322070581
322070581
    SEEED(矽递科技)
    RASPBERRY PI ABS ENCLOSURE W/COO
322070581 数据手册
      Raspberry Pi ABS Enclosure with Cooling Fan ‐ Transparent SKU 322070581 Description   Now, the Raspberry Pi is a superstar in open source hardware, more and more people use the Raspberry Pi. However, it is quite often that the Raspberry Pi is damaged by accidental fall or running slow because of high temperatures. So why not choose some gears for your Raspberry Pi to make it stronger and faster. Here, we recommend the Raspberry Pi ABS Enclosure with Cooling Fan, it can protect your Raspberry Pi and cool it down at the same time. It is made of high quality ABS, which has high impact resistance and high toughness characteristics. Meanwhile, this enclosure can drive away heat with a built‐in fan. We also provide a black version, you can check here. Assembly drawing Technical Details Dimensions 93.50mm x 62.70mm x 27.50mm  Weight  G.W 40g      Battery  Exclude  Fan Operating Voltage  5V  Max Fan current  0.15A  Max Fan Power  0.75W  Supported Models  Raspberry Pi 1 Model B+/ 2 Model B / 3 Model B / 3 Model B+  Part List Raspberry Pi ABS Enclosure with  Cooling Fan ‐ Transparent 1  Cooling Fan  1  Gasket  4  Screw  2  ECCN/HTS ECCN EAR99  HSCODE  3923100090                                https://www.seeedstudio.com/Raspberry%20Pi%20ABS%20Enclosure%20with%20Cooling%20Fan%20‐%20Transparent‐p‐3112.html 9‐7‐18
322070581 价格&库存
很抱歉,暂时无法提供与“322070581”相匹配的价格&库存,您可以联系我们找货
  • 10000+29.8072910000+3.86126
