S-8335A200FT-TB-G
S-8335A200FT-TB-G
    ABLIC(艾普凌科)
    TSSOP24
    IC REG BUCK BST ADJ 60MA 24TSSOP
S-8335A200FT-TB-G 数据手册
Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series The S-8335 Series is a bias supply IC for a Multi Line Addressing (MLA) driven LCD using a dual-line simultaneous selection mode. This IC supports medium-sized LCD panels. Two step-up type and one inverter type PFM control CMOS switching regulators supply the required positive or negative power to the two MLA-driven LCD common drivers and segment drivers. Because of its CMOS structure, the current consumption of the S-8335 Series is extremely low, which makes it ideal for the LCD power supply of portable equipment that requires low power consumption. Also, an extremely low power consumption LCD module can be created by using the S-8335 Series with the LCD common driver (HD66523R∗1: Manufactured by Hitachi, Ltd.) and segment driver (HD66522∗1: Manufactured by Hitachi, Ltd.). ∗ 1:These drivers are able to support 1/240duty and 1/200duty. Features • Supports four types of LCD panels (1/240 duty, 1/200 duty, 1/160 duty, and 1/120 duty). • Input voltage range: 2.4 to 5.0 V (The S-8335 can be driven by a single direct-coupled lithium battery.) • Output voltage range Common driver positive power supply (VRH) output voltage range(typ.value) 8.91 to 16.59 V (S-8335A240FT) 8.22 to 15.30 V (S-8335A200FT) 7.48 to 13.93 V (S-8335A160FT) 6.66 to 12.41 V (S-8335A120FT) (This supply can be varied by on-chip 6-bit electric volume. Power MOSFET is built in.) Common driver negative power supply (VRL) output voltage range(typ.value) -6.87 to -12.80 V (S-8335A240FT) -6.18 to -11.49 V (S-8335A200FT) -5.44 to -10.13 V (S-8335A160FT) -4.61 to -8.59 V (S-8335A120FT) Segment driver positive power supply (VCH) output voltage range 2.0 to 3.8 V Segment driver intermediate potential (VM) output voltage range 1.0 to 1.9 V Icon positive power supply (VICON) output voltage range 1.0 to 2.2 V (This supply can be set arbitrarily by external resistors.) • Low current consumption 100 µA typ. (mode 1, VBAT = 3 V) 10 µA typ. (mode 2, VBAT = 3 V) 1 µA max. (mode 3, VBAT = 3 V) • Triple operation mode function: Triple mode switching according to 2-bit input Mode 1: Normal operation Mode 2: Icon mode (reference voltage circuit- and regulator S-only operation) Mode 3: Standby mode (power off) • Power-off function Stops step-up or step-down operation and short circuits VRH and VRL to VSS by on-chip and external Nch transistors. • Soft-start function: This function can be set according to an external capacitor (CSS). • Oscillation frequency: 100 kHz ± 20 kHz, Duty = 50% • Lead-free products Applications • Power supply for medium-sized LCD panel Package Name • 24-pin TSSOP package (PKG diagram code: FT024-A) Seiko Instruments Inc. 1 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series Block Diagram D3 L3 L1 D1 CL3 A VRH 12 1 6 16 2 4 24 VOUT3 CONT3 VSTR_B VCLK 3 21 Electric volume RESET DC/DC P VBAT VDIN VOUT1 CONT1 CL1 DC/DC U PFM control circuit PFM control circuit 5 R1 R2 17 DC/DC Q MC1 23 22 PFM control circuit Mode control circuit MC2 14 VQERR 20 VREFU CREFU Reference voltage generation circuit op-amp X Oscillator REG S VDDX VXO REG T VYO VREGSF VREGSO VREGTF VREGTO 11 10 9 8 RS1 RS2 : small current VSS, D2 F RT1 VCH 13 VM 15 CSS CRS1 VICON 18 op-amp Y EXT2 7 19 L2 VRL CL2 CRT1 RT2 : large current VSS Figure 1 Block Diagram Note: Except for op-amp X, all of the power for the internal circuits of the S-8335 Series is supplied by the VBAT pins. The power supply for op-amp X uses VOUT3, which is generated by stepping up VBAT using DC/DC U. Short-circuit the VOUT3 and VDDX pins as shown in the figure above. 2 Seiko Instruments Inc. Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series Selection Guide 1. Product name S−8335A XXX FT−TB−G Package name (abbreviation) Product type 240: 1/240 duty support 200: 1/200 duty support 160: 1/160 duty support 120: 1/120 duty support 2. Product list S-8335AXXXFT Series Bias Ratio Common Driver Positive Power Supply VRH Output Voltage Range [V] Common Driver Negative Power Supply VRL Output Voltage Range [V] VRH_min VRH_max VRL_min VRL_max S-8335A240FT-TB-G 8.75 8.91 16.59 −6.87 −12.80 S-8335A200FT-TB-G 8.04 8.22 15.30 −6.18 −11.49 S-8335A160FT-TB-G 7.33 7.48 13.93 −5.44 −10.13 S-8335A120FT-TB-G 6.50 6.66 12.41 −4.61 −8.59 Note: VRH_min and VRL_min indicate the typical value of the VRH and VRL output voltage, respectively, when the electric volume is set to the minimum, and VRH_max and VRL_max indicate the typical value of the VRH and VRL output voltage, respectively, when the electric volume is set to the maximum. Also, VRH_max is obtained from VRETGO × 7.136 and VRH_min is obtained from VRETGO × 3.832, where VRETGO is the regulator T output voltage. Seiko Instruments Inc. 3 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series Pin Assignment 24-pin TSSOP Package Pin No. Top view CONT1 1 24 CONT3 VDIN 2 23 MC1 VCLK 3 22 MC2 VSTR_B 4 21 VOUT3 VSS 5 20 VREFU VOUT1 6 19 VDDX CSS 7 18 VXO VREGTO 8 17 VSS VREGTF 9 16 VBAT VREGSO 10 15 EXT2 VREGSF 11 14 VQERR VBAT 12 13 VYO Pin Name Function 1 CONT1 2 VDIN External inductor 1 connection pin Electric volume data input pin 3 VCLK Electric volume clock input pin 4 VSTR_B Electric volume strobe signal input pin 5 VSS GND pin 6 VOUT1 Switching regulator P output voltage pin 7 CSS Soft start capacitor connection pin 8 VREGTO Regulator T output pin 9 VREGTF Regulator T feedback input pin 10 VREGSO Regulator S output pin 11 VREGSF Regulator S feedback input pin 12 VBAT Power supply pin 13 VYO OP amplifier Y output pin 14 VQERR Switching regulator Q output voltage monitoring pin 15 EXT2 Switching regulator Q external transistor connection pin 16 VBAT Power supply pin 17 VSS GND pin 18 VXO OP amplifier X output pin 19 VDDX OP amplifier X power supply pin 20 VREFU Switching regulator U internal reference voltage pin 21 VOUT3 Switching regulator U output voltage pin 22 MC2 Operating mode control pin 2 23 MC1 Operating mode control pin 1 24 CONT3 External inductor 3 connection pin Absolute Maximum Ratings (Unless otherwise specified: TOPR=25°C) Parameter Symbol VBAT pin voltage VBAT CONT1 pin voltage VCONT1 CONT1 pin current VOUT1 pin voltage Unit 8 V −0.3 to +20 V ICONT1 300 mA VOUT1 −0.3 to +20 V EXT2 pin voltage VEXT2 −0.3 to VBAT+20 V EXT2 pin current IEXT2 CONT3 pin voltage VCONT3 CONT3 pin current VOUT3 pin voltage ±50 mA −0.3 to +8 V ICONT3 200 mA VOUT3 −0.3 to +8 V VQERR pin voltage VQERR −0.3 to +8 V VDDX pin voltage VDDX 8 V VXO pin voltage VXO −0.3 to VDDX+0.3 V Other pin voltage −0.3 to VBAT+0.3 V 650 mW TOPR −20 to +70 °C TSTG −40 to +125 °C Power dissipation PD Operating temperature range Storage temperature range Note: 4 Ratings Although this IC incorporates an electrostatic protection circuit, the user is urged to avoid subjecting the circuit to an extremely high static electricity or voltage in excess of its performance. Seiko Instruments Inc. Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series Electrical Characteristics Note: The data specifications are based on measured results using recommended peripheral parts (see Recommended Peripheral Parts). Common (Unless otherwise specified: VBA T = 3.0 V, TOPR = 25°C) Item Min. Typ. Max. Unit Measurement Circuit 2.4 3.0 5.0 V − − 100 200 µA 1 − 40 90 µA 1 − 10 20 µA 1 − − 1.0 µA 1 VCH 1.6 − − V 1 VCL − − 0.4 V 1 Symbol Input voltage VBAT Mode 1 current consumption for full oscillation IMC11 Conditions Current flowing from power supply pin VBAT. Only regulator S and T resistance externally. Maximum setting for electric volume. Output voltage of DC/DC P, U, and Q are each setting value × 0.9. CONT1 and CONT3 are pulled up to 3 V via a 300 Ω resistor. Mode 1 current consumption for stopped oscillation IMC12 Current flowing from power supply pin VBAT. Only regulator S and T resistance externally. Maximum setting for electric volume. Output voltage of DC/DC P, U, and Q are each setting value × 1.2. CONT1 and CONT3 are pulled up to 3 V via a 300 Ω resistor. Mode 2 current consumption IMC2 Current flowing from power supply pin VBAT. Only regulator S and T resistance externally. Output voltage of DC/DC P, U, and Q are 0 V. CONT1 and CONT3 are pulled up to 3 V via a 300 Ω resistor. Mode 3 current consumption IMC3 Current flowing from power supply pin VBAT. Only regulator S and T resistance externally. Output voltage of DC/DC P, U, and Q are 0 V. CONT1 and CONT3 are pulled up to 3 V via a 300 Ω resistor. MC1, MC2, VDIN, VCLK, VSTR_B pin input voltage Oscillator Part (Unless otherwise specified: VBAT = 3.0 V, TOPR = 25°C) Item Symbol Conditions Min. Typ. Max. Unit Measurement Circuit Oscillation frequency fOSC 80 100 120 kHz 1 Duty ratio Duty 40 50 60 % 1 Seiko Instruments Inc. 5 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series VRH Generation Step-Up Type DC/DC P Part (Unless otherwise specified: VBAT=3.0 V, TOPR = 25°C) Item Output voltage 1 Output voltage 2 Symbol VOUT11 VOUT12 Conditions Electric volume at maximum, IOUT1 = 100 µA Electric volume at minimum, IOUT1 = 100 µA Min. Typ. Max. Unit Measurement Circuit For S-8335A240FT, VREGTO = 2.325 V For S-8335A200FT, VREGTO = 2.144 V 16.180 16.590 17.009 V 2 14.918 15.300 15.683 V For S-8335A160FT, VREGTO = 1.952 V 13.582 13.930 14.278 V For S-8335A120FT, VREGTO = 1.739 V 12.098 12.410 12.718 V For S-8335A240FT, VREGTO = 2.325 V For S-8335A200FT, VREGTO = 2.144 V 8.688 8.910 9.134 V 8.011 8.220 8.422 V For S-8335A160FT, VREGTO = 1.952 V 7.293 7.480 7.667 V For S-8335A120FT, VREGTO = 1.739 V 6.496 6.660 6.829 V 2 Switching current ISWP VCONT1 = 0.4 V 60 85 − mA 1 Switching transistor leakage current ISWQP For mode 3 (25°C) − − 1 µA 1 For mode 3 (70°C) − − 10 µA − VOUT1 pin input current IVOUT1 For electric volume set to minimum 2 4 8 µA 1 VOUT1 pin sink current IVOUT1L Mode 3, VOUT1 = 0.4 V 0.9 1.3 − mA 1 Soft start time Tss Time until the error amplifier reference voltage reaches 90% of the final value of the regulator T output voltage. 10 15 35 ms 1 − 82 − % − CRT1= 0.1 µF, CSS= 0.01 µF Efficiency 6 EFFIP Electric volume set to middle, IOUT1 = 1 mA Seiko Instruments Inc. Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series DC/DC P Electric Volume Part (Unless otherwise specified: VBAT = 3.0 V, TOPR = 25°C) Item Symbol Min. Typ. Max. Unit Measurement Circuit For S-8335A240FT, VREGTO = 2.325 V 8.91±2.5% − 16.59±2.5% V 2 For S-8335A200FT, VREGTO = 2.144 V 8.22±2.5% − 15.30±2.5% V For S-8335A160FT, VREGTO = 1.952 V 7.48±2.5% − 13.93±2.5% V For S-8335A120FT, VREGTO = 1.739 V 6.66±2.5% − 12.41±2.5% V Potential division precision − − 2.5 % Electric volume resolution − 1/63 − Electric volume adjustment range VOUT Conditions Linearity error 2 2 − − 1/2 LSB 2 Data setup time tsc 5.0 − − µs − Data hold time thc 5.0 − − µs − VCLK pulse width tdc 0.5 4.17 − µs − VCLK period ttc 5.0 8.33 − µs − VCLK↓ to VSTR_B ↓ tss 5.0 − − µs − VSTR_B pulse width tda 5.0 − − µs − VSTR_B↑ to VCLK↑ ths 5.0 − − µs − D1 VDIN D0 tsc VCLK next MSB ttc thc tss tda tdc ths VSTR_B Figure 2 Clock Timing VDIN VCLK VSTR_B H − − Data 1 State L − − Data 0 − L to H − Load data in shift register − − L Load shift register contents in latch − − H Hold latch data Seiko Instruments Inc. 7 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series VRL Generation Inverter Type DC/DC Q Part (Unless otherwise specified: VBAT = 3.0 V, TOPR = 25°C) Item Symbol Conditions Min. Typ. Max. Unit Measurement Circuit Comparator offset VQEROF VYO = 1.45 V −20 0 +20 mV 1 EXT2 pin output current IEXT2H For VEXT2 = VBAT - 0.4 V −5.3 −7.6 − mA 1 IEXT2L For VEXT2 = 0.4 V 7.4 10.5 − mA 1 EFFIQ Electric volume set to middle, IOUT2 = 1 mA − 60 − % − Efficiency Step-up Type DC/DC U Part (Unless otherwise specified: VBAT = 3.0 V, TOPR = 25°C) Item Symbol Conditions Min. Typ. Max. Unit Measurement Circuit 2.97 3.05 3.12 V 2 Output voltage VOUT3 For fixed VREFU = 2.90 V, IOUT3 = 100 µA Switching current ISWU VCONT3 = 0.4 V 73 104 − mA 1 Switching transistor leak current ISWQU Mode 3 − − 1.0 µA 1 VOUT3 pin off current IVOUT3L Mode 3, VOUT3 = 0.4 V − − 0.5 µA 1 Efficiency EFFIU Electric volume set to middle, IOUT3 = 1 mA − 95 − % − OP Amplifier X Part (Unless otherwise specified: VBAT = 3.0 V, TOPR = 25°C) Item Symbol Conditions Output voltage VXO IOUTX = 50 µA, VREFU = 2.90 V Output voltage 2 VXO2 For 1mA output Current consumption ISSX VXO pin sink current IVXOL Mode 3, VXO = 0.4 V Min. Typ. Max. Unit Measurement Circuit 2.828 2.90 2.973 V 1 VXO - 0.08 − VXO V 1 − 10 20 µA 1 0.46 0.66 − mA 1 OP Amplifier Y Part (Unless otherwise specified: VBAT = 3.0 V, TOPR = 25°C) Item 8 Symbol Conditions Min. Typ. Max. Output voltage precision VYOD = (VXO-VYO)/VYO, no load at Y, IOUTX = 50 µA 0.98 − 1.02 VYO pin sink current IVYOL Mode 3, VYO = 0.4 V 0.46 0.66 − Seiko Instruments Inc. Unit Measurement Circuit 1 mA 1 Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series Regulator S Part (Unless otherwise specified: VBAT = 3.0 V, TOPR = 25°C) Item Output voltage Symbol VREGSO Conditions IOUTS = 50 µA, Min. Typ. Max. Unit Measurement Circuit 1.576 1.6 1.624 V 1 − ±50 − ppm/°C − 0.40 0.57 − mA 1 RS1 = 210 kΩ, RS2 = 270 kΩ Output voltage temperature coefficient ∆VREGSO /(VREGSO • ∆TOPR) TOPR = -20°C to +70°C (when no RS1, RS2 temperature characteristics are taken into account) VREGSO pin sink current IVREGSOL Mode 3, VREGSO = 0.4 V Regulator T Part (Unless otherwise specified: VBAT = 3.0 V, TOPR = 25°C) Item Output voltage VREGTO pin sink current Symbol VREGTO IVREGTOL Min. Typ. Max. Unit Measurement Circuit S-8335A240FT 2.290 2.325 2.360 V 1 S-8335A200FT 2.112 2.14 2.176 V S-8335A160FT 1.923 1.95 1.981 V S-8335A120FT 1.713 1.74 1.765 V 0.46 0.65 − mA Conditions For fixed VREGSO = 1.6 V, IOUTT=50 µA. For RT1, RT2 values, see Recommended Peripheral Parts. Mode 3, VREGSO = 0.4 V Seiko Instruments Inc. 1 9 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series Recommended Peripheral Parts (When VICON=1.6 V) Part L1, L2, L3 Value Unit 150 µH D1, D2, D3 Model No. Remark CDRH5D18-151 Manufactured by Sumida Electric Co., Ltd. MA720 Manufactured by Matsushita Electric Components Co., Ltd. (Schottky type) CL1 2.2 µF CM316W5R225K25A Ceramic type CL2 2.2 µF CM316W5R225K25A Ceramic type CL3 10 µF F930J106MA Tantalum type MOSFET A 2SJ356 Pch MOSFET manufactured by NEC MOSFET F TM5211 Pch MOSFET manufactured by Toyoda Automatic Loom Works, Ltd. MOSFET C 2SJ463A Pch MOSFET manufactured by NEC MOSFET D, E, G 2SK3019 Nch MOSFET manufactured by ROHM µF CM21B105K10A Ceramic type 1 µF CM21B105K10A Ceramic type CL6 1 µF CM21B105K10A Ceramic type CL7 1 µF CM21B105K10A Ceramic type CREFU 2200 pF CM105W5R222M10A Ceramic type CSS 0.01 µF CM105W5R103M10A Ceramic type CR1, CR2 0.01 µF CM105W5R103K25A Ceramic type CRS1 − µF CRT1 0.1 µF CM105W5R104M10A Ceramic type 1 µF CM105Y5V105Z10A Ceramic type 1 CL4 1 CL5 CVBAT1 CVBAT2 Ceramic type (capacitance added only when regulator S oscillates) µF CM105Y5V105Z10A Ceramic type CMC1, CMC2, CMC3 0.1 µF CM105Y5V104Z10A Ceramic type CDIN, CCLK, CSTR_B 1 µF CM105Y5V105Z10A Ceramic type R1, R2 1 MΩ 210 kΩ RS1 ±0.5% precision (100 + 110) kΩ, 100 kΩ replaced by thermistor. Ishizuka Electronics Corporation thermistor 104HT (100 kΩ). RS2 RT1 270 kΩ Use when RS1 + RS2 > 100 kΩ 68 kΩ S-8335A240FT (Use when RT1 + RT2 > 185 kΩ) 51 kΩ S-8335A200FT (Use when RT1 + RT2 > 110 kΩ) 33 kΩ S-8335A160FT (Use when RT1 + RT2 > 80 kΩ) S-8335A120FT (Use when RT1 + RT2 > 65 kΩ) 13 kΩ RT2 150 kΩ RA1 470 kΩ RA2 150 kΩ RA3 150 kΩ Note 1: The regulator S input (reference voltage generation circuit output) voltage has been trimmed to 0.9 V when shipped. Also, the external resistance RS1 and RS2 of the recommended peripheral parts have been set so that VICON=1.6 V. When a VICON value other than 1.6 V is used, select the resistance RS1 and RS2 values to match the VICON voltage used. Also change the RT1 and RT2 values at the same time, because the RT1 and RT2 values are selected based on VICON=1.6 V. Note 2: CRS1 is not usually necessary. Add the capacitance only when regulator S is oscillating. Evaluate the actual device using capacitance value on the order of 0.1 µF. Note 3: The output voltage precision does not include external resistance dispersion. Seiko Instruments Inc. 10 Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series Measurement Circuits 1: 1 24 CREFU CRT1 RT1 RS1 VOUT3 MC2 MC1 CRS1 VOUT1 VDIN VCLK VSTR_B VREFU CSS RT2 RS2 CL6 12 VBAT VDDX 13 CL7 VEXT2 VQERR CVBAT1 CVBAT2 CL5 CL4 2: L1 1 24 L3 D3 D1 R2 CREFU RT1 CR2 CRT1 PSW CR1 RS1 D2 CRS1 MC2 MC1 R1 VDIN VCLK VSTR_B RT2 RS2 12 CSS CL6 VBAT 13 L2 CL7 CVBAT1 CL1 CVBAT2 VREFU CL2 CL5 CL4 CL3 Figure 3 Measurement Circuits Seiko Instruments Inc. 11 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series Operation The S-8335 Series has two step-up type and one inverter type CMOS on-chip switching regulators. These switching regulators employ the pulse frequency modulation (PFM) method to provide low current consumption features. 1. Operation Overview The output of the reference voltage generation circuit is the input to regulator S. The output of regulator S is the input to regulator T. After the extremely steep rise has been blunted by an RC low-pass filter, the output of regulator T becomes the DC/DC P reference voltage. The DC/DC P output (pin name: VOUT1) that is controlled by the electric volume is obtained based on this reference voltage. The DC/DC P output becomes the common driver positive power supply (VRH). VRH is divided by internal resistors and becomes the input of OP amplifier X. The output (pin name: VXO) of OP amplifier X becomes the segment driver positive power supply (VCH). Also, the input voltage of OP amplifier X becomes the reference voltage of the DC/DC U error amplifier. The DC/DC U output (pin name: VOUT3) is obtained so that it becomes 1.05 times larger than this reference voltage. The DC/DC U output voltage can be used for the OP amplifier X power supply voltage. VCH is divided by internal resistors and becomes the input of OP amplifier Y. The output (pin name: VYO) of OP amplifier Y becomes the segment driver intermediate potential (VM). VM becomes the reference voltage of the DC/DC Q error amplifier. DC/DC Q oscillates and VRL is obtained so that the common driver negative power supply (VRL) and VRH are symmetric around VM. 12 Seiko Instruments Inc. Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series 2. Step-up type switching regulators (DC/DC P and DC/DC U) L A IOUT D VOUT VIN CONT MC1 MC2 VOUT COUT Mode control ∗ R1 M1 OSC R2 *: In DC/DC P, R1 is a variable resistance controlled by the electric volume. Figure 4 DC/DC P and DC/DC U The fundamental equations {(1) to (7)} of the step-up type regulators are shown below (see Figure 4). CONT pin voltage (VA) immediately after M1 is turned on (IL, which is the current that flows to L, is zero): VA = VS .......................................................................................................................... (1) (VS: Unsaturated voltage of M1) Change in IL with time: dIL VL VIN − VS = = dt L L ...................................................................................................... (2) Result of integrating the above equation (IL):  VIN − VS  IL =  •t L   ...................................................................................................... (3) The current IL flows during time tON. This time (tON) is determined according to the oscillation frequency of OSC. Peak current (IPK) after tON:  VIN − VS  IPK =   • tON L   ...................................................................................................... (4) The energy stored in L at this time is represented by 1/2⋅L(IPK)2. Next, when M1 is turned off (tOFF), the energy stored in L is emitted through a diode, and a counter voltage (VL) is generated. Seiko Instruments Inc. 13 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series VL: VL = (VOUT + VD ) − VIN ...................................................................................................... (5) (VD: Diode forward voltage) The CONT pin voltage rises by the voltage corresponding to VOUT + VD. Change with time of current (IL) that flows to VOUT through a diode during time tOFF: dIL VL VOUT + VD − VIN = = dt L L ................................................................................................. (6) Result of integrating the above equation:  VOUT + VD − VIN  IL = IPK −  •t L   .............................................................................................. (7) During tON, the energy is stored in L and not transmitted to VOUT. When output current (IOUT) flows from VOUT, the capacitor (COUT) energy is used. As a result, the COUT pin voltage decreases and reaches its lowest value after time tON. When M1 is turned off, the energy stored in L is transmitted through the diode to COUT, and the COUT pin voltage rises dramatically. VOUT is a time function that indicates the maximum value (ripple voltage: VP-P) when the current flowing through the diode to VOUT matches the load current IOUT. This ripple voltage value is calculated below. IOUT when the time from immediately after tON until VOUT reaches its highest level is set to t1:  VOUT + VD − VIN  IOUT = IPK −   • t1 L   L   + − V OUT V D V IN   ∴ t1 = (IPK − IOUT ) •  ......................................................................................... (8) .................................................................................... (9) Since IL=0 at time tOFF (when all inductor energy was emitted), the following is obtained from equation (7): L tOFF = VOUT + VD − VIN IPK ...................................................................................................... (10) The following is obtained by substituting equation (10) into equation (9):  IOUT  t1 = tOFF −   • tOFF  IPK  14 ...................................................................................................... Seiko Instruments Inc. (11) Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series The amount of electric charge ∆Q1 charged in COUT during time t1: ∆Q1 = ∫0t1 IL dt = IPK • ∫0t1 dt − = IPK • t1 − VOUT + VD − VIN t1 • ∫0 t dt L VOUT + VD − VIN 1 2 • t1 L 2 ......................................................................................... (12) The following is obtained by substituting equation (9) into equation (12)  ∆Q1 = IPK −  1 (IPK − IOUT ) • t1 =  IPK + IOUT  • t1 ......................................................................... 2 2    (13) The voltage rise (VP-P) due to ∆Q1 is as follows: VP-P = 1 ∆Q1  IPK + IOUT  • =  • t1 COUT COUT  2  ............................................................................... (14) The following is obtained when the IOUT consumed during time t1 and RESR, which is the Electric Series Resistance (ESR) of COUT, are taken into consideration: VP-P = 1 IOUT • t1 ∆Q1  IPK + IOUT   IPK + IOUT  • =  • RESR −  • t1 +  COUT COUT  2 2 COUT    ................................... (15) The following is obtained when equation (11) is substituted into equation (15): VP-P = (IPK − IOUT )2 2IPK • tOFF  IPK + IOUT  +  • RESR COUT  2  .................................................................. (16) Effective ways to reduce the ripple voltage are to increase the capacitance of the capacitor connected to the output pin and to reduce its ESR. Note: Although this IC has an on-chip soft-start circuit, a rush current flows because the output capacitor (COUT) and load capacitance component are charged up via the coil and diode on power application. Therefore, care must be taken. Seiko Instruments Inc. 15 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series 3. Inverter type switching regulator (DC/DC Q) The fundamental equations of the inverter type regulator are shown below. Point A voltage immediately after M1 is turned on (IL, which is the current that flows to L, is zero): VA = VIN − VS ................................... (17) VIN (VS: Unsaturated voltage of M1) M1 IOUT A −VOUT Di L Change in IL with time: dIL VL VIN − VS ............................. = = dt L L COUT OSC (18) Figure 5 Inverter Type Switching Regulator Result of integrating the above equation (IL):  VIN − VS  IL =   • t ................................. L   (19) The current IL flows during time tON. This time (tON) is determined according to the oscillation frequency of OSC. Peak current (IPK) after tON:  VIN − VS  IPK =   • tON L   ...................................................................................................... (20) The energy stored in L at this time is represented by 1/2⋅L(IPK)2. Next, when M1 is turned off, the energy stored in L is emitted through ground→capacitor→diode (Di), and a counter voltage (VL) is generated at the same time. VL: VL = − (VOUT + VD ) ...................................................................................................... (21) (VD: Diode forward voltage) Change with time of current (IL) that flows to −VOUT through a capacitor during time tOFF: dIL VL VOUT + VD = = dt L L ...................................................................................................... (22) Result of integrating the above equation:  VOUT + VD  IL = IPK −  •t L   16 ...................................................................................................... Seiko Instruments Inc. (23) Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series During tON, the energy is stored in L and not transmitted to −VOUT. When output current (IOUT) flows from -VOUT, the capacitor (COUT) energy is used. As a result, the COUT pin voltage decreases and reaches its lowest value after time tON. When M1 is turned off, the energy stored in L is transmitted through the diode to COUT, and the COUT pin voltage rises dramatically. VOUT is a time function that indicates the maximum value (ripple voltage: VP-P) when the current flowing through the diode to VOUT matches the load current IOUT. This ripple voltage value is calculated below. IOUT when the time from immediately after tON until VOUT reaches its highest level is set to t1:  VOUT + VD  IOUT = IPK −   • t1 ..................................................................................................... L   (24) L   ................................................................................................  VOUT + VD  (25) ∴ t1 = (IPK − IOUT ) •  Since IL=0 at time tOFF (when all inductor energy was emitted), the following is obtained from equation (23): L tOFF = VOUT + VD IPK ...................................................................................................... (26) The following is obtained by substituting equation (26) into equation (25):  IOUT  t1 = tOFF −   • tOFF  IPK  ...................................................................................................... (27) The amount of electric charge ∆Q1 charged in COUT during time t1: ∆Q1 = ∫0t1 IOUT dt = IPK • ∫0t1 dt − = IPK • t1 − VOUT + VD t1 • ∫0 t dt L VOUT + VD 1 2 • t1 ...................................................................................................... L 2 (28) The following is obtained by substituting equation (25) into equation (28) ∆Q1 = IPK − 1 (IPK − IOUT ) • t1 = IPK + IOUT • t1 2 2 ............................................................................ (29) The voltage rise (VP-P) due to ∆Q1 is as follows: VP-P = ∆Q1 COUT = 1 COUT •  IPK + IOUT    • t1 2   ................................................................................. Seiko Instruments Inc. (30) 17 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series The following is obtained when the IOUT consumed during time t1 is taken into consideration: VP-P = 1 IOUT • t1 ∆Q1  IPK + IOUT  • = .....................................................................  • t1 − COUT COUT  2 COUT  (31) The following is obtained when equation (27) is substituted into equation (31): VP-P 18 = (IPK − IOUT )2 • 2IPK tOFF COUT ................................................................................................. Seiko Instruments Inc. (32) Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series Operation Modes and Mode Control The mode is switched among modes 1 to 3 according to the 2-bit input from the MC1 and MC2 pins and the MC3 signal. The MC3 signal is not an input to a pin of this IC. It is a signal required for external part control. This signal should be supplied from the LCD driver or LCD controller. Since the MC1 and MC2 pins are not pulled up or pulled down internally, they should not be in a floating state. Also, note that the current consumption in standby mode may exceed 1 µA if there is a potential difference between the supply voltage of MC1 and MC2 and the supply voltage of the S-8335 Series IC. MC1 MC2 MC3* L L H Operation Mode L H L Mode 2 (Icon mode) H X L Mode 3 (Standby mode) Mode 1 (Normal operation) Remark: L: Low level, H: High level, X: Don't care * MC3 is a signal that is the input to an external switch to forcibly discharge a capacitor in modes 2 and 3. 1. Normal operation mode (MC1=L, MC2=L, MC3=H) Step-up operation is performed. 2. Icon mode (MC1=L, MC2=H, MC3=L) Only the reference voltage circuit and regulator S operate. The regulator S output VREGSO can be set arbitrarily in the range from 1.0 to 2.2 V by using external resistors RS1 and RS2. VREGSO can be used as the icon voltage. Use an RS1 value that matches the temperature characteristics of the panel by combining a series or parallel resistor with a thermistor as necessary. See the section on regulator S for information about the output voltage characteristics of regulator S when the output current is drawn. 3. Standby mode (MC1=H, MC3=L) The operation of internal circuits is shut down. The current consumption does not exceed 1 µA. When the MC1 pin is set high ("H" level), the operation of all internal circuits stops, and the current consumption is dramatically reduced. At the same time, the VOUT1, VXO, VYO, VREGSO, and VREGTO pins are each short-circuited to VSS by on-chip Nch transistors. (However, data that was written to the register of the electric volume part is retained if a voltage of at least 2 V is applied between the VBAT and VSS pins.) Since current flows at this time from the VOUT1 pin to VSS through a coil and a diode at the input side, a switch for shutting down the current is required. Figure 6 shows a sample circuit that uses NEC’s 2SJ356 (Pch MOSFET) as the current breaker switch. In this sample circuit, the small signal transistor E (Nch MOSFET) is used to turn 2SJ356 on or off by inputting the control signal MC3 to the gate of transistor E. An invalid current flowing to resistor RA1 during a step-up operation may affect efficiency. Resistor RA1 should be set to a high resistance value to reduce current. However, if the RA1 resistance value is set too high, a voltage drop across resistor RA1 will occur due to the off-leak current of the small signal transistor E, and the 2SJ356 current breaker switch may not turn off. Therefore, care must be taken. Note: The efficiency characteristics shown in the reference data, which were measured without a current breaker switch, differ from the efficiency of this sample circuit. Seiko Instruments Inc. 19 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series SBD L1 2SJ356 A D1 CONT1 VOUT1 RESET RA2: 150 kΩ RA1: 470 kΩ VBAT MC1 CL1 MC2 E VSS MC3 Figure 6 Sample Circuit in Which 2SJ356 is Used When mode 3 (standby mode) is canceled, the mode returns to the one that was in effect before switching to standby mode. For example, if the IC entered mode 3 from mode 1, it will return to mode 1 when mode 3 is canceled. Note 1: For example, when the applied voltage to MC1 and MC2 is 3.0 V and the power supply voltage of the S-8335 Series is 5.0 V, the current consumption in standby mode rises to approximately 2.5 µA at 25°C (typ.) (see Figure 7). The reason this occurs is that a penetrating current flows in CMOS logic circuits because the potential of input signals MC1 and MC2 (3.0 V) is lower than the internal logic power supply voltage (5.0 V). 3 Standby Current [µA] If there is a potential difference between the applied voltage to MC1 and MC2 and the power supply voltage of the S8335 Series, the current consumption in standby mode may exceed 1 µA. 2.5 VMC1 = 3.0 V 2 1.5 1 0.5 0 2.0 2.5 3.0 3.5 4.0 VBAT [V] 4.5 5.0 Figure 7 Standby Mode Current Characteristics Therefore, use this IC in such a way that no potential difference occurs between the applied voltage to MC1 and MC2 and the power supply voltage of the S-8335 Series. MC1 (or MC2) Note 2: A penetrating current from VBAT to VSS flows when the mode is switched. When MC1 (or MC2) = "H" and MC3 = "H", a current of approximately 6 mA flows from the VBAT pin through the coil L1, diode D1, and transistor A because the VOUT1 pin is short-circuited to GND level. MC3 Also, when MC1 (or MC2) = "L" and MC3 = "L", VRL and GND are short-circuited via transistor G, and a current of approximately 150 mA flows. 20 To reduce the penetrating current, the MC1 (or MC2) and MC3 signals should both be switched at the same time when modes are switched. If this cannot be done, avoid a state in which the MC1 (or MC2) and MC3 signals are both low ("L" level) at the same time in order to reduce the penetrating current (see Figure 8). Seiko Instruments Inc. Normal mode Standby mode (or icon mode) Normal mode Figure 8 Mode Switching Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series Electric volume VDIN VCLK 6-bit shift register VDIN D5 D4 D3 D2 D1 (MSB) D0 (LSB) VCLK RESET VSTR_B 6-bit latch VSTR_B Hold Read Reset VOUT Electric volume Hold min. value Setting value VOUT Figure 9 Block Diagram and Clock Timing of Electric Volume Part VDIN: This is the data input pin to the electric volume. "Data 1" is an input for the “H” level, and "data 0" is an input for the "L" level. (A high impedance state is prohibited.) When no data is sent, keep VDIN at the "L" level. VCLK: This is the clock input pin to the electric volume. The data of the VDIN pin is fetched to the shift register at the clock rising edge. When a clock with more than six bits data is input, the data that had been read is sequentially shifted at each clock pulse, and the last six bits of data become effective. VSTR_B: This is the strobe signal input pin. When the strobe signal goes low (set to "L" level), the shift register contents are fetched to the latch. The data that is fetched to the latch is sent directly to the electric volume, and consequently the output voltage changes. When the strobe signal goes high (set to "H" level), the latch data is held. Output voltage (V) ±1/2 LSB ±1/2 LSB 0 1 31 32 62 63 Electric volume data (DEC) Figure 10 Linearity Error Seiko Instruments Inc. 21 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series The electric volume has 6-bit resolution. The integral and differential linearity errors are ±0.5LSB. For example, if you want the VRH output voltage range to vary between 8.91 and 16.59 V, you can obtain a linearity precision of ±61 mV by selecting the S-8335A240FT. Since the register contents are undefined when the power is turned on, they must be reset. Even if the MC1 pin or MC2 pin is set high ("H" level) and the MC3 signal is set low ("L" level) and the step-up operation stops, the electric volume register contents are retained if a voltage of at least 2 V is applied between the VBAT and VSS pins. Register “WRITE” and “RESET” operations are also available in this state. The register is initialized to “000000” and the output voltage is set to its minimum value by setting VCLK = "H" and VSTR_B = "L". Turn on the power with MCI = “H” and MC3 = “L”. Then initialize the register contents by setting VCLK = "H" and VSTR_B="L" and begin the step-up operation by switching the MC1 and MC2 pins low ("L" level) and the MC3 signal high ("H" level). Caution: If a step-up operation is started without initializing the data in the register after turning on the power, the maximum output voltage may appear at the VOUT pins and connected devices or instruments may be damaged. It is recommended to connect a pull-down resistor between VSS and the external part pins that the MC3 signal enters and to connect a pull-up resistor between the MC1 pin and VBAT. Note: 22 3 Standby current [µA] If there is a potential difference between the applied voltage to VDIN, VCLK, and VSTR_B and the power supply voltage of the S-8335 Series, the current consumption in standby mode may exceed 1 µA. For example, when the applied voltage to VDIN, VCLK, and VSTR_B is 3.0 V and the power supply voltage of the S-8335 Series is 5.0 V, the current consumption in standby mode rises to approximately 2.5 µA at 25°C (typ.) (see Figure 11). The reason this occurs is that a penetrating current flows in the CMOS logic circuits because the potential of input signals VDIN, VCLK, and VSTR_B (3.0 V) is lower than the internal logic power supply voltage (5.0 V). A similar situation occurs for the power supply voltage of MC1 and MC2 (see Note in the Mode Control section). 2.5 VDIN = 3.0 V 2 1.5 1 0.5 0 2.0 2.5 3.0 3.5 4.0 VBAT [V] 4.5 5.0 Figure 11 Standby Mode Current Characteristics Seiko Instruments Inc. Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series The power supply voltage of OP amplifier X is generated using DC/DC U so that it is approximately 1.05 times larger than the output voltage of OP amplifier X. Since the difference between the power supply voltage and output voltage is kept small, the power loss is extremely small and efficiency is increased. Figure 12 shows the output voltage of OP amplifier X when source current is drawn. VXO [V] OP amplifier X 4 3.5 3 2.5 2 1.5 1 240 dot,25°C 0.5 VBAT =3.0V 0 EV=MIN EV=MID EV=MAX 500 1000 1500 2000 SOURCE CURRENT, IOUTX[µA] Figure 12 OP Amplifier X Output Voltage OP amplifier Y VBAT is used for the power supply voltage of OP amplifier Y. Figures 13 and 14 show the output voltage of OP amplifier Y when source current and sink current are drawn, respectively. 1.5 1.5 1 0.5 0 EV=MIN EV=MID EV=MAX 240 dot,25 °C VBAT=3.0V 500 1000 SOURCE CURRENT, 1500 VYO [V] 2 VYO [V] 2 1 2000 0 −500 IOUTY [µA] Figure 13 VYO Pin Source Current Characteristics EV=MIN EV=MID EV=MAX 0.5 240 dot,25 °C VBAT=3.0V −1000 SINK CURRENT, −1500 −2000 IOUTY [µA] Figure 14 VYO Pin Sink Current Characteristics VBAT is used for the power supply voltage of the regulator S part. The regulator S output VREGSO can be set arbitrarily in the range from 1.0 to 2.2 V by using external resistor RS1 and RS2. VREGSO can be used as the icon voltage. Use an RS1 value that matches the temperature characteristics of the panel by combining a series or parallel resistor with a thermistor as necessary. VREGSO [V] Regulator S Part 1.6 1.58 1.56 1.54 1.52 1.5 1.48 1.46 Also, CRS1 is a capacitor for preventing oscillation. It is required only when the regulator oscillates. Adjust the CRS1 value when the RS1 and RS2 values are changed. Using the actual device, confirm that the regulator does not oscillate. Figure 15 shows the voltage VREGSO when current is drawn. Seiko Instruments Inc. VBAT=2.4V VBAT=3.0V VBAT=5.0V 0 500 1000 1500 2000 IOUT [µ A] Figure 15 VREGSO Characteristics 23 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series Regulator T Part VREGTO [V] VBAT is used for the power supply voltage of the regulator T part. The regulator T output VREGTO can be set by using external resistance RT1 and RT2. Set VREGTO to match the voltage range that is to be used. The common-driver voltage VRH_max is obtained by VREGTO × 7.136, and VRH_min is obtained by VREGTO × 3.832. Figure 16 shows the voltage VREGTO when current is drawn. 2.35 2.3 2.25 2.2 2.15 2.1 2.05 2 VBAT=2.4V VBAT=3.0V VBAT=5.0V 0 500 1000 1500 2000 IOUT [µ A] Figure 16 VREGTO Characteristics Power Supply Rising Edge Sequence The power supply rising edge sequence is VRH, VCH, VM, VRL. The falling edge sequence is VRL, VM, VCH, VRH. (See Figure 17.) VRH : 2 V/div VCH : 2 V/div VM : 2 V/div VRL : 5 V/div t : 5 ms/div VRH V VCH VM VRL t Figure 17 Rising and Falling Edge Sequences Soft Start The soft-start function blunts the rising edge of the reference voltage VREGTO by using an external capacitor CSS and an internal resistor so that the rush current can be reduced to some degree corresponding to this moderated ascent. However, note that this is not a complete soft start because the switching regulators of the S-8335 Series use PFM control. 24 Seiko Instruments Inc. Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series Selection of External Parts 1. Inductor The inductance value significantly affects the maximum output current IOUT and efficiency η (EFFI). Figure 18 shows graphs of the dependency of IOUT and EFFI for the S-8335 Series on the inductance value L. DC-DC Q ( VOUT=16.6 V, VBAT=3.0 V ) DC-DC P (VOUT = 16.6 V, VBAT = 3.0 V) EFFIP IOUT IOUT 100 IOUT EFFIQ IOUT EFFIP L value (µH) 150 EFFIQ 100 180 L value (µH) Recommended range Recommended range DC-DC U (VOUT = 3.99 V, VBAT = 3.0 V ) EFFIU IOUT IOUT 100 EFFIU 150 180 L value (µH) Recommended range Figure 18 Dependency of IOUT and EFFI on Inductance Value L As the L value decreases, the peak current IPK increases, and IOUT reaches its maximum at a certain L value. If the L value decreases further, the current driving capability of the switching transistor becomes insufficient, and IOUT is reduced. Also, as the L value increases, the power loss due to IPK at the switching transistor decreases, and the efficiency reaches its maximum at a certain L value. If the L value increases further, the power loss due to the series resistance of the coil increases, and efficiency is reduced. The recommended inductance value is 100 to 150 µH for DC/DC P and 100 to 180 µH for DC/DC Q and DC/DC U. Seiko Instruments Inc. 25 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series When you select inductors, pay attention to the permissible current of the inductors. If a current that exceeds the permissible current flows in the inductor, magnetic saturation will occur in the inductor. This may cause a significant decrease in efficiency and may damage the IC due to excessive current. Therefore, select inductors so that the peak current IPK does not exceed the permissible current. The peak current IPK in non-continuous mode is given by the following equation. IPK = 2IOUT • ( VOUT + VD − VIN ) fOSC • L (A) ...................................................................................... (33) where fOSC is the oscillation frequency. VD is approximately 0.4 V. For example, assume that output voltage VOUT = 16.6 V, with load current IOUT = 2mA, using S-8335A240FT with the input voltage VIN = 3 V and fOSC = 100 kHz. If 150 µH is selected for the L value, then IPK = 61 mA from equation (33). Therefore, an inductor having a permissible current of at least 61 mA at an L value of 150 µH should be selected. 2. Diode An off-chip diode must satisfy the following conditions. • • • • Low forward voltage: VF < 0.3 V Fast switching speed: 500 ns max. Reverse breakdown voltage: VOUT+VF or more Rated current: IPK or more 3. Capacitors (CVBAT, CL) The input capacitor (CVBAT) can improve efficiency by decreasing the power supply impedance and stabilizing the input current. Select the capacitor value according to the impedance of the power supply used. Connect a capacitor of at least 1 µF to each of the two power supply pins. For the output capacitor (CL), use a capacitor having a small Electric Series Resistance (ESR) and large capacitance to stabilize the ripple voltage. Standard capacitor values are at least 2.2 µF for CL1 and CL2 and at least 10 µF for CL3. In particular, a tantalum electrolytic capacitor having excellent low temperature characteristics and low leakage current characteristics should be used. A capacitor having a large capacitance produces more stable output and leads to higher efficiency. 26 Seiko Instruments Inc. Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series Standard Circuits D3 L3 L1 D1 CL3 A VRH CL1 12 1 6 16 2 RESET CVBAT2 3 24 VOUT3 CONT3 VSTR_B 4 21 Electric volume DC/DC P VBAT VCLK E MC3 VDIN CVBAT1 RA2 VOUT1 CONT1 RA1 DC/DC U PFM control circuit PFM control circuit 5 CR1 17 23 MC2 CMC2 PFM control circuit Mode control circuit CMC1 22 14 20 VQERR VREFU CREFU Reference voltage generation circuit op-amp X Oscillator REG S 19 VDDX 18 VCH CL4 13 VM CL5 VXO REG T VYO VREGSF VREGSO VREGTF VREGTO 11 R2 CR2 DC/DC Q MC1 R1 10 9 CL6 8 CL7 RS2 : small current VSS, 15 CSS CRS1 VICON RS1 D2 F RT1 op-amp Y EXT2 7 L2 CL2 VRL G CRT1 RT2 RA3 VBAT C D MC3 : large current VSS Figure 19 Standard Circuits Except for op-amp X, all of the power for the internal circuits of the S-8335 Series is supplied by the VBAT pin. Seiko Instruments Inc. 27 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series Pattern Diagram In general, the switching regulator is significantly affected by the circuit board wiring. The following figure shows a sample pattern diagram for which the effect of the circuit board wiring is small. 55 mm 59 mm Figure 20 Pattern Diagram Note the following points when creating a pattern diagram. • There are two VSS lines (connected inside the IC). a) VSS (pin No. 5): Large current GND b) VSS (pin No. 17): Small current (analog) + middle current GND • Arrange the VSS line and capacitors first. CVBAT, CL1, CL2, and CL3 are particularly important. Draw the VSS line as wide as possible. • Basically, make the GND part of the circuit board as broad as possible and keep the impedance low. • There are two VBAT lines (not connected inside the IC). a) VBAT (pin No. 12): Reference (low noise) b) VBAT (pin No. 16): All others (semi-low noise) • Connect CL3 at both pin No. 19 (VDDX) and pin No. 21 (VOUT3) if possible (for example, connect 6.8 µF at each pin). • Do not use through holes at locations for connecting CL1 to CL3. • Increasing CL1 makes the output more stable. If the DC/DC P output fluctuates due to ripple, and this causes VQERR to frequently exceed the DC/DC Q error amplifier threshold value, then DC/DC Q oscillates more than necessary and the DC/DC Q efficiency will decrease. Therefore, stabilizing the DC/DC P output will also improve DC/DC Q efficiency. 28 Seiko Instruments Inc. Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series Application Circuit D3 L3 L1 D1 CL3 A CL1 12 1 6 2 3 4 24 21 VDDX VOUT3 CONT3 VSTR_B VCLK MC3 VDIN CVBAT1 RA2 VOUT1 VBAT CONT1 RA1 19 16 VBAT CVBAT2 CR1 R1 CR2 R2 VQERR 14 VBAT 5 VSS VREFU 20 S-8335 CREFU 17 VSS MC1 CL4 CMC1 MC2 CMC2 22 VCH Segment driver VM VCL VXO 18 23 MC1 VYO 13 MC2 CL5 VREGSF VREGSO VREGTF VREGTO 11 10 9 CL6 8 CL7 EXT2 7 CSS CRS1 VICON RS1 RS2 : small current VSS, 15 F RT1 VM D2 L2 CL2 G CRT1 RT2 RA3 VBAT C D VRL VRH Common driver MC3 : large current VSS Figure 21 Application Circuit Example Seiko Instruments Inc. 29 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series Precautions • Mount external capacitors, diodes, coils, and other components as close as possible to the IC. • The RS1, RS2, RT1, and RT2 values of the recommended peripheral parts are for VICON = 1.6 V. If a VICON value other than 1.6 V is used, the resistance values should be changed. The output voltage precision does not include external resistance dispersion. • Characteristic ripple voltage and spike noise occur at the switching regulator. Since these are significantly affected by the coil and capacitor that are used, evaluate them using actual devices when the circuit is designed. • CR1 and CR2 contribute to the stability of the VQERR pin potential and increase the efficiency of switching regulator Q. Although a capacitance value in the range from 1000 pF to 0.01 µF is recommended for CR1 and CR2, you should evaluate this value using an actual device. Power dissipation PD (mW) • Make sure that the operating ambient temperature range of this IC is not exceeded due to switching transistor power dissipation (particularly at high temperature). 1000 800 600 400 200 0 50 100 150 Ambient temperature TOPR (°C) Figure 22 Power Dissipation of 24-pin TSSOP Package (Unmounted) • Arrange parts so that the line to the VSS pin (indicated by the bold line in Figure 23) is as short as possible. If this line has resistance and inductance components, the VSS potential of the IC will fluctuate due to the switching current. If a potential difference is produced between the VSS of the CPU and the VSS of the IC, a malfunction may occur in the interface, and the electric volume may be reset. VIN CONT VDIN VCLK CPU VSS S-8335 VSTR_B VSS Figure 23 VSS Line 30 Seiko Instruments Inc. VOUT Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series • When switching the output voltage by the electric volume, the soft start does not function. Note that an overshoot will occur when the output voltage increases by a large amount. • When the internal impedance of the power supply (VBAT) is large, the S-8335 Series may not start up. Make sure that the internal impedance of the power supply used is sufficiently small when using this IC. • Make sure that the potential of the VOUT1 pin does not exceed 20 V, which is the absolute maximum rating, when using this IC. • Make the capacitance of VDIN, VCLK, and VSTR_B large enough to prevent noise and malfunctions. • Seiko Instruments Inc. shall bear no responsibility for any patent infringement by a product that includes an IC manufactured by Seiko Instruments Inc. in relation to the method of using this IC in that product, the product specifications, or the destination country. Seiko Instruments Inc. 31 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series Characteristic Curves 1. Common characteristics (Unless otherwise specified, these graphs show typical data for TOPR = 25°C.) Current consumption (for mode 1 when oscillation is stopped) Current consumption (for mode 1 with full oscillation) 41 160 140 40 IMC11 [µA] IMC12 [µA] 39 38 37 36 35 1 2 3 4 5 120 100 80 60 40 20 0 6 VBAT [V] 3 14 3 12 2.5 10 2 8 6 4 6 4 5 6 5 6 1.5 1 1 2 3 4 5 0 6 1 2 3 VBAT [V] VBAT [V] ISSX [µA] 8.95 8.9 8.85 8.8 8.75 8.7 8.65 8.6 8.55 VXO pin sink current IVXOL [µA] OP amplifier X part current consumption 1 2 3 4 5 6 0.72 0.71 0.7 0.69 0.68 0.67 0.66 0.65 0.64 0.63 0.62 1 VBAT [V] 0.66 0.65 0.64 0.63 0.62 0.61 0.6 0.59 1 2 3 2 3 4 VBAT [V] VYO pin sink current IVYOL [µA] 5 0.5 2 4 5 6 VBAT [V] 32 4 Current consumption (mode 3) IMC3 [µA] IMC2 [µA] 2 VBAT [V] Current consumption (mode 2) 0 1 Seiko Instruments Inc. Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series DC/DC P part switching current DC/DC P part switching transistor leakage current 140 0.02 0.016 100 ISWQP [µA] ISWP [mA] 120 80 60 40 0.008 0.004 20 0 0.012 1 2 3 4 5 0 6 1 2 3 VBAT [V] DC/DC Q part comparator offset voltage IEXT2H [mA] VQEROF [mV] −0.5 5 6 4 5 6 4 5 6 8 6 4 2 1 2 3 VBAT [V] 4 5 0 6 EXT2 pin current (IEXT2L) 1 2 3 VBAT [V] DC/DC U part switching current 140 120 ISWU [mA] IEXT2L [mA] 4 10 −1 100 80 60 40 20 0 1 2 3 VBAT [V] 4 5 6 2 3 VOUT3 pin off current 1 0.008 0.8 IVOUT3L [µA] 0.01 0.006 0.004 0.6 0.4 0.2 0.002 0 1 VBAT [V] DC/DC U part switching transistor leakage current ISWQU [µA] 6 12 −1.5 18 16 14 12 10 8 6 4 2 0 5 EXT2 pin current (IEXT2H) −2 0 4 VBAT [V] 1 2 3 4 5 6 0 1 VBAT [V] 2 3 VBAT [V] Seiko Instruments Inc. 33 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series Regulator S part output voltage (vs. IOUT) 1.6 1.6 1.5995 1.58 1.599 1.56 VREGSO [V] VREGSO [V] Regulator S part output voltage (vs. VBAT) 1.5985 1.598 1.52 VBAT=2.4V VBAT=3.0V VBAT=5.0V 1.5 1.5975 1.597 1.54 1.48 1 2 3 4 5 1.46 6 0 500 1000 IOUT [µA] VBAT [V] VREGSO pin sink current 1 IVREGTOL [mA] IVREGSOL [mA] 0.8 0.6 0.4 0.2 1 2 3 4 5 0 6 1 2 3 MC1, MC2 pin high level voltage VCL [V] VCH [V] 4 5 6 0.598 1 0.8 0.6 0.4 0.596 0.594 0.592 0.2 1 2 3 4 5 6 VBAT [V] 0.59 1 20 18 16 14 12 1 2 3 2 3 VBAT [V] Soft start time tSS [ms] 6 0.6 1.2 4 5 6 VBAT [V] 34 5 MC1, MC2 pin low level voltage 1.4 10 4 VBAT [V] VBAT [V] 0 2000 VREGTO pin sink current 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 1500 Seiko Instruments Inc. Rev.6.0_01 2. STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series S-8335A240FT (1/240 duty. Unless otherwise specified, these graphs show typical data for TOPR = 25°C.) 4 3.5 3 2.5 2 1.5 1 0.5 0 OP amplifier X part output voltage (VBAT = 3.0 V) 4 3.5 VXO [V] VXO [V] OP amplifier X part output voltage (VBAT = 2.4 V) EV=MIN EV=MID EV=MAX 0 500 1000 1500 2000 3 2.5 2 1.5 1 0.5 0 EV=MIN EV=MID EV=MAX 0 SOURCE CURRENT, IOUTX [µA] OP amplifier Y part output voltage (vs. source current, VBAT = 2.4 V) VYO [V] VYO [V] 1.5 1 EV=MIN EV=MID EV=MAX 0.5 0 500 1000 1500 2000 2 1.8 1.6 1.4 1.2 1 0.8 0.6 0.4 0.2 0 OP amplifier Y part output voltage (vs. sink current, VBAT = 2.4 V) VYO [V] VYO [V] 1.5 1 EV=MIN EV=MID EV=MAX 0 −500 −1000 2000 EV=MID EV=MAX 0 500 1000 SOURCE CURRENT, 1500 IOUTY [µA] 2000 OP amplifier Y part output voltage (vs. sink current, VBAT = 3.0 V) 2 0 1500 IOUTX [µA] EV=MIN SOURCE CURRENT, IOUTY [µA] 0.5 1000 OP amplifier Y part output voltage (vs. source current, VBAT = 3.0 V) 2 0 500 SOURCE CURRENT, −1500 −2000 SINK CURRENT, IOUTY [µA] 2 1.8 1.6 1.4 1.2 1 0.8 0.6 0.4 0.2 0 EV=MIN EV=MID EV=MAX 0 −500 −1000 −1500 SINK CURRENT, IOUTY [µA] −2000 Regulator T part output voltage 2.35 VREGTO [V] 2.3 2.25 2.2 2.15 VBAT=2.4V VBAT=3.0V VBAT=5.0V 2.1 2.05 2 0 500 1000 IOUT [µA] 1500 2000 Seiko Instruments Inc. 35 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series VOUT1 [V] DC/DC P part output voltage 18 16 14 12 10 8 6 4 2 0 VBAT=2.4V VBAT=3V VBAT=5V 0 20 40 EV Point 60 80 DC/DC P part output efficiency (VBAT = 2.4 V) DC/DC P part output ripple voltage (VBAT = 2.4 V, reference value) 70 60 50 40 30 20 10 0 30 25 Ripple [mV] EFFIP [%] 80 EV=MIN EV=MID 500 1000 IOUT [µA] 1500 EFFIP[%] Ripple [mV] EV=MID EV=MAX 500 1000 IOUT [µA] 1500 2000 DC/DC P part output efficiency (VBAT = 5.0 V) Ripple [mV] EFFIP [%] 60 EV=MIN EV=MID EV=MAX 0 0 36 500 1000 IOUT [µA] 1500 0 500 1000 IOUT [µA] 1500 2000 50 45 40 35 30 25 20 15 10 5 0 EV=MIN EV=MID EV=MAX 500 1000 IOUT [µA] 1500 2000 DC/DC P part output ripple voltage (VBAT = 5.0 V, reference value) 80 20 EV=MAX 0 100 40 EV=MID DC/DC P part output ripple voltage (VBAT = 3.0 V, reference value) EV=MIN 0 EV=MIN 10 0 2000 DC/DC P part output efficiency (VBAT = 3.0 V) 90 80 70 60 50 40 30 20 10 0 15 5 EV=MAX 0 20 2000 180 160 140 120 100 80 60 40 20 0 EV=MIN EV=MID EV=MAX 0 Seiko Instruments Inc. 500 1000 IOUT [µA] 1500 2000 Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series VOUT2 [V] DC/DC Q part output voltage -13 -12 -11 -10 -9 -8 -7 -6 -5 -4 VBAT=3V 0 20 40 EV Point 60 80 DC/DC Q part output efficiency (VBAT = 2.4 V) DC/DC Q part output ripple voltage (VBAT = 2.4 V, reference value) 70 50 40 50 Ripple [mV] EFFIQ [%] 60 40 30 EV=MIN 20 EV=MID 10 EV=MAX 30 20 EV=MIN EV=MID 10 0 EV=MAX 0 0 500 1000 1500 2000 0 500 IOUT [µA] DC/DC Q part output efficiency (VBAT = 3.0 V) 50 Ripple [mV] EFFIQ[%] 60 40 30 EV=MIN 20 EV=MID 10 EV=MAX 0 500 1000 1500 80 70 60 50 40 30 20 10 0 2000 EV=MID EV=MAX 0 500 1000 1500 2000 IOUT [µA] DC/DC Q part output efficiency (VBAT = 5.0 V) DC/DC Q part output ripple voltage (VBAT = 5.0 V, reference value) 350 300 Ripple [mV] EFFIQ[%] 2000 EV=MIN IOUT [µA] 90 80 70 60 50 40 30 20 10 0 1500 DC/DC Q part output ripple voltage (VBAT = 3.0 V, reference value) 70 0 1000 IOUT [µA] EV=MIN EV=MID EV=MAX 0 500 1000 1500 2000 250 200 150 100 EV=MIN 50 EV=MID EV=MAX 0 0 IOUT [µA] 500 1000 1500 2000 IOUT [µA] Seiko Instruments Inc. 37 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series 4 3.5 3 2.5 2 1.5 1 0.5 0 DC/DC U part output voltage (VBAT = 3.0 V) VOUT3 [V] VOUT3 [V] DC/DC U part output voltage (VBAT = 2.4 V) EV=MIN EV=MID EV=MAX 0 200 400 600 IOUTX [µA] 800 1000 5 4 4 3 EV=MIN EV=MID 1 EV=MID EV=MAX EV=MAX 800 1000 3 2 VBAT=2.4V VBAT=3V VBAT=5V 0 0 200 400 600 IOUTX [µA] 800 1000 DC/DC U part output voltage (EV = Mid.) 0 4 4 VOUT3 [V] 5 3 2 200 400 600 IOUTX [µA] 800 1000 DC/DC U part output voltage (EV = Max.) 5 VBAT=2.4V VBAT=3V VBAT=5V 1 3 2 VBAT=2.4V VBAT=3V VBAT=5V 1 0 0 0 200 400 600 IOUTX [µA] 800 1000 0 DC/DC U part output voltage (VBAT = 3.0 V, VREFU = 2.90 V) 3.06 3.055 VOUT3 [V] 400 600 IOUTX [µA] 1 0 3.05 3.045 3.04 0 38 200 DC/DC U part output voltage (EV = Min.) 5 2 EV=MIN 0 VOUT3 [V] VOUT3 [V] DC/DC U part output voltage (VBAT = 5.0 V) VOUT3 [V] 4 3.5 3 2.5 2 1.5 1 0.5 0 20 40 EV Point 60 80 Seiko Instruments Inc. 200 400 600 IOUTX [µA] 800 1000 Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series 80 70 60 50 40 30 20 10 0 DC/DC U part output ripple voltage (VBAT = 2.4 V, reference value) Ripple [mV] EFFIU[%] DC/DC U part output efficiency (VBAT = 2.4 V) EV=MIN EV=MID EV=MAX 0 500 1000 IOUT [µA] 1500 2000 DC/DC U part output efficiency (VBAT = 3.0 V) Ripple [mV] EFFIU[%] EV=MIN EV=MID EV=MAX 20 0 0 500 1000 IOUT [µA] 1500 Ripple [mV] EFFIU[%] EV=MID EV=MAX 20 0 0 500 1000 IOUT [µA] 1500 1000 IOUT [µA] 1500 2000 EV=MIN EV=MID EV=MAX 500 1000 IOUT [µA] 1500 2000 DC/DC U part output ripple voltage (VBAT = 5.0 V, reference value) 80 EV=MIN 500 40 35 30 25 20 15 10 5 0 0 100 40 EV=MAX 2000 DC/DC U part output efficiency (VBAT = 5.0 V) 60 EV=MID DC/DC U part output ripple voltage (VBAT = 3.0 V, reference value) 80 40 EV=MIN 0 100 60 16 14 12 10 8 6 4 2 0 2000 4 3.5 3 2.5 2 1.5 1 0.5 0 EV=MIN EV=MID EV=MAX 0 Seiko Instruments Inc. 500 1000 IOUT [µA] 1500 2000 39 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series S-8335A200FT (1/200 duty. Unless otherwise specified, these graphs show typical data for TOPR = 25°C.) 3. DC/DC P part output voltage DC/DC Q part output voltage 16 12 VOUT2 [V] VOUT1 [V] 14 10 VBAT=3V 8 6 0 20 40 60 -12 -11 -10 -9 -8 -7 -6 -5 -4 80 VBAT=3V 0 20 EV Point DC/DC U part output voltage (VREFU = 2.91 V) VREFU=2.91V VXO [V] VOUT3 [V] 4.5 4 VBAT=3V VBAT=5V 3 0 20 40 60 4.5 4 3.5 3 2.5 2 1.5 1 0.5 0 EV=MID EV=MAX 0 80 2 2 1.5 1.5 VYO [V] VYO [V] 2.5 EV=MIN EV=MAX 500 1000 SOURCE CURRENT, 1500 1 2000 EV=MAX 0 0 IOUTY [µA] VREGTO [V] 2.1 2.08 2.06 2.04 2.02 2 1000 1500 2000 IOUT [µA] 40 −500 −1000 SINK CURRENT, 2.12 500 2000 EV=MID Regulator T part output voltage (VBAT = 3.0 V) 0 1500 IOUTX [µA] EV=MIN 0.5 EV=MID 0 1000 OP amplifier Y part output voltage (vs. sink current, VBAT = 3.0 V) 2.5 0 500 SOURCE CURRENT, OP amplifier Y part output voltage (vs. source current, VBAT = 3.0 V) 0.5 80 EV=MIN EV Point 1 60 OP amplifier X part output voltage (vs. source current, VBAT = 3.0 V) 5 3.5 40 EV Point Seiko Instruments Inc. −1500 IOUTY [µA] −2000 Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series DC/DC P part output ripple voltage (VBAT = 3.0 V, reference value) 70 90 80 70 60 50 40 30 20 10 0 60 Ripple [mV] EFFIP [%] DC/DC P part output efficiency (VBAT = 3.0 V) EV=MIN EV=MID EV=MAX 50 40 30 EV=MIN 20 EV=MID 10 EV=MAX 0 0 500 1000 1500 0 2000 500 IOUT [µA] 1500 2000 DC/DC Q part output ripple voltage (VBAT = 3.0 V, reference value) 120 80 70 60 50 40 30 20 10 0 100 Ripple [mV] EFFIQ [%] DC/DC Q part output efficiency (VBAT = 3.0 V) EV=MIN EV=MID 80 60 40 EV=MIN EV=MID EV=MAX 20 EV=MAX 0 0 500 1000 IOUT [µA] 1500 0 2000 DC/DC U part output efficiency (VBAT = 3.0 V) 500 1000 IOUT [µA] 1500 2000 DC/DC U part output ripple voltage (VBAT = 3.0 V, reference value) 60 100 50 Ripple [mV] 80 EFFIU[%] 1000 IOUT [µA] 60 EV=MIN 40 EV=MID 20 40 EV=MIN EV=MID EV=MAX 30 20 10 EV=MAX 0 0 0 500 1000 IOUT [µA] 1500 2000 0 500 1000 1500 2000 IOUT [µA] Seiko Instruments Inc. 41 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series 4. S-8335A160FT (1/160 duty. Unless otherwise specified, these graphs show typical data for TOPR = 25°C.) DC/DC Q part output voltage 14 13 -11 12 11 10 9 -9 -10 VOUT2 [V] VOUT1 [V] DC/DC P part output voltage VBAT=3V 8 7 6 -6 -4 20 40 EV Point 60 0 80 DC/DC U part output voltage (VREFU = 2.906 V) VXO [V] VREFU=2.906V VBAT=3V 4 VBAT=5V 3.5 3 2.5 2 1.5 60 80 EV=MIN 1 0.5 0 3 0 20 40 EV Point 60 EV=MAX 500 1000 SOURCE CURRENT, 1500 IOUTX [µA] 2000 OP amplifier Y part output voltage (vs. sink current, VBAT = 3.0 V) 2 1.5 1.5 VYO [V] 2 1 EV=MIN 0.5 EV=MID 0 80 OP amplifier Y part output voltage (vs. source current, VBAT = 3.0 V) 1 EV=MIN EV=MID 0.5 EV=MID EV=MAX EV=MAX 0 0 0 500 1000 SOURCE CURRENT, 1500 IOUTY [µA] 2000 0 Regulator T part output voltage (VBAT = 3.0 V) VREGTO [V] 40 EV Point 4 3.5 4.5 1.93 1.92 1.91 1.9 1.89 1.88 1.87 1.86 1.85 1.84 1.83 0 42 20 OP amplifier X part output voltage (vs. source current, VBAT = 3.0 V) 5 VOUT3 [V] VBAT=3V -7 -5 0 VYO [V] -8 500 1000 IOUT [µA] 1500 2000 Seiko Instruments Inc. −500 −1000 −1500 SINK CURRENT, IOUTX [µA] −2000 Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series DC/DC P part output ripple voltage (VBAT = 3.0 V, reference value) 80 90 80 70 60 50 40 30 20 10 0 Ripple [mV] EFFIP[%] DC/DC P part output efficiency (VBAT = 3.0 V) EV=MIN EV=MID EV=MAX 0 500 1000 IOUT [µA] 1500 30 20 EV=MIN 10 0 EV=MAX EV=MID 0 500 1000 IOUT [µA] 1500 2000 DC/DC Q part output ripple voltage (VBAT = 3.0 V, reference value) 140 80 70 60 50 40 30 20 10 0 120 Ripple [mV] EFFIQ[%] 50 40 2000 DC/DC Q part output efficiency (VBAT = 3.0 V) EV=MIN 100 80 60 EV=MID 40 EV=MAX 20 EV=MIN EV=MID EV=MAX 0 0 500 1000 IOUT [µA] 1500 2000 DC/DC U part output efficiency (VBAT = 3.0 V) 0 500 1000 IOUT [µA] 1500 2000 DC/DC U part output ripple voltage (VBAT = 3.0 V, reference value) 100 35 30 Ripple [mV] 80 EFFIU [%] 70 60 60 EV=MIN 40 EV=MID 20 EV=MAX 0 EV=MIN EV=MID EV=MAX 25 20 15 10 5 0 0 500 1000 IOUT [µA] 1500 2000 0 Seiko Instruments Inc. 500 1000 IOUT [µA] 1500 2000 43 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR Rev.6.0_01 S-8335 Series S-8335A120FT (1/120 duty. Unless otherwise specified, these graphs show typical data for TOPR = 25°C.) 5. DC/DC Q part output voltage 13 -10 12 -9 11 -8 VOUT2 [V] VOUT1 [V] DC/DC P part output voltage 10 9 VBAT=3V 8 -7 -6 -5 7 VBAT=3V -4 6 0 20 40 60 80 0 20 DC/DC U part output voltage (VREFU = 2.92 V) VBAT=3V VXO [V] VOUT3 [V] 4.5 VBAT=5V 3.5 3 20 40 60 4 3.5 3 2.5 2 1.5 1 0.5 0 80 EV=MIN EV=MID EV=MAX 0 EV Point 2 1.5 1.5 VYO [V] VYO [V] 2 1 EV=MIN EV=MID EV=MAX 500 1000 SOURCE CURRENT, 1000 IOUTX [µA] EV=MID EV=MAX 1500 2000 0 IOUTY [µA] 1500 −500 −1000 SINK CURRENT, 1.73 1.72 1.71 1.7 1.69 1.68 1.67 1.66 1.65 1.64 500 2000 EV=MIN 0.5 Regulator T part output voltage (VBAT = 3.0 V) 0 1500 1 0 0 VREGTO [V] 1000 OP amplifier Y part output voltage (vs. sink current, VBAT = 3.0 V) 0 2000 IOUT [µA] 44 500 SOURCE CURRENT, OP amplifier Y part output voltage (vs. source current, VBAT = 3.0 V) 0.5 80 OP amplifier X part output voltage (vs. source current, VBAT = 3.0 V) 5 0 60 EV Point EV Point 4 40 Seiko Instruments Inc. −1500 IOUTY [µA] −2000 Rev.6.0_01 STEP-UP, FOR LCD BIAS SUPPLY, 3-CHANNEL SWITCHING REGULATOR S-8335 Series 90 80 70 60 50 40 30 20 10 0 DC/DC P part output ripple voltage (VBAT = 3.0 V, reference value) Ripple [mV] EFFIP[%] DC/DC P part output efficiency (VBAT = 3.0 V) EV=MIN EV=MID EV=MAX 0 500 1000 1500 90 80 70 60 50 40 30 20 10 0 2000 EV=MIN EV=MID EV=MAX 0 500 IOUT [µA] 1500 2000 DC/DC Q part output ripple voltage (VBAT = 3.0 V, reference value) 140 80 70 60 50 40 30 20 10 0 120 Ripple [mV] EFFIQ [%] DC/DC Q part output efficiency (VBAT = 3.0 V) EV=MIN EV=MID 100 80 60 EV=MIN 40 EV=MID 20 EV=MAX EV=MAX 0 0 500 1000 1500 0 2000 500 1000 1500 2000 IOUT [µA] IOUT [µA] DC/DC U part output efficiency (VBAT = 3.0 V) DC/DC U part output ripple voltage (VBAT = 3.0 V, reference value) 100 35 80 30 Ripple [mV] EFFIU[%] 1000 IOUT [µA] 60 EV=MID 20 EV=MAX 15 40 EV=MIN 20 EV=MID 10 EV=MAX 5 0 EV=MIN 25 0 0 500 1000 1500 2000 0 IOUT [µA] 500 1000 1500 2000 IOUT [µA] Seiko Instruments Inc. 45 7.9±0.2 24 13 1 12 0.65 0.17±0.05 0.22±0.1 No. FT024-A-P-SD-1.0 TITLE TSSOP24-A-PKG Dimensions No. FT024-A-P-SD-1.0 SCALE UNIT mm Seiko Instruments Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.1 12.0±0.1 0.3±0.05 ø1.6±0.1 1.5±0.1 4.2±0.2 +0.4 6.5 -0.2 1 24 12 13 Feed direction No. FT024-A-C-SD-1.0 TITLE TSSOP24-A-Carrier Tape FT024-A-C-SD-1.0 No. SCALE UNIT mm Seiko Instruments Inc. 21.4±1.0 17.4±1.0 +2.0 17.4 -1.5 Enlarged drawing in the central part ø21±0.8 2.0±0.5 ø13.0±0.2 No. FT024-A-R-SD-1.0 TITLE TSSOP24-A-Reel FT024-A-R-SD-1.0 No. SCALE UNIT QTY. 2,000 mm Seiko Instruments Inc. • • • • • • The information described herein is subject to change without notice. Seiko Instruments Inc. is not responsible for any problems caused by circuits or diagrams described herein whose related industrial properties, patents, or other rights belong to third parties. The application circuit examples explain typical applications of the products, and do not guarantee the success of any specific mass-production design. When the products described herein are regulated products subject to the Wassenaar Arrangement or other agreements, they may not be exported without authorization from the appropriate governmental authority. Use of the information described herein for other purposes and/or reproduction or copying without the express permission of Seiko Instruments Inc. is strictly prohibited. The products described herein cannot be used as part of any device or equipment affecting the human body, such as exercise equipment, medical equipment, security systems, gas equipment, or any apparatus installed in airplanes and other vehicles, without prior written permission of Seiko Instruments Inc. Although Seiko Instruments Inc. exerts the greatest possible effort to ensure high quality and reliability, the failure or malfunction of semiconductor products may occur. The user of these products should therefore give thorough consideration to safety design, including redundancy, fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community damage that may ensue.
S-8335A200FT-TB-G 价格&库存
很抱歉,暂时无法提供与“S-8335A200FT-TB-G”相匹配的价格&库存,您可以联系我们找货
