5.16.02 FLASHER PORTABLE PLUS
    SEGGERMICROCONTROLLERSYSTEMS
    ARM®,Cortex®,PowerPC,RX - 编程器(在线/在系统)
5.16.02 FLASHER PORTABLE PLUS 数据手册
SEGGER - The Embedded Experts - Production Programmers - Flasher Portable Production Programmers Page 1 of 3 Flasher Portable Flasher Portable/Flasher Portable PLUS Handheld Flash Programmer for on-chip and external flash memory. Flasher Portable and Flasher Portable PLUS are battery driven programming tools for microcontrollers with on-chip and/or external flash memory. They have been designed to fill the need of an extremely portable, production grade flash programmer used for in-field firmware updates. Flasher Portable can be powered by its internal battery (rechargeable for Flasher Portable PLUS) or USB. Initial setup/preparation for stand-alone mode operation is done via the J-Flash software, also used by other Flasher models, which requires a PC running Microsoft Windows 2000, Windows XP, Windows 2003, Windows Vista, Windows 7, Windows 8 or Windows 10. Flasher Portable PLUS also supports having up to eight (four in case of Flasher Portable) configurations/image files stored on the Flasher, so one unit can be used for different targets, versions or configurations. Proper image selection is done by simply clicking a button. The currently selected image is displayed. Adapters for all common connections are available which may be used to do everything from fully electrically isolating the Flasher Portable II from the target device, to remapping the pins and reducing the pitch and/or pins to the target header. In-field programming Powered by Li-Ion Features Up to eight images • Stand-alone in-circuit-programmer (Once set up, Flasher can be controlled without the use of a PC program) • Powered by internal battery, no external power supply required • Up to 10 hours programming with one battery charge • Supports having up to eight configurations/data files being stored on Flasher • Push button allows easy selection between multiple images/configurations stored on Flasher • 128 MB internal memory for configuration and data file storage • Supports ARM, Cortex, PowerPC and Renesas RX cores. For a complete list, please click here • Supports internal and external flash devices 1 • Free software updates , 1 year of support • Data files can be updated via mass storage or via J-Flash • Target interface: JTAG / SWD / FINE / SPD • Programming speed typically between 30 KB/second and 1 MByte/second. Max. programming speed highly depends on target hardware and max. programming speed of the flash itself • SECURITY: Flasher Portable and Flasher Portable PLUS support Authorized Flashing. It allows to limit the number of flash programming cycles and to protect the Flasher against non-authorized access in case of external production Authorized programming Transparent monitoring of your flashing process Head office Germany Phone: +49-2103-2878-0 Fax: +49-2103-2878-28 E-mail: info@segger.com www.segger.com 1 As a legitimate owner of a SEGGER Flasher, you can always download the latest software free of charge. Though not planned and not likely, we reserve the right to change this policy. Note that older models may not be supported by newer versions of the software. Typically, we support older models with new software at least 3 years after end of life. US office 2 Phone: +1-978-874-0299 Fax: +1-978-874-0599 E-mail: info@segger-us.com www.segger-us.com Actual programming speed depends on flash & target hardware. Model Overview Flasher Portable Portable Power Supply 3 AAA batteries Flasher Portable PLUS Internal lithium-ion rechargeable battery (Sony US14500VR) LCD Display https://www.segger.com/flasher-portable-plus.html 3/28/2017 SEGGER - The Embedded Experts - Production Programmers - Flasher Portable Max. Number of Firmware Configurations Size Weight 4 8 130mm x 65mm x 25mm 126mm x 70mm x 28mm 120g (excl. batteries) 140g Page 2 of 3 Package content Flasher Portable PLUS is delivered with the following components: Flasher Portable PLUS 20-pin, 0.1" target ribbon cable USB cable Flasher Portable is delivered with the following components: Flasher Portable 20-pin, 0.1" target ribbon cable USB cable 3x AAA batteries Specifications Power Supply Powered via battery (Li-Ion) or USB USB Host Interface USB 2 0 Target Interface Standard 20-pin J-Link target connector (optional adapters available) Serial Transfer Rate between Flasher Portable II and Target Up to 15MHz Supported Target Voltage 1.8V - 5V Current drawn from target voltage sense pin (VTRef) < 25µA Target supply voltage 4.5V max. (depends on current battery voltage) Target supply current Max. 400mA Operating Temperature + 5 °C ... + 60 °C Storage Temperature - 20 °C ... + 65 °C Relative Humidity (non-condensing) < 90% rH Size (without cables) 130mm x 65mm x 25mm Weight (without cables) 140g Supported OS Microsoft Microsoft Microsoft Microsoft Microsoft Microsoft Microsoft Microsoft Microsoft Microsoft Microsoft Microsoft Microsoft Windows Windows Windows Windows Windows Windows Windows Windows Windows Windows Windows Windows Windows 2000 XP XP x64 2003 2003 x64 Vista Vista x64 7 7 x64 8 8 x64 10 10 x64 Target interfaces Since Flasher Portable and Flasher Portable PLUS are compatible to J-Link they also support the same target interfaces. Currently the following target interfaces are supported: • JTAG • SWD • FINE https://www.segger.com/flasher-portable-plus.html 3/28/2017 SEGGER - The Embedded Experts - Production Programmers - Flasher Portable Page 3 of 3 • SPD For more information about the target interfaces please refer to J-Link - Interface description. Standard 20-pin connector pinout Flasher Portable and Flasher Portable PLUS use the standard J-Link 20-pin connector. There are various adapters available to fit all customer needs. JTAG interface connector signals: Pin Signal Type Description 1 VTref Input This is the target reference voltage. It is used to check if the target has power, to create the logic-level reference for the input comparators and to control the output logic levels to the target. It is normally fed from Vdd of the target board and must not have a series resistor. 2 Vsupply NC This pin is not connected in Flasher Portable II. It is reserved for compatibility with other equipment. Connect to Vdd or leave open in target system. 3 nTRST Output JTAG Reset (optional). Output from Flasher Portable II to the Reset signal of the target JTAG port. Typically connected to nTRST of the target CPU. This pin is normally pulled HIGH on the target to avoid unintentional resets when there is no connection. Not mandatory for Flasher operation. Should not be shortened with RESET. In case of doubt, leave open/unconnected. 5 TDI JTAG data input of target CPU. Output It is recommended that this pin is pulled to a defined state on the target board. Typically connected to TDI on target CPU. 7 TMS JTAG mode set input of target CPU. Output This pin should be pulled up on the target. Typically connected to TMS on target CPU. 9 TCK JTAG clock signal to target CPU. Output It is recommended that this pin is pulled to a defined state on the target board. Typically connected to TCK on target CPU. 11 RTCK Input Return test clock signal from the target. Some targets must synchronize the JTAG inputs to internal clocks. To assist in meeting this requirement, you can use a returned, and retimed, TCK to dynamically control the TCK rate. Flasher Portable II supports adaptive clocking, which waits for TCK changes to be echoed correctly before making further changes. Connect to RTCK if available, otherwise to GND. 13 TDO Input JTAG data output from target CPU. Typically connected to TDO on target CPU. 15 RESET I/O Target CPU reset signal. Typically connected to the RESET pin of the target CPU, which is typically called "nRST", "nRESET" or "RESET". 17 DBGRQ NC This pin is not connected in Flasher Portable II. It is reserved for compatibility with other equipment to be used as a debug request signal to the target system. Typically connected to DBGRQ if available, otherwise left open. 19 5V-Target This pin can be used to supply power to the target hardware. Supply voltage is 5V, max. current is 300mA. If not Output supply needed, leave open. Notes: All pins marked NC are not connected inside Flasher Portable II. Any signal can be applied here; Flasher Portable II will simply ignore such a signal. Pins 4, 6, 8, 10, 12, 14, 16, 18, 20 are GND pins connected to GND in Flasher Portable and Flasher Portable PLUS. They should also be connected to GND in the target system. Power can be controlled via the J-Link commander. The following commands are available to control power: Command Explanation power on Switch target power on power off Switch target power off power on perm Set target power supply default to "on" power off perm Set target power supply default to "off" © 2017, www.segger.com, All rights reserved. https://www.segger.com/flasher-portable-plus.html 3/28/2017
5.16.02 FLASHER PORTABLE PLUS 价格&库存
很抱歉,暂时无法提供与“5.16.02 FLASHER PORTABLE PLUS”相匹配的价格&库存,您可以联系我们找货
