114992115
114992115
    SEEED(矽递科技)
    DUAL SATA HAT FOR RASPBERRY PI 4
114992115 数据手册
      Dual SATA HAT for Raspberry Pi 4 SKU 114992115 This is a Pi Hat for Raspberry Pi 4 with SATA port which can insert HDD/SSD for extra storage. Key Features           Up to 2x HDD/SSD´s - 2.5 or 3.5inch storage is supported Utilizes two independent USB3 buses on Raspberry Pi 4 Type C power input with USB PD/QC support for 2.5inch drives and Raspberry Pi 4 External standard ATX power supply support for 3.5inch HDD Fan and heatsink for Raspberry Pi 4 CPU cooling HDD suspend mode supported UASP support Software RAID 0/1/5 support Optional PWM control fan for HDD heat dispatching Optional OLED display for IP Address/Storage info Description Are you worried about your Raspberry Pi 4 that they don't have enough storage? Here is a HAT for Raspberry Pi 4 which you can use the SATA port HDD to extend your Pi storage. For 3.5inch HDD setups, a standard ATX PSU is required to power the HDD´s and the Raspberry Pi. With 2x 3.5inch HDD´s the PSU should provide at least 60W or more. For 2.5inch HDD setups, the USB PD/QC power adapter ( >=30W power adapter ) is sufficient to power the disk drives and the Raspberry Pi 4 together. It is important to mention that the power connector on the SATA HAT must be used to power up the NAS with Raspberry Pi 4. The Dual SATA HAT utilizes two high-performance JMS561 (one JMS561 for the Dual SATA HAT) and provides up to 400MB/s read/write performance with four disks in RAID0 mode. Hardware Overview Part List    Dual SATA HAT board USB3.0 Connection adapter 2x SATA cable ECCN/HTS HSCODE UPC 8473301000             https://www.seeedstudio.com/Dual‐Quad‐SATA‐HAT‐for‐Raspberry‐Pi‐4‐or‐Rock‐Pi‐4‐p‐4389.html/1‐14‐20
114992115 价格&库存
很抱歉,暂时无法提供与“114992115”相匹配的价格&库存,您可以联系我们找货
