317060015
317060015
    SEEED(矽递科技)
    SMD16模块
    ESP8266 BASED WIFI MODULE FCC/CE
317060015 数据手册
ESP-12E Brief Spec 规格修改记录(SPECIFICATION CHANGE HISTORY) 编号 修订日期 修订内容 修订者 1 2012-5-5 最初版本 Harri Approve 批准 Check 审核 Preparation 拟制 Date 日期 目录 Product Description ................................................................................................................................................................... 4 Description ........................................................................................................................................................................ 4 Features ............................................................................................................................................................................. 4 Applications ....................................................................................................................................................................... 4 Electrical performance .............................................................................................................................................................. 5 Digital IO Pads.................................................................................................................................................................... 5 Receiver Sensitivity ............................................................................................................................................................ 5 Current Consumption ........................................................................................................................................................ 6 Pin ...................................................................................................................................................................................... 6 BOOT Mode ....................................................................................................................................................................... 7 Reference Schematic ......................................................................................................................................................... 7 Reflow Profile .................................................................................................................................................................... 8 Mechanical Dimensions............................................................................................................................................................. 9 In Kind................................................................................................................................................................................ 9 Physical Dimensions ........................................................................................................................................................ 10 Product Description Description ESP-12E is a low power consumption of the UART-WiFi module, with very competitive prices in the industry and ultra low power consumption technology, designed specifically for mobile devices and IOT applications, user's physical device can be connected to a Wi-Fi wireless network, Internet or intranet communication and networking capabilities. ESP-07 the use of small ceramic antenna package can support IPEX interface. users have a variety of installation options. Features            ▪ 802.11 b/g/n protocol ▪ Wi-Fi Direct (P2P), soft-AP ▪ Integrated TCP/IP protocol stack ▪ +19.5dBm output power in 802.11b mode ▪ Power down leakage current of < 10uA ▪ Integrated low power 32-bit MCU ▪ SDIO 2.0, SPI, UART ▪ STBC, 1x1 MIMO, 2x1 MIMO ▪ A-MPDU & A-MSDU aggregation & 0.4μs guard interval ▪ Wake up and transmit packets in < 2ms ▪ Standby power consumption of < 1.0mW (DTIM3) Applications           Smart power plugs Home automation Mesh network Industrial wireless control Baby monitors IP Cameras Sensor networks Wi-Fi location-aware devices Security ID tags Wi-Fi position system beacons Electrical performance Digital IO Pads Parameter InputLow voltage InputHighVoltage InputLeakageCurrent OutputLowVoltage OutputHighVoltage InputPinCapacitance VDDIO MaximumDriveCapability Temperature Symbol Vil Vih Iil Vol Voh Cpad Vio Imax Tamb Min -0.3 0.75xVio Max 0.25xViO 3.3 50 0.1 xVio Unit V V nA V V pF V mA °C 0.8xVio 5 3.3 12 125 1.8 -40 Receiver Sensitivity Description Input frequency MIN Typical 2412 MAX 2484 50 Input impedance Input reflection Unit MHz Ω -10 dB Output power of PA for 72.2Mbps 14 15 16 dBm Output power of PA for 11b mode 17.5 18.5 19.5 dBm Sensitivity CCK 1Mbps -98 dBm CCK 11Mbps -91 dBm 6Mbps(1/2BPSK) -93 dBm 54Mbps(3/4 64-QAM) -75 dBm HT20,MCS7(65Mbps,72.2Mbps) -71 dBm OFDM,6Mbps 37 dB OFDM,54Mbps 21 dB HT20,MCS0 37 dB HT20,MCS7 20 dB Adjacent Channel Rejection Current Consumption Mode MIN Typical MAX Unit Send 802.11b,CCK 1Mbps,Pout=+19.5dBm 215 mA Send 802.11b,CCK 11Mbps,Pout=+18.5dBm 197 mA Send 802.11g,OFDM54 Mbps,Pout=+16dBm 145 mA Send 802.11n,MCS7,Pout=+14dBm 135 mA Receive 802.11b,Length 1024 Byte,-80dBm 100 mA Receive 802.11g,Length 1024 Byte,-70dBm 100 mA Receive 802.11n,Length 1024 Byte,-65dBm 102 mA Standby 70 mA Power Down 0.5 μA PIN Function Description 1 RST 1)Reset Pin. Active low; 2)NC Or External MCU control ; 2 ADC/TOUT 1)10-bit ADC Analog Input 0-1V; 3 EN 1)Module Enable. Active HIGH 4 GPIO16 1)GPIO (WEAK UP) 5 GPIO14 1)GPIO 6 GPIO12 1)GPIO 7 GPIO13 1)GPIO 2)UART2 RXD 8 VDD 1) Power supply . 3.3V IN; 9 10 CS0 MISO 1 ) Chip selection of SPI interface. 11 GPIO9 1 ) GPIO (Only available on ESP-12-D) 12 GPIO10- 1 ) GPIO (Only available on ESP-12-D) 13 MOSI 1 ) MOSI of SPI interface. 14 SCLK 1 ) Clock of SPI interface. 15 CND 1 ) Power Ground 16 GPIO15 1)GPIO 2)UART2 TXD 17 GPIO2 1)GPIO 2 ) WIFI status. Connection inside the module LED 18 GPIO0 1)GPIO 19 GPIO4 1)GPIO 20 GPIO5 1)GPIO 21 RXD0 1)UART0 RXD 22 TXD0 1)UART0 TXD 1 ) MISO of SPI interface. BOOT Mode GPIO15 GPIO0 GPIO2 1 X X SDIO/SPI WIFI 0 0 1 UART Download 0 1 1 Flash BOOT Reference Schematic Reßow Profile Refer to IPC/JEDEC standard; Peak Temperature :
317060015
物料型号:ESP-12E
器件简介:ESP-12E是一款低功耗的UART-WiFi模块,具有行业竞争力的价格和超低功耗技术,专为移动设备和物联网应用设计。用户可以将其物理设备连接到Wi-Fi无线网络,实现互联网或局域网的通信和联网能力。
引脚分配:ESP-12E模块具有22个引脚,包括电源、复位、模块使能、GPIO(通用输入输出)引脚、SPI接口引脚等。
参数特性:包括输入低电压、输入高电压、输入漏电流、输出低电压、输出高电压、输入引脚电容、VDDIO电压、最大驱动能力、工作温度范围等。
功能详解:ESP-12E支持802.11 b/g/n协议、Wi-Fi Direct (P2P)、软AP、集成TCP/IP协议栈、+19.5dBm的输出功率、待机功耗小于1.0mW等。
应用信息:适用于智能插座、家庭自动化、Mesh网络、工业无线控制、婴儿监视器、IP摄像头、传感器网络、Wi-Fi定位设备、安全ID标签、Wi-Fi定位系统信标等。
封装信息:提供了机械尺寸和物理尺寸的详细信息。
317060015 价格&库存
很抱歉,暂时无法提供与“317060015”相匹配的价格&库存,您可以联系我们找货
