TSPC-15S-485
TSPC-15S-485
    SENIX
    圆柱形,有螺纹
    TOUGHSONIC 30 1.5" NPT RS-485
TSPC-15S-485 数据手册
ToughSonic® 30 Level & Distance Sensor Windows PC or Button Setup, Waterproof, Multiple Outputs TSPC Non-Contact Ultrasonic Distance & Level Measurement sensors with SenixVIEW software put the power of ultrasonics in your hands yet retain the simplicity of push-button TEACH setup. You can quickly adjust, optimize, save and clone your applications without calibration! ToughSonic sensors contain a rugged transducer potted in a stainless steel housing for long life. Outputs respond to measured distance and non-contact technology means nothing touches your materials. Many applications exist in all industries. Contact Senix today to discuss your specific needs. SenixVIEW PC Software included! PC Setup Power! Multiple Outputs Distance Measurements • Long range, short dead band • Unaffected by optical factors like color and transparency • PC or button “teachable” setup • Narrow beam with adjustments to optimize performance • Temperature compensated Use SenixVIEW software (see separate data sheet) to select and adjust all interfaces, timing parameters, filters and modes. Then view, analyze or log data to optimize your application. In addition to the model's RS-232 or RS-485 serial data interface there are five simultaneous outputs, fully configurable with SenixVIEW. Free Functionality using adjustable interface features like switch hysteresis and time delays to build complete solutions such as pump or material flow controllers. Save cost by eliminating PLCs, delay circuits and time delay relays! 800 677 3649 Up to 30-ft. (9.1 m) maximum range in IP68 rated 1-1/2 in. NPT threaded housing Features Packaging & Performance • Quick mounting • Durable sealed housing for wet or dirty applications • Short & overload protected I/O • Multi-sensor synchronization • Adjustable sensitivity • Rear status indicators (3) Level or Volume TSPC-15S Series Distance-Proximity Analog Outputs (3) include 0-10 VDC and dual 4-20 mA current loops (sinking and sourcing). These outputs have user-selectable voltage/current ranges, adjustable endpoint distances, slope reversal, timing parameters and much more. Flexible configuration means fewer parts to stock and quick duplication! Higher volume OEM options are available. Switches (2) are SenixVIEW configurable as "PNP" or "NPN" type (sourcing or sinking). Each has adjustable set point, hysteresis, window, initial conditions, ON delay, OFF delay and loss of target response for ultimate flexibility. Push-button "teach" features provide for several common adjustments when a PC is not available. Dimension 802 489 7300 10516 Route 116 Suite 300, Hinesburg, VT 05461 USA Fax: 802 489 7400 e-mail: sales@senix.com web: senix.com Object Detection Senix® Corporation, 10516 Route 116 Suite 300, Hinesburg, VT 05461 USA Phone: 800 677 3649 or 802 489 7300 FAX: 802 489 7400 Web: senix.com e-mail: sales@senix.com ® ToughSonic 30 Level & Distance Sensor Specifications Optimum Range Deadband Case Material Temperature Humidity Compensation Resolution Repeatability Update Rate Voltage Output Current Loop #1 Current Loop #2 Sinking Switch Sourcing Switch RS-232, RS-485 SYNC feature Objects Connections 20 ft. (6.1 m) Max Range 30 ft. (9.1 m) Typ. < 10 in. (25.4 cm) Adjustment Button "teach" or SenixVIEW 316 stainless steel Configuration Stored in non-volatile memory -40 to 158 F (-40 to 70 C) Outputs Five selectable, plus serial data 0 to 100% operating Transducer Ruggedized piezoelectric Temperature compensated Protection NEMA-4X, NEMA-6P, IP68 Serial data: 0.0068 in. (0.172 mm); Analog:4099 steps (0-10 VDC), 3279 steps (4-20 mA) Nominal 0.2% of range @ constant temp. Affected by target, distance, environment 10 Hz (100 ms), SenixVIEW adjustable; affected by SenixVIEW filter selections 0-10, 0-5 VDC or PC customized; 10 mA max. (*) Current sourcing 4-20 mA or PC customized, max. loop 450Ω (*) Current sinking 4-20 mA or PC customized, max. loop 450Ω (*) 150 mA max. @ 40 VDC max., teachable set point & polarity, fault indication 150 mA max. @ input voltage, teachable set point & polarity, fault indication Modbus protocol, 9600-115200 baud (selectable), 8 data bits, 1 stop, no parity Permits up to 32 sensors to operate in close proximity without interaction Target Requirements Detects flat or curved objects. Surface must reflect ultrasound to sensor Max. Distance Affected by size, shape, orientation of target (sound level reflected back to sensor), environment Restrict use to Optimum Range when using over a wide range of environmental conditions Orientation Optical Flat surfaces should be oriented perpendicular to sensor output beam Unaffected by target color, transparency, light, or other optical characteristics Cable Connection Power Ground Voltage Output * Current Loop Output * Current Loop Output * Switch #1 Output Switch #2 Output RS-232 out / RS-485RS-232 in / RS-485+ Wire Brown Blue Violet Green Orange Black White Gray Yellow Description 10-30 VDC @ 70 mA maximum; Typical: 45 mA @ 24 VDC (** ) Power and interface common 0-10 VDC, 0-5 VDC or custom end values between 0 and 10 VDC 4-20 mA sourcing (adjustabled end values between 4 and 20 mA) 4-20 mA sinking (adjustabled end values between 4 and 20 mA) Sinking ("NPN") or Sourcing ("PNP"), user selected Sinking ("NPN") or Sourcing ("PNP"), user selected Serial data connection (depends on model - see model selection) Serial data connection (depends on model - see model selection) (*) Analog outputs share common distance endpoints. Both 4-20 mA outputs share the same adjustable max / min end values. The maximum loop resistance is derated below 15 VDC input voltage. (**) At default update rate. Output currents not included. Part Numbers Model Number Description TSPC-15S-485 Analog, switch and RS-485 serial interface (allows addressable multi-sensor networks) TSPC-15S-485A * TSPC-15S-232 TSPC-15S-232A * Same as above but with only RS-485 serial data interface * Analog, switch and RS-232 serial data interface (PC COM port compatible) Same as above but with only RS-232 serial data interface * * Models with "A" suffix are data communications only; Analog & switch outputs, pushbutton and interface LEDs are removed. Senix also offers interconnection, communications, mounting and display accessories. Mechanical Dimensions Mounting: 1.5 inch NPT thread, top or bottom Attached Cable: 6.5ft (2 m) Total Weight: 22.6 oz. (0.64 kg) 1 July 2019 Rev L Copyright Senix Corporation. All rights reserved. Specifications subject to change without notice. This Senix product is not recommended for applications with hazardous or explosive materials, or as a primary device for personal safety.
TSPC-15S-485 价格&库存
很抱歉,暂时无法提供与“TSPC-15S-485”相匹配的价格&库存,您可以联系我们找货
