Grove - I2C UV Sensor (VEML6070)
The Grove - I2C UV Sensor(VEML6070) is an advanced ultraviolet (UV) light sensor
with I2C protocol interface. Ultraviolet (UV) is electromagnetic radiation with a
wavelength from 10 nm to 400 nm, shorter than that of visible light but longer than Xrays, this sensor detects 320-410nm light most effectively, and will converts solar UV
light intensity to digital data.
This module is based on VEML6070, which has linear sensitivity to solar UV light and is
easily adjusted by an external resistor.
What's more the active acknowledge (ACK) feature with threshold windows setting
allows the UV sensor to send out a UVI alert message. Under a strong solar UVI
condition, the smart ACK signal can be easily implemented by the software
programming.
Features
Excellent performance of UV radiation measurement under long time solar UV exposure
Excellent UV sensitivity and linearity
Excellent temperature compensation
High dynamic detection resolution
Support acknowledge feature (ACK)
Specification
Item
Value
Operating Voltage
3.3V / 5V
Range of spectral sensitivity
320 ~ 410 nm
Peak Sensitivity
355 nm
UVA Sensitivity
5 μW/cm2/step(typical)
Interface
I2C
I2C Address
0x38(Data LSB) / 0x39(Data MSB)
Attention
Actually, this sensor has 3 I2C address, each address
Typical applications
Solar UV indicator
Cosmetic / outdoor sport handheld product
Consumer products
Hardware Overview
Pin Out
Platforms Supported
Arduino
Raspberry Pi
BeagleBone
Wio
LinkIt ONE
Caution
The platforms mentioned above as supported is/are an indication of the module's
hardware or theoritical compatibility. We only provide software library or code examples
for Arduino platform in most cases. It is not possible to provide software library / demo
code for all possible MCU platforms. Hence, users have to write their own software
library.
Getting Started
Play With Arduino
Hardware
Materials required
Seeeduino V4.2
Base Shield
Grove ‐ I2C UV Sensor (VEML6070)
Note
1 Please plug the USB cable gently, otherwise you may damage the port. Please use
the USB cable with 4 wires inside, the 2 wires cable can't transfer data. If you are not
sure about the wire you have, you can click here to buy
2 Each Grove module comes with a Grove cable when you buy. In case you lose the
Grove cable, you can click here to buy.
Step 1. Connect the Grove - I2C UV Sensor (VEML6070) to port I2C of Grove-Base
Shield.
Step 2. Plug Grove - Base Shield into Seeeduino.
Step 3. Connect Seeeduino to PC via a USB cable.
Note
If we don't have Grove Base Shield, We also can directly connect this module to
Seeeduino as below.
Seeeduino
Grove Cable
GND
Black
GND
5V or 3.3V
Red
VCC
SDA
White
SDA
SCL
Yellow
SCL
Software
Attention
If this is the first time you work with Arduino, we strongly recommend you to see Getting
Started with Arduinobefore the start.
Step 1. Download the Seeed_VEML6070 Library from Github.
Step 2. Refer to How to install library to install library for Arduino.
Step 3. Restart the Arduino IDE. Open the example, you can open it in the following
three ways:
a. Open it directly in the Arduino IDE via the path: File → Examples →
Seeed_VEML6070 → INT_mode.
b. Open it in your computer by click the INT_mode.ino which you can find in the
folder XXXX\Arduino\libraries\Seeed_VEML6070master\examples\INT_mode, XXXX is the location you installed the Arduino
IDE.
c. Or, you can just click the icon
in upper right corner of the code block to copy
the following code into a new sketch in the Arduino IDE.
1 #include "Seeed_VEML6070.h"
2
3
4 /*SAMD core*/
5 #ifdef ARDUINO_SAMD_VARIANT_COMPLIANCE
6 #define SERIAL SerialUSB
7 #else
8 #define SERIAL Serial
9 #endif
10
11 VEML6070 sensor;
12
13 char *UV_str[]={"low level","moderate level","high_level","very high","extreme"};
14
15 err_t read_UV()
16 {
17 err_t ret=NO_ERROR;
18 u16 step;
19 sensor.wait_for_ready();
20 CHECK_RESULT(ret,sensor.read_step(step));
21 SERIAL.print("UV step = ");
22 SERIAL.println(step);
23 RISK_LEVEL level=sensor.convert_to_risk_level(step);
24 SERIAL.print("UV level is ");
25 SERIAL.println(UV_str[level]);
26 SERIAL.println(" ");
27 SERIAL.println(" ");
28 SERIAL.println(" ");
29 return ret;
30 }
31
32
33
34 void setup()
35 {
36 SERIAL.begin(115200);
37 delay(10);
38 SERIAL.println("serial start!!");
39 delay(1000);
40 if(sensor.init())
41 {
SERIAL.println("init failed!!!");
42
43 }
44 /*threshold is 145 steps*/
45 /*enable*/
46 sensor.set_interrupt(INT_145_STEP,ENABLE);
47 }
48
49
50 void loop()
51 {
52 if(read_UV())
53 {
SERIAL.print("read UV sensor failed!!");
54
55 }
56 //sensor.enable();
57 //sensor.disable();
58 delay(1000);
59 }
Note
There are 2 demos in the library:
basic_demo.ino
This example can get the UV index and UV level from the serial.polling for data.
INT_mode.ino
here is a INT pad on the sensor module which connect to ACK pin of VEML6070. You
can set UV threshold by 102 steps or 145 steps(only two choises).The INT pin outputs
low when the UV value beyond limit.You can attach INT pin to a interrupt pin of host,To
improve the efficiency of program operation.
Attention
The library file may be updated. This code may not be applicable to the updated library
file, so we recommend that you use the first two methods.
Step 4. Upload the demo. If you do not know how to upload the code, please
check How to upload code.
Step 5. Open the Serial Monitor of Arduino IDE by click Tool-> Serial Monitor. Or
tap the Ctrl + Shift + M key at the same time. Set the baud rate to 115200.
Success
If every thing goes well, when you use UV light to illuminate this module, you will see
information like:
1 4serial start!!
2 cmd reg=32
3 UV step = 20
4 UV level is low level
5
6
7
8 UV step = 125
9 UV level is low level
10
11
12
13 UV step = 511
14 UV level is low level
Alert Function
As we can see in the hardware Overview part, there is a ACK pin for user to work as a
interrupt signal. The good news is that there are two threshold 102 step and 145 step to
choose, the bad one is that you can not set your own number, only 102 and 145 are
valid. The ACK pin default output low, once the UV value exceed the threshold you
setted, the ACK pin output High. Let's come back to the example code INT_mode.ino.
Line 46, the default setting of threshold is 145, if you want to use the 102, you should
just change the code as below:
1sensor.set_interrupt(INT_145_STEP,ENABLE);
1sensor.set_interrupt(INT_102_STEP,ENABLE);
Project
This is the introduction Video of this product, simple demos, you can have a try.
Tech Support
Please do not hesitate to submit the issue into our forum
http://wiki.seeedstudio.com/Grove‐I2C_UV_Sensor‐VEML6070/ 11‐5‐18
很抱歉,暂时无法提供与“101020600”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+52.8763610000+6.84843
