SEGGER - The Embedded Experts - J-Link Debug Probes - Isolators - USB Isolator
Page 2 of 2
Target side isolation vs. Host side isolation
Host side isolation forces the Host to set the USB Link to Full Speed (12MBit) when connecting to J-Link. This is typically fully sufficient and
does not or not significantly reduce the debug and flash programming speed. With host side isolation, both J-Link and the target are isolated
from the host, whereas target side isolation isolates the target from both Host and J-Link. This can be desirable in metering applications, as
it introduces the least amount of noise from the debug probe to potentially sensitive ADC readings. Host side isolation works with all
supported types of debug interfaces, JTAG, SWD (with or w/o SWO), FINE, C2, UART, ... Target side isolation allows High-Speed USB
connection (480MBit) with all J-Link models supporting it, but typically limits the maximum speed on the debug interface (target side).
Target side isolation options for J-Link are:
• JTAG Isolator
• SWD Isolator
Using USB Isolators from other vendors with J-Link
The full J-Link family is designed to work with the J-Link USB Isolator, but may also be used with USB Isolators from other vendors.
However; this use is done outside of SEGGER support and done at your own risk!
© 2017, www.segger.com, All rights reserved.
https://www.segger.com/jlink-usb-isolator.html
4/13/2017
很抱歉,暂时无法提供与“8.07.02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1764.928261+228.34058
