Serial CAN‐BUS Module based
on MCP2551 and MCP2515
SKU 114991377
Description
The Serial CAN‐BUS provides your Arduino or others MCU with the capability to communication to CAN‐
BUS, such as hacking your vehicle. CAN‐BUS is a common industrial bus because of its long travel
distance, medium communication speed and high reliability.
This Serial CAN‐BUS module is based on MCP2551 and MCP2515, which can provide speed up to 1Mb/s.
There's Grove connect as well as Grove cable included in the kit, which allows connect the module to
your Arduino easily, click to get more about Seeed Grove System. http://wiki.seeed.cc/Grove_System/
Features
•Uart to CAN‐BUS communication
•AT command
•Up to 115200 Uart baud rate (default 9600)
•Up to 1Mb/s CAN‐BUS baud rate
•TX and RX led indicator
•4pin Grove connector
•3.3V working voltage
•Easy‐to‐use Arduino library
•Small size
Support
Please feel free to contact joney.sui@longan‐labs.cc if you need techsupport.
Technical Details
Dimensions
20mm x 40mm x 10mm
Weight
G.W 9.5g
Battery
Exclude
Part List
Serial CAN‐Bus PCBA
1
4 Pin Grove cable
1
Small screw
1
https://www.seeedstudio.com/Serial‐CAN‐BUS‐Module‐based‐on‐MCP2551‐and‐MCP2515‐p‐2924.html 9‐7‐17
很抱歉,暂时无法提供与“114991377”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+193.914671+25.20306
