322070580
322070580
    SEEED(矽递科技)
    RASPBERRY PI ABS ENCLOSURE W/COO
322070580 数据手册
    Raspberry Pi ABS Enclosure with Cooling Fan ‐ Black SKU 322070580 Description Now, the Raspberry Pi is a superstar in open source hardware, more and more people use the Raspberry Pi. However, it is quite often that the Raspberry Pi is damaged by accidental fall or running slow because of high temperatures. So why not choose some gears for your Raspberry Pi to make it stronger and faster. Here, we recommend the Raspberry Pi ABS Enclosure with Cooling Fan, it can protect your Raspberry Pi and cool it down at the same time. It is made of high quality ABS, which has high impact resistance and high toughness characteristics. Meanwhile, this enclosure can drive away heat with a built‐in fan. We also provide a transparent version, you can check here. Assembly drawing Technical Details Dimensions 93.50mm x 62.70mm x 27.50mm  Weight  G.W 40g      Battery  Exclude  Fan Operating Voltage  5V  Max Fan current  0.15A  Max Fan Power  0.75W  Supported Models  Raspberry Pi 1 Model B+/ 2 Model B / 3 Model B / 3 Model B+  Part List Raspberry Pi ABS Enclosure ‐ Black 1  Cooling Fan  1  Gasket  4  Screw  2  ECCN/HTS ECCN EAR99  HSCODE  3923100090                     https://www.seeedstudio.com/Raspberry%20Pi%20ABS%20Enclosure%20with%20Cooling%20Fan%20‐%20Black‐p‐3111.html 9‐7‐18
322070580
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外发射二极管。
2. 器件简介:EL817是一种红外发射二极管,常用于遥控器等设备。
3. 引脚分配:EL817有两个引脚,分别为阳极和阴极。
4. 参数特性:工作电压范围为1.4V至1.8V,工作电流为50mA。
5. 功能详解:EL817能够发射红外光,用于无线通信。
6. 应用信息:主要用于遥控器、传感器等设备。
7. 封装信息:EL817采用黑色塑料封装,尺寸为5.7mm x 2.8mm。
322070580 价格&库存
很抱歉,暂时无法提供与“322070580”相匹配的价格&库存,您可以联系我们找货
  • 10000+29.7088710000+3.86126
