RF Transmitter and Receiver Link Kit 315MHz/433MHz
This is an ultra-long-distance 315MHz or 433MHz radio frequency link set, with VCO and
PLL technology, stable frequency and strong anti-interference ability. You can directly use
it for your projects, such as wireless data transmission and remote control.
Features
Low power consumption: 5V about 6.0mA / 3.3V about 5mA
High receiving sensitivity: -110dBm@10kbps
Long emission distance: 2km(Open area without interference)
Wide temperature range: -20~75℃
Flexible application,breadboard and PCB friendly
Strong radiation suppression ability:no mutual interference, no influence on receiving
distance.
Specifications
Parameter
Value/Range
Operating voltage
Transmitter(3-9V),Receiver(3-5V)
Working current
50mA(9VDC)
Principle of work
Superhet(VCO, PLL)
Modulation
OOK/ASK
Working band
315MHz ; 433.92MHz (customize service available)
Operation Temperature
-20℃ to +75℃
Bandwidth
200KHZ
Sensitivity
-110dBm (50Ω)
Modulation rate
<10Kbps
Decoding form
PT2272
Antenna length
18cm(Tx)、24cm (Rx)
Emission Distance
2KM(Open area without interference)
Working Output Modes
Unlocked, interlocked, self-locked
Application Ideas
Automobile remote control door switch
Remote control door opener
Wireless security alarm
Remote control curtain machine
Wireless industrial controller
Wireless data transmission
Wireless remote control model
Wireless toys control
Hardware Overview
1.Transmitter-Pin interface: 7PIN (pitch: 2.54mm) 2.Receiver-Pin interface: 7PIN (pitch:
2.54mm) 3.Transmitting antenna(Antenna should be straightened during usage.) 4.Spring
receiving antenna
Getting Started
Here, we will use an RF transceiver kit, an LED, a switch button, a development board to
provide power, and some wires to achieve a simple demo of wireless control LED on and
off.
Step 1. Prepare RF transceiver kit, wires, breadboards or development boards, and
other components related to the functions you want to implement.
Take our simple wireless lighting control demo as an example, we will use:
Name
Value
RF transceiver kit
*1
Breadboards
*1
LED
*1
Key switch
*1
Seeeduino XIAO
*1
Wires
Some
Step 2. Follow the instructions below to connect the circuit system.
Note: All signal ports are used in the diagram below, but the actual circuit connection we
give uss only one port.
Connection diagram
Actual circuit connection diagram
Note: In this RF wireless lighting control demo, we use the development board Seeeduino
XIAO (3.3V output) as the common power supply system, and build the transmitting
module and receiving module on the same board. In practice, the remote transceiver
module is usually powered by their own power supply. For example, you can directly use
battery pack power supply.
Step 3. To supply power to the system, press the button switch.
Note: You can change the LED light in the RF wireless light control Demo to the object you
want to control, and use multiple signal ports to achieve wireless control of a variety of
signal systems.
You can also use the Seeedino XIAO in the demo to achieve more functions, such as
connecting a light sensor to make the light go on and off and the brightness of the light be
controlled wirelessly according to the intensity of the light. This process can send signals
without manual operation.
Resources
[Datasheet] Datasheet for PT2272 and PT2262
Tech Support
Please submit any technical issue into our forum.
https://wiki.seeedstudio.com/RF-Transmitter-and-Receiver-Link-Kit-315MHz-433MHz//8-17-22
很抱歉,暂时无法提供与“114992732”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+149.589691+19.40914
