101020634
101020634
    SEEED(矽递科技)
    SCD30 二氧化碳(CO2),湿度,温度 传感器 Grove 平台评估扩展板
101020634 数据手册
Grove - CO2 & Temperature & Humidity Sensor (SCD30) The Grove - CO2 & Temperature & Humidity Sensor (SCD30) is a high precision carbon dioxide sensor, which is based on Sensirion SCD30. The measuring range of this sensor is 0 ppm-40'000 ppm, and the measurement accuracy can reach to ±(30 ppm + 3%) between 400ppm to 10'000ppm. In addition to the Non-Dispersive Infrared(NDIR) measurement technology for CO2 detection, the SCD30 integrates Sensirion humidity and temperature sensors on the same sensor module. Tip We've released the Seeed Gas Sensor Selection Guide, it will help you choose the gas sensor that best suits your needs. Application Ideas • Air Purifier • Environmental Monitoring • Plant Environmental Monitoring Feature • NDIR CO2 sensor technology • Integrated temperature and humidity sensor • Best performance-to-price ratio • Dual-channel detection for superior stability • Digital interface I2C • Low power consumption • Ultra-long sensor lifetime (15 years) Specification Parameter Value Supply voltage 3.3V / 5V Operating temperature 0 – 50℃ Storage temperature - 40°C – 70°C Humidity operating conditions 0 – 95 %RH Sensor lifetime 15 years Interface I2C I2C Address 0x61 Table 1.General Specification Parameter Conditions CO2 measurement range Value 0 – 40’000 ppm Accuracy 400ppm – 10'000ppm ± (30 ppm + 3%) Repeatability 400ppm – 10'000ppm 10ppm Response time τ63% 20 s Table 2.CO2 Sensor Specifications Parameter Conditions Humidity measurement range Value 0 %RH – 100 %RH Accuracy 0 – 50°C, 0 – 100%RH Repeatability ±2 %RH 0.1 %RH Response time τ63% 8s Table 3.Humidity Sensor Specifications Parameter Conditions Temperature measurement range Value -40°C – 120°C Accuracy 0 – 50°C Repeatability ±0.5°C 0.1°C Response time τ63% >2s Table 4.Temperature Sensor Specifications Parameter Conditions Value Average current Update interval 2 s 19 mA Max. current During measurement 75 mA Energy consumption 1 measurement 120 mJ Table 5.Electrical Specifications Hardware Overview Platforms Supported Arduino Getting Started Play With Arduino Hardware Raspberry Pi BeagleBone Wio LinkIt ONE Materials required Seeeduino V4.2 Base Shield Grove-CO2 & T&H SCD30 In addition, you can consider our new Seeeduino Lotus M0+, which is equivalent to the combination of Seeeduino V4.2 and Baseshield. Note 1 Please plug the USB cable gently, otherwise you may damage the port. Please use the USB cable with 4 wires inside, the 2 wires cable can't transfer data. If you are not sure about the wire you have, you can click here to buy 2 Each Grove module comes with a Grove cable when you buy. In case you lose the Grove cable, you can click here to buy. Hardware Connection • Step 1. Connect the Grove - CO2 & Temperature & Humidity Sensor (SCD30) to the I2C port of the Base Shield. • Step 2. Plug Grove - Base Shield into Seeeduino. • Step 3. Connect Seeeduino to PC via a USB cable. Software Attention If this is the first time you work with Arduino, we strongly recommend you to see Getting Started with Arduinobefore the start. • Step 1. Download the Grove Multi Switch Library from Github. • Step 2. Refer to How to install library to install library for Arduino. • Step 3. Restart the Arduino IDE. Open the example, you can open it in the following three ways: a. Open it directly in the Arduino IDE via the path: File → Examples →Grove_scd30_co2_sensor→SCD30_Example. b. Open it in your computer by click the SCD30_Example.ino which you can find in the folder XXXX\Arduino\libraries\Seeed_SCD30master\examples\SCD30_Example, XXXX is the location you installed the Arduino IDE. c. Or, you can just click the icon in upper right corner of the code block to copy the following code into a new sketch in the Arduino IDE. 1#include "SCD30.h" 2 3#if defined(ARDUINO_ARCH_AVR) #pragma message("Defined architecture for ARDUINO_ARCH_AVR.") 4 #define SERIAL Serial 5 6#elif defined(ARDUINO_ARCH_SAM) #pragma message("Defined architecture for ARDUINO_ARCH_SAM.") 7 #define SERIAL SerialUSB 8 9#elif defined(ARDUINO_ARCH_SAMD) #pragma message("Defined architecture for ARDUINO_ARCH_SAMD.") 10 #define SERIAL SerialUSB 11 12#elif defined(ARDUINO_ARCH_STM32F4) #pragma message("Defined architecture for ARDUINO_ARCH_STM32F4.") 13 #define SERIAL SerialUSB 14 15#else #pragma message("Not found any architecture.") 16 #define SERIAL Serial 17 18#endif 19 20 21 22void setup() 23{ Wire.begin(); 24 SERIAL.begin(115200); 25 SERIAL.println("SCD30 Raw Data"); 26 scd30.initialize(); 27 28} 29 30void loop() 31{ float result[3] = {0}; 32 33 if(scd30.isAvailable()) 34 { 35 scd30.getCarbonDioxideConcentration(result); 36 SERIAL.print("Carbon Dioxide Concentration is: "); 37 SERIAL.print(result[0]); 38 SERIAL.println(" ppm"); 39 SERIAL.println(" "); 40 SERIAL.print("Temperature = "); 41 SERIAL.print(result[1]); 42 SERIAL.println(" ℃"); 43 SERIAL.println(" "); 44 SERIAL.print("Humidity = "); 45 SERIAL.print(result[2]); 46 SERIAL.println(" %"); 47 SERIAL.println(" "); 48 SERIAL.println(" "); 49 SERIAL.println(" "); 50 } 51 52 delay(2000); 53 54} Attention The library file may be updated. This code may not be applicable to the updated library file, so we recommend that you use the first two methods. • Step 4. Upload the demo. If you do not know how to upload the code, please check How to upload code. Success If everything goes well, the raw data of the Grove - CO2 & Temperature & Humidity Sensor (SCD30) should be able to read from Serial Monitor. Calibration and Placement In order to get more accurate results in a practical scenario, you need to pay attention to the following two points: • a. The correct placement • a. Calibration Placement Please refer to the SCD30 Design-In Guidelines for the correct placement. Calibration When activated for the first time a period of minimum 7 days is needed so that the algorithm can find its initial parameter set for ASC. The sensor has to be exposed to fresh air for at least 1 hour every day. Also during that period, the sensor may not be disconnected from the power supply, otherwise the procedure to find calibration parameters is aborted and has to be restarted from the beginning. The successfully calculated parameters are stored in non-volatile memory of the SCD30 having the effect that after a restart the previously found parameters for ASC are still present. For more detail about the calibration, please refer to the Interface Description Sensirion SCD30 Sensor Module There are two ino sample in the SCD30 library foldor, you can run the SCD30_auto_calibration.ino to start the calibration. Resources • [ZIP] Grove - CO2 & Temperature & Humidity Sensor (SCD30) Schematic file • [PDF] SCD30 Design-In Guideline • [PDF] SCD30 Datasheet • [PDF] SCD30 Interface Description Tech Support Please submit any technical issue into our forum or drop mail to techsupport@seeed.cc http://wiki.seeedstudio.com/Grove-CO2_Temperature_Humidity_Sensor-SCD30//4-19-19
101020634 价格&库存
很抱歉,暂时无法提供与“101020634”相匹配的价格&库存,您可以联系我们找货
  • 1+460.94767
库存:110
