102110608
102110608
    SEEED(矽递科技)
    SBC 3.7GHZ 2 CORE 64GB/0GB RAM
102110608 数据手册
ODYSSEY- X86i31125G4 Powerful Edge Platform powered by 11th Gen Intel® Core™ i3 1125G4 SKU B102110608 ODYSSEY X86i31125G4 is an ODYSSEY X86 v2 board and powered by the quad-core Intel® Core™ 11th Gen. i3 1125G4 and Intel UHD Graphics 48EUs (400 - 1250 MHz), which delivers high CPU and AI performance for various applications. The x86 board has two high-speed 2.5-Gigabit Ethernet ports and supports hybrid connectivity including 5G, LoRa, BLE and WiFi. There is also an onboard ATSAMD21 coprocessor, an ARM Cortex-M0+ MCU that allows you to program Arduino on the x86 platform. PRODUCT DETAILS Features • Powered by 11th Gen Intel® Core™ i3 1125G4 CPU running up to 3.70GHz and Intel UHD Graphics 48EUs running up to 1.25 GHz • Rich peripherals including dual® 2.5-Gigabit Ethernet ports, USB 3.2 Type-A port, USB 2.0 Type-A port, HDMI port and DP port • Support hybrid connectivity including 5G, LoRa, BLE and WiFi (5G, LoRa, BLE and WiFi need additional modules) • Dual SATA III 6.0 Gbps data connectors for hard disk drives • Embedded Arduino Coprocessor ATSAMD21G18 32-Bit ARM® Cortex-M0+ • M.2 B-Key/ M-Key/ E-Key for expandability such as SSD, LTE/4G/5G/LoRaWAN/WiFi/BLE modules • Support both Windows OS and Linux OS Description ODYSSEY is a series of SBC (Single Board Computer),there are already ODYSSEYX86J4125 in this series as the mian core of the mini pc, reComputer. Here, we would like to introduce our new ODYSSEY board - the ODYSSEY-X86 v2 board. ODYSSEY X86i31125G4, as one of the main cores of reServer series, is a highperforming yet cost-efficient board from the edge to the cloud. By supporting both Windows OS and Linux OS, ODYSSEY-X86i31125G4 allows you to build applications efficiently and easily no matter for commercial, industrial, or other uses. ODYSSEY X86i31125G4 is an ODYSSEY X86 v2 board and powered by the quad-core Intel® Core™ 11th Gen. i3 1125G4 running up 3.70GHz and Intel UHD Graphics 48EUs (400 - 1250 MHz) running up to 1.25GHz, which delivers high CPU and AI performance for various applications. It comes with two high-speed 2.5-Gigabit Ethernet ports and supports hybrid connectivity including 5G, LoRa, BLE and WiFi. It enables up to 250% faster performance than Gigabit Ethernet with compatible hardware and provides the transition speed up to 5Gbps using link aggregation. ODYSSEY X86i31125G4 is equipped with a large scale of heatsink to ensure stable operations under heavy load, while providing excellent heat dissipation to enable the power of CPU. Vapor Chambers heatsink dissipates heat by phase transition of liquid. It can work more efficiently to maintain the bestoperating temperature of CPU. Compared with cooper board, VC board of the same size improves the heat-sinking performance by at least 40%. At the same time, VC heatsink has less limits for working space and angles. Having dual SATA III 6.0Gbps data connectors, ODYSSEY X86i31125G4 is able to equip up to two SATA hard disk drives to acquire more storage. It also has M.2 adapters to connect to various SSDs for faster read and write speeds. * SATA Hard Disk Drives are not included. SSD is not included in some versions. There is an onboard ATSAMD21 Core, an ARM Cortex-M0+ MCU that allows you to program Arduino on the x86 platform, which provides endless possibilities of using the X86 i3 1125G4 The X86 board supports LoRa technology which makes it possible to connect to a wide range of sensors. It can be applied as an edge computing center for all scenarios that require vast data to collect and process at the edge. The expandability of 5G technology is useful in places where there isn’t always reliable internet connectivity, such as on a farm or in a location with spotty service. *To get LoRa and 5G connectivity, optional modules are needed. Place it in the artistic, suitable enclosure which is of the compact and delicate structure to have a neat work space. Get a reServer, the X86 board with a nice enclosure. Specifications Versions Processor Platform Cores/Thread s Frequency Co-processor Memory Versions Intel® Intel® Intel® Core™ Core™ Core™ vPro® vPro® 11th Gen. 11th Gen. 11th Gen. i5 1135G7 i5 i7 1145GRE 1185GRE 4C/8T 4C/8T 4C/8T Up to Up to 4.20 1.50 GHz ~ 1.80 GHz ~ 3.70 GHz GHz 4.10 GHz 4.40 GHz Intel® Intel® Core™ Core™ 11th 11th Gen. i3 Gen. i3 1115G4 1125G4 2C/4T 4C/8T Up to 4.10 GHz Microchip® ATSAMD21G18 32-Bit ARM® Cortex-M0+ @ 48MHz Technology Dual Channels DDR4-3200 Capacity Support up to 64GB ECC Memory Supported Graphics High Performance Basic Versions Controller NO Raspberry Pi® RP2040 32-Bit Dual ARM Cortex-M0+ @ 133MHz YES Intel® Intel® Intel® Iris Intel® Iris Intel® Iris UHD UHD Xe Xe Xe Graphics Graphics Graphics Graphics Graphics 48EUs 48EUs G7 G7 G7 Versions High Performance Basic Versions Intel® vPro® Versions (400 - (400 - 80EUs(400 80EUs(400 96EUs(400 1250MHz 1250MHz -1300MHz) -1300MHz) -1300MHz) ) ) NO YES NO YES Advanced Technologie Intel® Total s Memory Encryption Network Controller WiFi Wireless Display Intel® Ethernet Controller I225-V Intel® Ethernet Controller I225-LM M.2 E-Key(PCIE & CNVi Support), Intel® Wi-Fi 6 AX201(Optional) Bluetooth Bluetooth 5.0, BLE(Optional) LCD eDP 40-Pin 4 Lane Connector HDMI 1 x HDMI 2.0b, up to 4Kx2Kx24bpp@60Hz DP 1 x DP1.4a 7680x4320x24bpp@60Hz Multiple 4 simultaneous displays with each display interface Display combination Versions Basic Versions Ethernet External I/O Mbps), Intel® i225 One/One USB Type-C N/A USB PD / USB 4.0 / Thunderbolt 4 USB2.0 Type A x1 ; USB3.2 Type A USB2.0 Type A x2 ; x1 USB3.2 Type A x1 LED Power Status Power Supply 1x5.5x2.5mm DC Jack / Wafer 2.0mm 8pin Micro Sim Card Slot SATA Internal I/O Versions 2 x 2.5GbE LAN ports (RJ45, supports 10/100/1000/2500 HDMI/DP USB Type-A High Performance COM Port GPIO 1 2 x SATA Gen III 6.0 Gb/s Data Connectors + 3 x SATA Power Connectors 1 x RS-232/422/485, 1 x RS-232 28-Pin Arduino Co-processor 2.54mm header 30-Pin Raspberry Pi Coprocessor 2.54mm header Versions Basic Versions Audio Versions Realtek High Definition Audio, Microphone + headphone Combo Connector USB2.0 USB2.0 9-pin Header x2 480Mbps Fan 2 x 12V 4-wire Fan header, PWM Control Front Panel Control Power-on, Reset, Power Status LED, SATA Status LED S/PDIF 3-Pin 2.54mm Header SATA Power WAFER4-Pin 2.0 pitch Connector Co-CPU. Debug Port Expansion High Performance 6-Pin 0.5mm FPC Connector (SWD) M.2 M-Key 1 x M-Key 2242/2280(PCIe 3.0 x4) M.2 E-Key 1 x E-Key 2230(PCIe 3.0 x1; USB2.0 x1;Intel CNVi) M.2 B-Key 1 x B-Key2242/2252/2280(PCIe 3.0 x2; USB2.0 x1) High Speed I/O 1 X PCIe 3.0 1 X PCIe x4 Gen4 x4/SMBus/LPC/USB 2.0/CPU GPIO etc. Versions Basic Versions Supply Power Certification Voltage DC Jack: 12V RTC Battery Lithium 3V/210mAH EMC CE,FCC,KC,TELEC Hardware Overview Part List ODYSSEY-X86i31125G4 x 1 User Manual x 1 Screwdriver x1 LEARN AND DOCUMENTS Learn High Performance Versions DC Jack: 12V-19V [Wiki] What is x86 Architecture and its difference between x64? Have you ever come across x86 and x64 but do not know what they mean? No worries, as this blog will cover everything you need to know about x86 and its architecture together with x64 and their differences between each other. [Wiki] Getting Started with BalenaOS on ODYSSEY - X86 Boards Some operations about BalenaOS on ODYSSEY - X86 Boards, including some basic information, installing steps, compiling code etc. https://www.seeedstudio.com/ODYSSEY-X86-v2-board-p-5075.html?queryID=77788bacdd977dbc6c9fcf7671823b9e&objectID=5075&indexName=bazaar_retailer_products/8-17-22
102110608 价格&库存
很抱歉,暂时无法提供与“102110608”相匹配的价格&库存,您可以联系我们找货
