317030016
317030016
    SEEED(矽递科技)
    Module
    2.4GHZ LOW POWER BLE4.0
317030016 数据手册
Page 1 of 2 2.4GHz Bluetooth Low Energy 4.0 module-4dB V-13051 SKU: 317030016 (images/product/317030016 1_01.jpg) (https://www.kickstarter.com/projects/seeed/wiolink-3-steps-5-minutes-build-your-iotapplicat/description?ref=banner_depot) Description V-13051 is a high integration small size Bluetooth 4.0 module. Features 1.  This module is based on low energy bluetooth4.0 chip NRF51822.support BLE4.0 mode and private mode. 2.  ARM Cortex-M0 32 core 128K Flash 16K RAM 3.  128bit AES hardware encryption, ,with a 1dB resolution RSSI,10bit ADC I2C UART SPI WDT RTC PPI 4.  Small size 12mm*19mm*2mm,pin space 1.27mm,can be used as embedded wireless development platform 5.Widely used as Bluetooth,serial port, remote control, wireless meter reading, industrial data collection, heart rate ,ANCS, keyboard and HID device, etc Specification Page 2 of 2 Work Frequency 2400MHZ-2483MHZ Work Voltage 1.8-3.6V Maximum power +4dBm Transmission rate 250/1000/2000kbps TX current 10mA RX current 13mA MCU work current 4.4mA@16MHZ@3v 自Flash运行 MCU work current 2.4mA@16MHZ@3v 自RAM   运行 MCU idle mode 2.3uA@3V ON mode,all block idle MCU close mode 420uA@3v OFF mode sensitivity -96dBm@250kbps 0.1%BER Overview (http://www.seeedstudio.com/depot/Shenzhen-2U-t-11.html?ref=pinfo) Designer: Others Other Products From This Designer (http://www.seeedstudio.com/depot/Others-m-24.html?ref=pinfo) Weight: 2 g http://www.seeedstudio.com/depot/24GHz-Bluetooth-Low-Energy-40-module4dB-V1305... 12/2/2015
317030016 价格&库存
很抱歉,暂时无法提供与“317030016”相匹配的价格&库存,您可以联系我们找货
