102110560
102110560
    SEEED(矽递科技)
    Edge Server ODYSSEY X86
102110560 数据手册
reServer i31115(16G+512SSD/W) - Compact Edge Server powered by 11th Gen Intel® Core™i3 1115G4 (16G+512SSD/W) SKU B102110560 reServer is based on an ODYSSEY X86 v2 board and powered by Intel® Core™ 11th Gen. i3 and Intel UHD Graphics 48EUs (400 - 1250 MHz), which delivers high CPU and AI performance for various applications. It has two high-speed 2.5-Gigabit Ethernet ports and supports hybrid connectivity including 5G, LoRa, BLE and WiFi. reServer is of compact design to work efficiently in almost any scenario. The neat structure of reServer also makes it simple to access to the hard drives, memory and PCIe slots which allows easy installation, upgrades and maintenance. Do not need the encloser? Get the main board of reServer, ODYSSEY X86 v2 board. PRODUCT DETAILS Note Please make sure to also choose the AC Power Cord to use with reServer: • AC Power Cord Compatible with reServer - US • AC Power Cord Compatible with reServer - EU Note Please make sure that this reServer has been pre-installed 16G Memory Module, 512G SSD and WiFi Module. Features • Compact design for a server with an overall dimension of 132mm*124mm*233mm • Powered by the latest 11th Gen Intel® Core™ i3 CPU running up to 4.10GHz and Intel UHD Graphics 48EUs running up to 1.25 GHz • Rich peripherals including dual® 2.5-Gigabit Ethernet ports, USB 3.2 Type-A port, USB 2.0 Type-A port, HDMI port and DP port • Support hybrid connectivity including 5G, LoRa, BLE and WiFi (5G and LoRa need additional modules) • Dual SATA III 6.0 Gbps data connectors for 3.5”/2.5" SATA hard disk drives with enough space inside the enclosure to store them both • M.2 B-Key/ M-Key/ E-Key for expandability such as SSD, LTE/4G/5G, WiFi 6 Modules • Quiet cooling fan with a large VC heat sink for excellent heat dissipation • Easy to install, upgrade and maintain with ease of access to the internal components after opening the enclosure • Pre-installed Windows 10 Enterprise(Unactivated), also support other Windows OS and Linux OS Description reServer, as a milestone product of reThings family, is extremely compact and powerful. This smart tiny server is able to work easily and efficiently from the edge to the cloud. reServer is based on an ODYSSEY X86 v2 board and powered by the latest 11th Gen Intel® Core™ i3 CPU running up to 4.10GHz and Intel UHD Graphics 48EUs running up to 1.25 GHz, which delivers high CPU and AI performance for various applications. reServer comes with two high-speed 2.5-Gigabit Ethernet ports and supports hybrid connectivity including 5G, LoRa, BLE and WiFi. It enables up to 250% faster performance than Gigabit Ethernet with compatible hardware and provides the transition speed up to 5Gbps using link aggregation. With an overall dimension of 132mm*124mm*233mm, reServer is only around 1/10 of the size of an ordinary computer case which makes it possible to place reServer on a table, on a self, on any surface you want it to be. The neat structure of reServer also makes it simple to access the hard drives, memory and PCIe slots which allows for easy installation, upgrade and maintenance. reServer is equipped with a quiet cooling fan as well as a large VC heatsink to ensure silent and stable operations under heavy load, while providing excellent heat dissipation. Having dual SATA III 6.0Gbps data connectors, reServer is able to equip up to two 3.5” SATA internal hard disk drives or two 2.5" SATA internal hard disk drives to acquire more storage. It also has M.2 adapters to connect to various SSDs for faster read and write speeds. * SATA Internal Hard Disk Drives are not included. SSD is not included in some versions. reServer supports LoRa technology which makes it possible to connect to a wide range of sensors. It can be applied as an edge computing center for all scenarios that require vast data to collect and process at the edge. The expandability of 5G technology is useful in places where there isn’t always reliable internet connectivity, such as on a farm or in a location with spotty service. *To get LoRa and 5G connectivity, optional modules are needed. Application • Small office, home office server • Industrial Automation • Robotics • Healthcare • Smart Agriculture • NAS Specifications Versions Platform High Performance Basic Versions Processor Intel® Intel® Core™ Core™ 11th 11th Versions Intel® Intel® Intel® Core™ Core™ Core™ vPro® vPro® 11th Gen. 11th Gen. Versions Cores/Thread s Frequency Co-processor Memory Versions Gen. i3 Gen. i3 11th Gen. i5 i7 1115G4 1125G4 i5 1135G7 1145GRE 1185GRE 2C/4T 4C/8T 4C/8T 4C/8T 4C/8T Up to Up to Up to 4.20 1.50 GHz ~ 1.80 GHz ~ 4.10 GHz 3.70 GHz GHz 4.10 GHz 4.40 GHz Microchip® ATSAMD21G18 32-Bit ARM® Cortex-M0+ @ 48MHz Technology Dual Channels DDR4-3200 Capacity Support up to 64GB ECC Memory Supported Graphics High Performance Basic Versions Controller NO Raspberry Pi® RP2040 32-Bit Dual ARM Cortex-M0+ @ 133MHz YES Intel® Intel® UHD UHD Graphics Graphics 48EUs 48EUs (400 - (400 - 1250MHz 1250MHz ) ) Intel® Iris Intel® Iris Intel® Iris Xe Xe Xe Graphics Graphics Graphics G7 G7 G7 80EUs(400 80EUs(400 96EUs(400 -1300MHz) -1300MHz) -1300MHz) Versions Basic Versions Intel® vPro® High Performance Versions NO YES NO YES Advanced Technologie s Intel® Total Memory Encryption Network Controller WiFi Wireless Display Intel® Ethernet Controller I225-V Intel® Ethernet Controller I225-LM M.2 E-Key(PCIE & CNVi Support), Intel® Wi-Fi 6 AX201(Optional) Bluetooth Bluetooth 5.0, BLE(Optional) LCD eDP 40-Pin 4 Lane Connector HDMI 1 x HDMI 2.0b, up to 4Kx2Kx24bpp@60Hz DP 1 x DP1.4a 7680x4320x24bpp@60Hz Multiple 4 simultaneous displays with each display interface Display combination Ethernet External I/O HDMI/DP 2 x 2.5GbE LAN ports (RJ45, supports 10/100/1000/2500 Mbps), Intel® i225 One/One Versions Basic Versions USB Type-C USB Type-A N/A High Performance Versions USB PD / USB 4.0 / Thunderbolt 4 USB2.0 Type A x1 ; USB3.2 Type A USB2.0 Type A x2 ; x1 USB3.2 Type A x1 LED Power Status Power Supply 1x5.5x2.5mm DC Jack / Wafer 2.0mm 8pin Micro Sim Card Slot SATA COM Port GPIO Internal I/O Audio 1 2 x SATA Gen III 6.0 Gb/s Data Connectors + 3 x SATA Power Connectors 1 x RS-232/422/485, 1 x RS-232 28-Pin Arduino Co-processor 2.54mm header 30-Pin Raspberry Pi Coprocessor 2.54mm header Realtek High Definition Audio, Microphone + headphone Combo Connector USB2.0 USB2.0 9-pin Header x2 480Mbps Fan 2 x 12V 4-wire Fan header, PWM Control Versions Basic Versions Front Panel Control 3-Pin 2.54mm Header SATA Power WAFER4-Pin 2.0 pitch Connector Debug Port Expansion 1 x M-Key 2242/2280(PCIe 3.0 x4) M.2 E-Key 1 x E-Key 2230(PCIe 3.0 x1; USB2.0 x1;Intel CNVi) M.2 B-Key 1 x B-Key2242/2252/2280(PCIe 3.0 x2; USB2.0 x1) I/O Supply Feature 6-Pin 0.5mm FPC Connector (SWD) M.2 M-Key High Speed Power Versions Power-on, Reset, Power Status LED, SATA Status LED S/PDIF Co-CPU. High Performance Voltage 1 X PCIe 3.0 1 X PCIe x4 Gen4 x4/SMBus/LPC/USB 2.0/CPU GPIO etc. DC Jack: 12V RTC Battery Lithium 3V/210mAH TPM Support DC Jack: 12V-19V Versions Certification Mechanical Basic Versions High Performance Versions Secure Boot Support EMC CE,FCC,TELEC Dimension 124mm*132mm*233mm Thermal Heat Pipe Assemblies/Heat Spreading Vapor Chamber Solution Assemblies Weight 1800g Hardware Overview Dimensions Part List 1 x reServer 1 x User Manual 1 x Screwdriver 1 x Fan Cable 2 x 2.4/5GHz Wi-Fi Antenna 1 x 60W AC-DC Power Adapter 1 x 8GB SODIMM DDR4 3200MHz (Already installed) 1 x M.2 2280 256GB NVMe PCIe 3.0 SSD (Already installed) 1 x M.2 Key E 2230 Dual Band Wi-Fi 6 AX201(CNVio) module (Already installed) ECCN/HTS HSCODE 8471419000 UPC https://www.seeedstudio.com/reServer-Compact-Edge-Server-powered-by-11th-Gen-Intel-Coretmi3-1115G4-16G-512SSD-W-p-5056.html/5-22-22
102110560 价格&库存
很抱歉,暂时无法提供与“102110560”相匹配的价格&库存,您可以联系我们找货
  • 1+8687.242571+1128.42874
库存:1
