114992382
114992382
    SEEED(矽递科技)
    缆线 C 母头转 C 公头 0.92'(280.0mm)
114992382 数据手册
SKU 114992382 USB Type-C Male to Female Extension Cable with Switch – 28cm USB Type-C Male to Female Extension Cable comes with a switch that can be used to conveniently turn ON/OFF any device connected to the cable. Also, the cable has a length of 28cm which makes it useful if you want the device to be far away from the power source. It also can support currents up to 4A. PRODUCT DETAILS Features • Conveniently turn ON/OFF devices with the built-in switch • 28cm extended length • Supports up to 4A of high current flow Description When you connect a Raspberry Pi to power, the Pi will turn on instantly when the power is supplied because there is no physical power button on the Raspberry Pi. The same applies to most other development boards in the market with a USB Type-C power input connector. So, this extension cable can be a solution to all these devices. USB Type-C Male to Female Extension Cable comes with a switch that can be used to conveniently turn ON/OFF any device connected to the cable. Also, the cable has a length of 28cm which makes it useful if you want the device to be far away from the power source. It also can support currents up to 4A. Note Please note that this cable can only transmit power. It cannot be used to transmit data Specifications • • Cable Length : 28cm Maximum Current Allowed : 4A Part List 1 x USB Type-C Male to Female Extension Cable with Switch – 28cm ECCN/HTS HSCODE 8544421900 USHSCODE 8544493080 UPC EUHSCODE 8544492000 COO CHINA RoHS 1 https://www.seeedstudio.com/Type-C-Extension-Cable-with-Switch-p4734.html?queryID=efcac0e15353ccc01fc80f75b95ea56c&objectID=4734&indexName=bazaar_retailer_ products 4-13-2023
114992382 价格&库存
很抱歉,暂时无法提供与“114992382”相匹配的价格&库存,您可以联系我们找货
  • 1+16.802811+2.17390
