RF Explorer ISM Combo PLUS
RF Explorer ISM COMBO+ is a powerful, high performance digital spectrum analyzer covering the
1GHz frequency range starting at 50KHz, and 2.35GHZ to 2.55GHz for scanning the popular
2.4GHz band.
The new SLIM design offers an outstanding robust enclosure, a more convenient USB connector on
the side and larger internal battery capacity.
Compared to the baseline ISM COMBO model, the new PLUS includes a higher frequency range in
the sub-1GHz band, more sensitivity and higher RF Generator power output in the 2.4GHz band.
Features
Internal LNA amplifier and selectable attenuator in the sub-1GHz band.
Low frequency support from 50KHz covering LF, MF, HF, VHF and UHF up to 960Mhz
High frequency support for 2.4GHz band starting at 2.35GHz and covering up to 2.55GHz.
New HELP and SET buttons to improve user interface and configuration selection with 2clicks
Excellent performance to diagnose and generate signals in the 2.4GHz ISM band.
Wide band coverage to all popular sub-1Ghz bands, including FM, TV and DTV, ISM, RFID,
GSM, etc.
Ideal choice for HAM bands from 160meters to 33cm.
Pocket size and light weight
Solid metal case
Spectrum Analyzer mode with Peak Max and Hold, Normal, Overwrite and Averaging modes
High capacity internal Lithium battery for 20hs+ of continuous run, rechargeable by USB
Multi-platform Windows/Linux/MacOS Open Source software and API libraries
Specification
Frequency band:
o Left connector: 0.05 – 960MHz
o Right connector: 2350 – 2550MHz
Frequency span:
o Left connector: 0.1 – 960MHz
o Right connector: 2 – 85MHz
Internal selectable LNA 25dB gain with the left connector
Internal selectable Attenuator 30dB with the left connector
Signal generator covering up to +11dBm output power with the right connector.
Wifi Analyzer for the 2.4GHz band
Graphics LCD 128x64 pixels, great visibility outdoors
Support included for Windows, Linux and MacOS X
Backlight for great visibility indoor
Internal Lithium Ion 1800mA/h rechargeable battery
Standard SMA 50 ohms connector
Wideband 144/433MHz dual band telescopic antenna included
UHF 400-900MHz rubber duck articulated antenna included
2.4GHz whip antenna included
Amplitude resolution: 0.5dBm
Dynamic range: -125dBm to 10dBm
Absolute Max input power: +30dBm
Average noise level (typical LNA): -125dBm
Frequency stability and accuracy (typical): +-10ppm
Amplitude stability and accuracy (typical): +-2dBm
Frequency resolution: 1Khz
Resolution bandwidth (RBW): automatic 2.6Khz to 600Khz
Note: RF Explorer is a very sensitive spectrum analyzer, specially designed to detect signals with
aerial antenna. For extra protection when connecting the analyzer to a signal source with a coaxial
cable, we suggest using a RF Explorer Power Limiter. More details at www.rfexplorer.com/PLIMITER
Part List
1 x Spectrum Analyzer
1 x Mini USB cable
1 x Dual band 144/430MHz Telescopic antenna
1 x UHF 400-900Mhz antenna
1 x 2.4GHz whip antenna
1 x EVA case
http://j3.rf‐explorer.com/60‐rfe/specifications/227‐rf‐explorer‐ism‐combo‐plus
https://www.seeedstudio.com/RF‐Explorer‐ISM‐Combo‐PLUS‐Slim‐p‐4162.html/9‐16‐19
很抱歉,暂时无法提供与“114991829”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2107.909821+273.06012
