114992083
114992083
    SEEED(矽递科技)
    ARMOR ALUMINUM METAL CASE WITH D
114992083 数据手册
      Armor Aluminum Metal Case with Dual Fans for Raspberry Pi (Support Pi 4) SKU 114992083 Armor Aluminum Metal Case with Dual Fans is a Raspberry Pi case for Raspberry Pi 2B/3B/3B+/4B. The material of this Raspberry Pi case is aluminum alloy which has an excellent ability to conduct heat. This case also has two fans to enhance the cooling function. Key features     Pi Aluminium alloy cooling case with 2 fans Easy to connect any GPIO PINs on Raspberry Pi Equipped with high-quality hot tape Compatible with Raspberry Pi 2B/3B/3B+/4B Description Worrying about the overheating of your Raspberry Pi? It’s time to get rid of this issue. The material of this Raspberry Pi case is aluminum alloy which has an excellent ability to conduct heat. But that is not enough! This case also has two fans which can be powered by the GPIO Pins of the Raspberry Pi to enhance the cooling function. Moreover, this case is compatible with Raspberry Pi 2B/3B/3B+/4B. Don’t hesitate, buy one and your Raspberry Pi will stay cool and comfortable in this case. Specification      Material: Pi Aluminium alloy with good thermal conductivity Fans: Including 2 fans for better cooling function Processing technic: CNC processing for easy installing Compatibility: Perfect compatible with Raspberry Pi 2B/3B/3B+/4B Accessories: 3 heat-conducting tapes, 1 inner hexagon wrench, 6 M2.5 inner hexagon screw (Not including Raspberry Pi) ECCN/HTS HSCODE 8414599060 UPC https://www.seeedstudio.com/Armor‐Aluminum‐Metal‐Case‐with‐Dual‐Fans‐for‐Raspberry‐Pi‐Support‐Pi‐4‐p‐4318.html/12‐9‐19
114992083 价格&库存
很抱歉,暂时无法提供与“114992083”相匹配的价格&库存,您可以联系我们找货
