110991190
110991190
    SEEED(矽递科技)
    K210 Sipeed MAix BiT Kit RISCV AI+IoT - RISC-V MPU 评估板 - 嵌入式
110991190 数据手册
Sipeed Maix-BIT Specifications v2.0 Datesheet Characteristic: · CPU : RISC-V Dual Core 64bit, with FPU,400Mhz standard Frequence(Can be overclocked) · 24P DVP connector · 24P 8bit MCU LCD connector · MEMS microphone : MSM261S4030H0 Seneitivity : -26(dB,dBFS @1kHz 1Pa) · Compact size: 53.3*25.4mm Can be connected to the breadboard directly · Download circuit: Just connect the USB typeC cable to complete the download Version 2.0 Sipeed · Onboard component: Copyright © 2019 RGB LED \ RST button and USR www.sipeed.com button \ MicroSD card(TF card) slot www.sipeed.com Sipeed Maix-BIT Specifications v2.0 Update record Edited on February 28, 2019 ; Original V1.0 document 1、Added MEMS microphone 2、CH340 was changed to CH552 3、24P connectors(Front lock) were changed to 24P connectors(rear lock) V2.0 (PCB was changed) 4、Added two LEDs to display serial state Added the website of Sipeed model shop Updated “Overall description” Updated the picture of Outlook information FEATURES OVERVIEW Powerful dual-core 64-bit open architecture-based CPU : RISC-V Dual Core 64bit, 400Mh adjustable processor with rich community resources Debugging Support UART and JTAG interface for debugging GPIO interface All GPIOs were connected to 2.54mm pin header and pads Micro SD card(TF card) slot Support Self-elastic card holder Just connect the USB typeC cable to complete the download One-click Download circuit Onborad CH552T, which support Baudrate 1.5Mbps/750kbps/375kbps/187.5kbps/115200 bps and below DVP Camera connector 24P 0.5mm FPC connector LCD connector 8bit MCU LCD 24P 0.5mm FPC connector Button RST button and USR button MSM261S4030H0 is an omnidirectional, Bottom-ported, I 2 S digital output MEMS Onboard MEMS microphone Microphone. It has high performance and Reliability. SOFTWARE FEATURES FreeRtos & Standard SDK Support FreeRtos and Standrad development kit. MicroPython Support Support MicroPython on M1 Machine vision Machine vision based on convolutional neural network Machine hearing High performance microphone array processor Sipeed Technology 2/6 Sipeed Maix-BIT Specifications v2.0 HARDWARE FEATURES Supply voltage of external power supply 4.8V ~ 5.2V Supply current of external power supply >600mA Temperature rise
110991190 价格&库存
很抱歉,暂时无法提供与“110991190”相匹配的价格&库存,您可以联系我们找货
