8.06.17
8.06.17
    SEGGERMICROCONTROLLERSYSTEMS
    J-Link - 适配器板
8.06.17 数据手册
SEGGER - The Embedded Experts - J-Link Debug Probes - Adapters - SiLabs C2 Adapter J-Link Debug Probes Adapters SiLabs C2 Adapter J-Link SiLabs C2 Adapter The J-Link SiLabs C2 Adapter allows debug connections between J-Link and target hardware which comes with Silicon Labs C2 debug interface. It adapts from the 20-pin 0.1'' standard debug connector to a 10-pin 0.1'' connector pinout compatible with Silicon Labs eval boards. Since VTRef is not present on all eval boards, it is provided by the J-Link SiLabs C2 Adapter. Default VTRef voltage is 3.3 V. For increased flexibility other target voltages in the range from 1.2 V to 5.0 V can be generated by replacing a single resistor on the adapter. The J-Link SiLabs C2 Adapter is compatible with J-Link, J-Link PRO, J-Link ULTRA+ and J-Link PLUS. Block diagram of the J-Link SiLabs C2 Adapter https://www.segger.com/jlink-adapters-silabs-c2.html 4/13/2017
8.06.17 价格&库存
很抱歉,暂时无法提供与“8.06.17”相匹配的价格&库存,您可以联系我们找货
