Grove - I2C Motor Driver (TB6612FNG)
The Grove - I2C Motor Driver (TB6612FNG) can drive two DC motors up to 12V/1.2A or
drive one stepper motor up to 12V/1.2A. With the on-board MCU, it can work with
Arduino easily via the Grove I2C interface.
This diver board is based on TB6612FNG, which is a driver IC for DC motor and
stepper motor with output transistor in LD MOS structure with low ON-resistor. Two
input signals, IN1 and IN2, can choose one of four modes such as CW, CCW, short
brake, and stop mode.
Features
On board MCU
CW/CCW/short brake/stop function modes
Built-in thermal shutdown circuit and low voltage detecting circuit
Standby (Power save) system
Specification
Item
Value
MCU Operating Voltage
3.3V / 5V
Motor Supply Voltage
2.5 ~ 13.5 (5V Typical, 15V Max.)
Output Current
1.2 A(ave)/3.2 A (peak)
Switching Frequency
100kHz
Logic Interface
I2C
I2C Address
0x14 (default)
I2C Address Range
0x01 ~ 0x7f (Configurable)
Typical applications
DC motor control
Stepper motor control
Hardware Overview
Pin Out
Hardware Detail
I2C Interface
This board uses the I2C interface to allow the on-board MCU to communicate with the
host computer.
GND: connect this module to the system GND
VCC: you can use 5V or 3.3V for this module
SDA: I2C serial data
SCL: I2C serial clock
Power In
Provide DC power to the motors, input range 2.5V ~ 13.5V.
GND: Connect to the system GND, plug the power "-"
VM: Plug the power "+", supply power for the motor.
DC Motor Output
This board has two channel DC Motor Output, it can output 12V/1.2A per channel. You
can use this driver board control two DC motors at the same time.
A1: Channel A output 1
A2: Channel A output 2
B1: Channel B output 1
B2: Channel B output 2
Steperp Motor Output
You can use this board to control the 4-wire stepper motor as well, it can output up to
12V/1.2A.
OUT1: Connected to one input of the stepper motor coil 1.
OUT2: Connected to the other input of the stepper motor coil 1.
OUT3: Connected to one input of the stepper motor coil 2.
OUT4: Connected to the other input of the stepper motor coil 2.
Note
Actually the DC port and the stepper port are physically connected together. The
connection diagram is as follows:
DC Port
Stepper Port
A1
OUT1
A2
OUT2
B1
OUT3
B2
OUT4
Platforms Supported
Arduino
Raspberry Pi
BeagleBone
Wio
LinkIt ONE
Caution
The platforms mentioned above as supported is/are an indication of the module's
hardware or theoritical compatibility. We only provide software library or code examples
for Arduino platform in most cases. It is not possible to provide software library / demo
code for all possible MCU platforms. Hence, users have to write their own software
library.
Getting Started
Play With Arduino
Hardware
Materials required
DC Motor Demo
Seeeduino V4.2
Base Shield
Grove ‐ I2C Motor Driver
(TB6612FNG)
DC Motor
Note
1 Please plug the USB cable gently, otherwise you may damage the port. Please use
the USB cable with 4 wires inside, the 2 wires cable can't transfer data. If you are not
sure about the wire you have, you can click here to buy
2 Each Grove module comes with a Grove cable when you buy. In case you lose the
Grove cable, you can click here to buy.
3 You also need prepare at least 2 jumpers, in case you do not have, you can
click here to buy.
Step 1. Plu the DC motor into the DC Motor Output port of the driver board, plug
the external DC power into the Power In port.
Step 2. Connect the Grove - I2C Motor Driver (TB6612FNG) to port I2C of GroveBase Shield.
Step 3. Plug Grove - Base Shield into Seeeduino.
Step 4. Connect Seeeduino to PC via a USB cable.
Stepper Motor Demo
Seeeduino V4.2
Base Shield
Grove ‐ I2C Motor Driver Stepper Motor
(TB6612FNG)
Step 1. Connect the stepper motor with Stepper Motor Output port of the driver board,
plug the external DC power into the Power In port.
Tip
This driver board is suitable for 4-wire stepper motors. Depending on the stepper motor
you use, the wiring color is different. We use the motor 24BYJ48 , the wiring is as
shown in the table below:
Pin Name
Wire of Stepper Motor
Wire color(24BYJ48)
OUT1
one end of coil 1
Orange
OUT2
the other end of coil 1
Blue
OUT3
one end of coil 2
Pink
OUT4
the other end of coil 2
Yellow
Note
Since the DC port and the stepper port are physically connected together, you can also
use the two DC port to control your stepper motor. The connection diagram is as
follows:
Note
If we don't have Grove Base Shield, We also can directly connect this module to
Seeeduino as below.
Seeeduino
Grove Cable Grove ‐ I2C Motor Driver (TB6612FNG)
GND
Black
GND
5V or 3.3V Red
VCC
SDA
White
SDA
SCL
Yellow
SCL
Software
Attention
If this is the first time you work with Arduino, we strongly recommend you to see Getting
Started with Arduinobefore the start.
Step 1. Download the Grove_Motor_Driver_TB6612FNG Library from Github.
Step 2. Refer to How to install library to install library for Arduino.
Step 3. Restart the Arduino IDE. Open the default example, we provide two
examples for you
dc_motor: Demo for DC motor
stepper_motor_2phase: Demo for 4-wire, 2phase stepper motor.
You can open them in the following two ways(take the dc_motor for example):
1. Open it directly in the Arduino IDE via the path: File → Examples → Grove - Motor
Driver(TB6612FNG) → dc_motor.
2. Open it in your computer by click the dc_motor.ino which you can find in the
folder XXXX\Arduino\libraries\Grove_Motor_Driver_TB6612FNG-
master\examples\dc_motor, XXXX is the location you installed the Arduino IDE.
Step 4. Upload the demo. If you do not know how to upload the code, please check How to
upload code.
Success
If every thing goes well, when you power up the external power port, the motor will run.
Tech Support
Please do not hesitate to submit the issue into our forum or drop mail
to techsupport@seeed.cc.
http://wiki.seeedstudio.com/Grove‐I2C_Motor_Driver‐TB6612FNG//12‐4‐18
很抱歉,暂时无法提供与“108020103”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+65.83277200+8.51648
