry‐Pi‐p‐4428.html/1‐14‐20
很抱歉,暂时无法提供与“114992066”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+2163.32014100+280.18845
