102110559
102110559
    SEEED(矽递科技)
    Edge Server ODYSSEY X86
102110559 数据手册
Getting Started with reServer reServer, as a milestone product of reThings family, is extremely compact and powerful. This smart tiny server is able to work easily and efficiently from the edge to the cloud. reServer is based on an ODYSSEY X86 v2 board and powered by the latest Intel® Core™ 11th Gen. processor and Intel® UHD Graphics or Intel® Iris Xe Graphics, which delivers high CPU and AI performance for various applications. It has two high-speed 2.5-Gigabit Ethernet ports and supports hybrid connectivity including 5G, LoRa, BLE and WiFi. Meanwhile, reServer is of compact design to work efficiently in almost any scenario. The neat structure of reServer also makes it simple to access to the hard drives, memory and PCIe slots which allows easy installation, upgrades and maintenance. Having dual SATA III 6.0Gbps data connectors, reServer is able to equip up to two 3.5"/2.5" SATA internal hard disk drives to acquire more storage. It also has M.2 connectors to connect to various SSDs for faster read and write speeds. Features • Compact design for a server with an overall dimension of 132mm x124mm x233mm • Powered by the latest 11th Gen Intel® Core™ CPU and Intel® UHD Graphics or Intel® Iris Xe Graphics. • Rich peripherals including dual® 2.5-Gigabit Ethernet ports, USB 3.2 Type-A port, USB 2.0 Type-A port, HDMI port and DP port • Support hybrid connectivity including 5G, LoRa, BLE and WiFi (5G and LoRa need additional modules) • Dual SATA III 6.0 Gbps data connectors for 3.5"/2.5" SATA hard disk drives with enough space inside the enclosure to store them both • M.2 B-Key/ M-Key/ E-Key for expandability such as SSD, 4G/5G modules, WiFi 6 • Quiet cooling fan with a large VC heat sink for excellent heat dissipation • Easy to install, upgrade and maintain with ease of access to the internal components after opening the enclosure Pre-installed Windows 10 Enterprise(Unactivated), also support other Windows OS and Linux OS Specifications • Versions Platform Processor Basic Versions High Performance Versions Intel® Intel® Intel® Core™ Core™ Core™ 11th Gen. 11th Gen. 11th Gen. i3 1115G4 i3 1125G4 i5 1135G7 Intel® Intel® Core™ vPro® 11th Gen. Core™ i7 1185GRE vPro® 11th Gen. i5 1145GRE Cores/Threads 2C/4T of processor 4C/8T 4C/8T 4C/8T 4C/8T Versions Basic Versions High Performance Versions Co-processor Microchip® ATSAMD21G18 32- Raspberry Pi® RP2040 32-Bit Dual ARM Bit ARM® Cortex-M0+ @ 48MHz Cortex-M0+ @ 133MHz Memory Technology Dual Channels DDR4-3200 Capacity 8GB; 16GB (Support up to 64GB) Support up to 64GB ECC Memory NO Supported Graphics Controller YES Intel® Intel® Intel® Iris Intel® Iris Intel® Iris Xe Graphics G7 UHD UHD Xe Xe 96EUs(400-1300MHz) Graphics Graphics Graphics Graphics 48EUs 48EUs G7 G7 (400 (400 80EUs(400- 80EUs(4001250MHz) 1250MHz) 1300MHz) 1300MHz) Advanced Intel® vPro® Technologies NO YES Intel® Total Memory Encryption NO YES Network Controller Intel® Ethernet Controller I225-V Intel® Ethernet Controller I225-LM Wireless WiFi M.2 E-Key(PCIE & CNVi Support), Intel® Wi-Fi 6 AX201(Optional) Bluetooth Bluetooth 5.0, BLE(Optional) LCD eDP 40-Pin 4 Lane Connector HDMI 1 x HDMI 2.0b, up to 4Kx2Kx24bpp@60Hz DP 1 x DP1.4a 7680x4320x24bpp@60Hz Multiple Display 4 simultaneous displays with each display interface combination Display External I/O Ethernet HDMI/DP 2 x 2.5GbE LAN ports (RJ45, supports 10/100/1000/2500 Mbps), Intel® i225 One/One Versions Basic Versions High Performance Versions USB Type-C N/A USB PD / USB 4.0 / Thunderbolt 4 USB Type-A USB2.0 Type A x1 ; USB3.2 Type USB2.0 Type A x2 ; USB3.2 Type A x1 A x1 LED Power Status Power Supply 1x5.5x2.5mm DC Jack / Wafer 2.0mm 8pin Micro Sim Card Slot Internal I/O SATA Expansion Power 1 2 x SATA Gen III 6.0 Gb/s Data Connectors + 3 x SATA Power Connectors COM Port 1 x RS-232/422/485, 1 x RS-232 GPIO 28-Pin Arduino Co-processor 2.54mm header Audio Realtek High Definition Audio, Microphone + headphone Combo Connector USB2.0 USB2.0 9-pin Header x2 480Mbps Fan 2 x 12V 4-wire Fan header, PWM Control Front Panel Control Power-on, Reset, Power Status LED, SATA Status LED S/PDIF 3-Pin 2.54mm Header SATA Power WAFER4-Pin 2.0 pitch Connector Co-CPU. Debug Port 6-Pin 0.5mm FPC Connector (SWD) M.2 M-Key 1 x M-Key 2242/2280(PCIe 3.0 x4) M.2 E-Key 1 x E-Key 2230(PCIe 3.0 x1; USB2.0 x1;Intel CNVi) M.2 B-Key 1 x B-Key2242/2252/2280(PCIe 3.0 x2; USB2.0 x1) High Speed I/O 1 X PCIe x4 Gen4 1 X PCIe 3.0 x4/SMBus/LPC/USB 2.0/CPU GPIO etc. Supply Voltage DC Jack: 12V DC Jack: 12V-19V 30-Pin Raspberry Pi Co-processor 2.54mm header Versions Basic Versions RTC Battery High Performance Versions Lithium 3V/210mAH Certification EMC CE,FCC,TELEC Mechanical Dimension 132mm*124mm*233mm Thermal Solution Heat Pipe Assemblies/Heat Spreading Vapor Chamber Assemblies Weight 1800g Comparison Version Basic Versions High Performance Versions Appearance Processor Intel® Core™ 11th Gen. i3 1115G4 Intel® Core™ 11th Gen. i3 1125G4 Intel® Core™ 11th Gen. i5 1135G7 Intel® Core™ Intel® Core™ vPro® 11th Gen. vPro® 11th Gen. i5 1145GRE i7 1185GRE Cores/Threads of processor 2C/4T 4C/8T 4C/8T 4C/8T Co-processor Microchip® ATSAMD21G18 32-Bit ARM® Cortex- Raspberry Pi® RP2040 32-Bit Dual M0+ @ 48MHz ARM Cortex-M0+ @ 133MHz Intel® vPro® NO YES Intel® Total Memory Encryption NO YES Graphics Intel® UHD Graphics 48EUs (400 1250MHz) Memory Dual Channels DDR4-3200(Support up to 64GB in total) ECC Memory Supported NO Intel® UHD Graphics 48EUs (400 1250MHz) Intel® Iris Xe Graphics G7 80EUs(4001300MHz) Intel® Iris Xe Graphics G7 80EUs(4001300MHz) YES 4C/8T Intel® Iris Xe Graphics G7 96EUs(4001300MHz) Version Basic Versions High Performance Versions Network Controller Intel® Ethernet Controller I225-V Intel® Ethernet Controller I225LM Expansion M.2 M-Key; M.2 B-Key; M.2 E-Key; 1 X PCIe x4 Gen4 M.2 M-Key; M.2 B-Key; M.2 EKey; 1 X PCIe 3.0 x4/SMBus/LPC/USB 2.0/CPU GPIO etc. External I/O USB Type-A(USB2.0 Type-A x1 ; USB3.2 Type-A USB Type-C(USB PD / USB 4.0 / x1); HDMI; DP; 2.5GbE LAN ports x2; Audio Jack; Thunderbolt 4); DC Jack(12V); USB Type-A(USB2.0 Type-A x2 ; USB3.2 Type-A x1); HDMI;DP; 2.5GbE LAN ports x2; Audio Jack; DC Jack(12V-19V); WirelessConnectivi WIFI, BLE and Support LTE/4G/5G/LoRaWAN ty Hardware Overview There are two different versions of reServer, Basic version and High performance version, which have different hardware configurations. Basic version High performance version Dimensions Both versions have the same dimensions. Quick Start with reServer If you want to get started with reServer in the fastest and easiest way, you can follow the guide below. Hardware Required You need to prepare the following hardware before getting started with reServer。 • reServer • Power Adapter(provided) • External monitor • HDMI/DP cable • Keyboard and Mouse Hardware Installation For this part, we will introduce how to install or replace some hardware inside reServer. If there are no needs for you, please skip it. You might follow the Assembly Guide Manual attached at the end of this page to access to the main board of reServer before reading this part. DDR4 Installation DDR4-3200MT/s has been pre-installed for all versions of reServer but you can also add a new DDR4 to the other channel or replace the pre-installed one with your own to expand memory. The dual-channel SO-DIMM slots support DDR43200MT/s up to 64GB in total. SSD Installation A NVMe SSD has been pre-installed for all versions of reServer, while, still, the M.2 M-Key 2242/2280(PCIe 3.0 x4) allows you to replace it with the SSD you desire. WiFi Module Installation All versions of reServer have installed 2230 Dual Band WiFi 6 AX201(CNVio) Module at M.2 E-Key 2242/2280(PCIe 3.0x4). If you want to replace the preinstalled WiFi Module, feel free to follow the steps below. • Step 1. Remove the SSD from M.2 M-Key slot. • Step 2. Take off the WiFi antenna cable and remove the pre-installed WiFi Module from M.2 E-Key. • Step 3. Install the new WiFi Module and connect the WiFi antenna cable back to it. • Step 4. Install the SSD back to M.2 M-Key. Note: reServer is shipped with two 2.⅘GHz WiFi Antennas, you can attach the antenna to the adapter which connects with the antenna cable of the WiFi module inside the reServer to achieve better WiFi connectivity. 4G/5G/LoRaWAN Module Installation reServer supports installing 4G/5G/LoRaWAN Module at M.2 B-Key 2242/2252/2280(PCIe 3.0 x2; USB2.0 x1). (4G/5G/LoRaWAN Module is not included in reServer) Please feel free to follow the steps to add 4G/5G/LoRaWAN Module. • Step 1. Install 4G/5G/LoRaWAN Module to M.2 B-Key. • Step 2. Connect the antenna cable to the Module. Note: You have to insert a standard SIM card into the micro SIM card slot to enable 5G/4G. HDD Installation reServer supports installing two 3.5"/2.5" internal hard disk drives to acquire more storage. (The HDDs are not included in reServer) Please follow the steps to install the HDDs. - Step 1. Remove the screws and pull out the brackets • Step 2. Attach the HHDs to the brackets with screws • Step 3. Push the HDD brackets down to connect the HHDs with the SATA ports. • Step 4. Fix the HDD brackets with screws Hardware Connection For this part, we will introduce the interface connection of reServer. There are two versions of reServer. Please note that different versions might have different interfaces. Display Connection There are three methods for reServer to connect to a display while the third method is only for High-performing versions. Method 1. HDMI Port、 Method 2. DP Port Method 3. USB Type-C(Available with High-performing versions only) Basic version High performance version Keyboard and Mouse Connection Connect keyboard and mouse through USB ports. There are one USB 3.2 port and one USB 2.0 port for Basic versions while there are one USB 3.2 port and two USB 2.0 ports for High-performing versions. Basic version High performance version Audio Connection For Basic versions, the Audio Jack is on the left side I/O panel, while, for Highperforming versions, it's on the right side I/O panel for High-performing versions Basic version High performance version Power Connection There are two methods to power up reServer, and the second one is only for High-performing versions. Method 1. Simply connect AC-DC power adapter(included in the product box) with AC power cord(Out of the product box but still in the package), then connect it to 12V DC Jack of reServer. Method 2. Connect USB Type-C charging cable(Not included in reServer) to the Thunderbolt 4 USB Type-C port(This port is only available with High-performing versions) Basic version High performance version Operation System Installation For all versions of reServer, Windows 10 Enterprise(Unactivated) has been preinstalled, you can simply boot it up and activate the OS. However, reServer still supports other Windows OS and, also, Linux OS, so you can cover the preinstalled OS with the one you want. Resources • [PDF] reServer Assembly Guide • [PDF] Atmel-SAMD21-datasheet Tech Support Please submit any technical issue into our forum. Getting Started with reServer - Seeed Wiki (seeedstudio.com)/5-2-22
102110559 价格&库存
很抱歉,暂时无法提供与“102110559”相匹配的价格&库存,您可以联系我们找货
