ABS Enclosure White Case for Raspberry Pi 4 B
SKU 114992086
ABS Enclosure White Case can be perfectly compatible with Raspberry Pi 4B. A cooling fan and heatsink are
added to help Pi to keep cooling.
Note
You can choose three types of Raspberry Pi case. They are white type, black type, and transparent type.
Key features
High performance of heat dissipation
Including cooling fan (35x35x10mm) and heatsink
Compatible with Raspberry Pi 4B
Description
This Raspberry case is made of ABS material. It can be perfectly compatible with Raspberry
Pi 4B. Considering the high power consumption cost by Raspberry Pi 4B, the Raspberry
case has room to add a fan (35x35x10mm) and general copper/aluminum heatsink (up to
6mm) for heat dissipation. What’s more? The case supports GPIO PINs of the Raspberry Pi
4B connect the external devices like Raspberry Pi Hat outside the case by cables. Also,
the ventilation openings are designed on the top and bottom of the case to keep cooling.
Part list
1 cooling fan (35x35x10mm)
1 Heatsink (up to 6mm)
4 M2*6 screws
Dimensions
92*70*29 mm
ECCN/HTS
HSCODE
UPC
3926909090
https://www.seeedstudio.com/ABS‐Enclosure‐White‐Case‐for‐Raspberry‐Pi‐4‐B‐p‐4322.html/12‐9‐19
很抱歉,暂时无法提供与“114992086”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+34.468901+4.47232
