114992084
114992084
    SEEED(矽递科技)
    箱 塑料 - ABS 黑色 手持,分叉式双侧 3.622" 长 x 2.756" 宽(92.00mm x 70.00mm) X 1.142"(29.00mm)
114992084 数据手册
        ABS Enclosure Black Case for Raspberry Pi 4 B SKU 114992084     ABS Enclosure Black Case can be perfectly compatible with Raspberry Pi 4B. A cooling fan and heatsink are  added to help Pi to keep cooling.    Note You can choose three types of Raspberry Pi case. They are white type, black type, and transparent type. Key features    High performance of heat dissipation Including cooling fan (35x35x10mm) and heatsink Compatible with Raspberry Pi 4B Description This Raspberry case is made of ABS material. It can be perfectly compatible with Raspberry Pi 4B. Considering the high power consumption cost by Raspberry Pi 4B, the Raspberry case has room to add a fan (35x35x10mm) and general copper/aluminum heatsink (up to 6mm) for heat dissipation. What’s more? The case supports GPIO PINs of the Raspberry Pi 4B connect the external devices like Raspberry Pi Hat outside the case by cables. Also, the ventilation openings are designed on the top and bottom of the case to keep cooling.     Part list    1 cooling fan (35x35x10mm) 1 Heatsink (up to 6mm) 4 M2*6 screws Dimensions 92*70*29 mm ECCN/HTS HSCODE  UPC  3926909090          https://www.seeedstudio.com/ABS‐Enclosure‐Black‐Case‐for‐Raspberry‐Pi‐4‐B‐p‐4317.html/12‐9‐19
114992084 价格&库存
很抱歉,暂时无法提供与“114992084”相匹配的价格&库存,您可以联系我们找货
