S204SP
S204SP
    SEEKTHERMAL
    模块
    热敏式 图像传感器 200H x 150V 12µm x 12µm 模块
S204SP 数据手册
Core Number: C204SP Product Specifications: Microbolometer Pixel Pitch Spectral Response Sensor Resolution (Array Format) Frame Rate Non-Uniformity Correction (NUC) Video Output Interfaces Power: Power Requirment Optical & Mechanical: Focal Length F-number (Focal Length/aperture) Spatial Resolution (IFOV, center) Field of View (FOV) Detection Range Recognition Range Identification Range Distance to Spot Ratio Core Size / Core Weight Seek Software Development Kit: Supported Platforms Output Formates (User selectable) Imaging Specifications: Imaging Range Thermography Accuracy Sensor Sensitivity Emmissivity Environmental Conditions: Operating Temperature Range Storage Temperature Range Solar Protection Humidity Regulatory Accessories: Cushion Bracket Sensor Flex Coprocessor Board USB Flex Customer Responsibilities: IP Rating Shock/Vibe Copyright 2021 Seek Thermal Inc. Mosaic Core Specification Starter Kit Number: S204SP Mktg Rev. 3 Description Uncooled Vanadium Oxide 12 Microns 7.8 - 14 Microns 200 (h) x 150 (v); 30,000 pixels Slow Frame - 120 TO 400 ±0.3 [.012] ANGLES ±1° 3. COPROCESSOR BOARD AND FLEX INCLUDED WITH "P" OPTION CORES. 7 SEE NOTES FINISH UNLESS OTHERWISE SPECIFIED: ADHESIVE BUMP PRESENT ON
S204SP 价格&库存
很抱歉,暂时无法提供与“S204SP”相匹配的价格&库存,您可以联系我们找货
