re_computer case: Most Compatible Enclosure for SBCs
SKU 114992152
The re_computer case is specially designed for the re_computer system, compatible with all popular
SBCs, with a removable acrylic cover on the top, and with a stackable structure to extend endless
possibilities
Key Feature
Compatible with all popular SBCs
Removable top layer Acrylic
Stackable case structure for expansions
Description
The re_computer case is specially designed for the re_computer system. It is more than just
aesthetic, there are also great features:
It is compatible with all popular SBCs. The re_computer case can not only install the
ODYSSEY - X86 board, we have designed and left screw holes for the installation of the
most popular SBCs including Raspberry Pi, BeagleBone and Jetson Nano.
The top acrylic cover is removable. If you want to add a HAT or Cape on your SBC inside
the case, there is no need to re-screw the whole case because the top acrylic layer is
designed to be removed easily.
Stackable structure to extend endless possibilities for building different applications
such as NAS. If your application requires more space, for example, adding more hard disks
to make a NAS, the stackable structure allows you to stack more middle layers to create
rooms very easily.
At Seeed, you can also design your solution all in one page where you choose the desired
SBC, any compatible mission board (HATs, expansions) that you want, I/O modules, and
nicely place them in the suitable enclosures/cases such as re_computer case. Rest assured,
as we have tested full compatibility for all of the products listed on the page. Try it
now here and save you time to find hardware compatibility!
ECCN/HTS
HSCODE
UPC
8543909000
https://www.seeedstudio.com/re‐computer‐case‐p‐4465.html/3‐11‐20
很抱歉,暂时无法提供与“114992152”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+366.043401+47.00800
