Superheterodyne wireless transceiver module- 433MHz
SKU 114992733
This is a complete wireless
transmitting and receiving
kit, which can be applied to
simple data wireless
transmission, wireless
remote control, anti-theft
alarm system, etc. The kit is
composed of ASK transmitter
and receiver modules with
superior performance and
low cost. The carrier
frequency is 433MHz.
PRODUCT DETAILS
Features
Low power consumption: 3.3V about 3.8mA / 5V about 4.2mA(315MHz)
High receiving sensitivity: -109dBm@10kbps
Wide temperature range: -40~85℃
Flexible application,breadboard and PCB friendly
Strong radiation suppression ability:no mutual interference, no influence on
receiving distance.
Description
This is a complete wireless transmitting and receiving kit, which can be applied to
simple data wireless transmission, wireless remote control, anti-theft alarm system,
etc. The kit has a simple structure and flexible application, and can be directly applied
to the design and experimental development of various products.
The popular link is like this: MCU -> Encoder -> Transmitter ------ Receiver -> Decoder ->
MCU.You can use this kit to build a system with other main control equipment, such as
Arduino,Seeeduino XIAO, to implement applications such as wireless security alarms,
remote control tools, and so on.
The following is the introduction of the transmitter and receiver respectively.
[Transmitter]
In the wireless transceiver kit, the wireless transmitter module model is APF03, and its
working voltage range is 3-12v.It adopts OOK modulation mode, which has the
advantages of fast modulation rate and long transmission rate.
OOK (on-off keying) is binary switching keying. The modulation principle is to control
the passage of the carrier by controlling the opening and closing of the switching
device through the binary sequence, so as to load the binary signal onto the carrier. It
is a low-cost and most easily implemented modulation method, which is widely used in
various occasions.
[Receiver ]
In addition, the model of the decoding wireless receiving module is RXB28, and the
working frequency is 315MHz or 433.92MHz. The recommended power supply input is
5V. At this time, when the operating frequency is 315MHz, the current can be as low as
4.2mA, and the power consumption is very low.
The receiving structure of this module is a superheterodyne method, receiving OOK
wireless signal. After receiving the signal, it will directly output the COMS signal to the
external IC for decoding. It has good local oscillator radiation suppression capability
and can work with multiple receiving modules.
Application
Car remote control door switch (RKE)
Remote access control
Wireless security alarm
Remote control curtain machine
Wireless industrial controller
Wireless data transmission
Wireless remote control robot
Specification
Parameter
Description
Working voltage
Transmitter(3-12V),Receiver(3.3-5V)
Working current
Transmitter :max≤35mA(12V), min≤2mA(3V)
Receiver :max≤4.5mA(5.5V), min≤3.8mA(3.3V)
Principle of work
Superhet(VCO, PLL)
Modulation
OOK/ASK
Working band
315MHz ; 433.92MHz
(customize service available)
Sensitivity
-109dBm (50Ω)
Modulation rate
<10Kbps
Decoding form
IC decoding
Temperature range
-40~85℃
Product drawings and pin information
Transmitter
The pins are arranged from left to right as follows:
Pin
Name
Function declaration
1
VCC
Positive pole
2
GND
Negative pole
3
DATA
Signal pin
4
ANT
Antenna pin
The transmitter module has a small volume and a standard 2.54 spacing for convenient
installation.
Receiver
Pin
Name
1
ANT
Antenna pin
2
VCC
Positive pole
3
DATA
Signal output
4
DATA
Signal output
5
GND
Negative pole
Technical Details
Dimensions
50mm x29mm x9mm
Weight
G.W 5g
Battery
Exclude
Part List
Transmitter module
1
Receiver module
1
ECCN/HTS
HSCODE
8517709000
USHSCODE
8517180050
UPC
841454112822
https://www.seeedstudio.com/Superheterodyne-wireless-transceiver-module-315MHz-433MHz-p-5078.html?queryID=3ab2f1951433bdae465ea3832db84cd9&objectID=5078&indexName=bazaar_retailer_products/8-17-22
很抱歉,暂时无法提供与“114992733”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+43.097571+5.57985
