Power-Over-Ethernet (PoE) HAT for Raspberry Pi
4B/3B+
SKU 114992117
Power-Over-Ethernet (PoE) HAT for Raspberry Pi 4B/3B+ is a Raspberry Pi HAT which can
support PoE for your Raspberry Pi 4B/3B+.
Key Features
Easy to assemble
Compatible With: Raspberry Pi 4 Model B / Raspberry Pi 3 Model B+
Built-in Cooling Fan
Support IEEE 802.3af or 802.3at PoE standard
Description
Raspberry Pi 4B/3B+ generally uses USB type-C interface for power supply. Although they
both have one ethernet interface for internetwork, it can not realize the power supply
function. Now, with this PoE Hat, things will be different. I'm afraid the USB type-C cable
will not be available anymore.
This PoE Hat for Raspberry Pi supports active PoE which includes IEEE 802.3af and 802.3at
PoE standard protocol. As a matter of fact, there is a "handshake" between PSE(Power
Source Equipment) and PD(Powered Devices) and the PD will not apply the power supply
if the supplied voltage is not matched. It is quite safe for your Raspberry Pi.
The Hat is perfectly compatible with Raspberry Pi 4B and available for Raspberry Pi 3B+.
The way to assemble the HAT on Raspberry Pi Hat is easy as well, you can view the
procedure here.
Attention
PoE power output must be within the budget of the switch when powering multiple boards!!!
STANDARDS COMPLIANT POWER OVER ETHERNET SWITCH REQUIRED!!!
The network switch or power sourcing equipment (PSE) must be compliant with the IEEE 802.3af or
802.3at PoE standard, particularly section 33.4.1 with regards to PSE electrical isolation of the leads.
"Passive PoE" (DC 24V or 48V) is not standards compliant and may cause damage to equipment.
Do not use this product in an enclosed case without active air circulation!!
Specification
Input: IEEE 802.3af Compliant PoE
Output: 5V +-5% up to 2.5A*
Protection Circuitry: Transient Overvoltage, Undervoltage Lockout, Thermal Shutdown, Foldback
Current Limiting
Active airflow and adequate cooling required for stable continuous operation at high load.
Weight: 30g
Part List
1 x Power-Over-Ethernet(PoE) Hat with 3007 Cooling Fan
3 x M2.5*9+6 Copper Stick
3 x M2.5 Screws
3 x M2.5 Nuts
1 x Aluminum Heat Sink
1 x Screw Driver
ECCN/HTS
HSCODE
UPC
8543909000
https://www.seeedstudio.com/Power‐Over‐Ethernet‐PoE‐HAT‐for‐Raspberry‐Pi‐4B‐3B‐p‐4391.html/1‐14‐20
很抱歉,暂时无法提供与“114992117”相匹配的价格&库存,您可以联系我们找货
