TSPC-25P-485
TSPC-25P-485
    SENIX
    圆柱形,有螺纹
    TOUGHSONIC 50 PVC 2.5"NPT RS-485
TSPC-25P-485 数据手册
ToughSonic® 50 Level & Distance Sensor Windows PC Setup, Waterproof, Multiple Outputs TSPC Non-Contact Ultrasonic Distance & Level Measurement sensors and SenixVIEW software put the power of ultrasonics in your hands. Quickly adjust, optimize, save and clone your setups without calibration! These sensors are housed in a single small potted enclosure for environmental durability and long life. They mount at a distance from a liquid or solid material and measure distance to the surface. Sensor outputs respond to that measured distance. Applications exist in many industries, and include pump control, bulk inventory, high/low level alarms, river level for flood detection and much more. Features Distance Measurements • Long range, short dead band • Continuous and point level • Water or non-caustic materials • Adjustable by computer (PC) software, locally or remotely • Narrow beam with adjustments to optimize performance Up to 50-ft. (15.2 m) maximum range in IP68 rated 316 stainless or PVC housing TSPC-21S-xxx (Clamp Mount) SenixVIEW PC Software included! PC Setup Power! Use SenixVIEW software (see separate data sheet) to select and adjust all interfaces, timing parameters, filters and modes. Then view, analyze or log data to optimize your application. Level or Volume 800 677 3649 Distance-Proximity Model Options Both stainless and PVC housings are offered for flexibility. All have multiple analog and switch outputs plus a serial data interface for PC configuration or other data communications (serial data only models are also available). Flange not included Packaging & Performance • Survives submersion • Temperature compensation for improved accuracy • Short & overload protected I/O • Adjustable sensitivity • Rear status indicators (3) Free Functionality using adjustable interface features like switch hysteresis and time delays to build complete solutions such as pump or material flow controllers. Save cost by eliminating PLCs, delay circuits and time delay relays! TSPC-21SRM-xxx (Rear Thread Mount) TSPC-21SRM-xxx (Rear Mount) Flexible configuration means fewer parts to stock and quick duplication! Application setups can be stored on your PC and later recalled. Using a single inventory part you can quickly clone replacement sensors for any number of applications with re-calibration! TSPC-25P-xxx (PVC housing) Environmental Object Detection 802 489 7300 10516 Route 116 Suite 300, Hinesburg, VT 05461 USA Fax: 802 489 7400 e-mail: sales@senix.com web: senix.com Flange not included Senix® Corporation, 10516 Route 116 Suite 300, Hinesburg, VT 05461 USA Phone: 800 677 3649 or 802 489 7300 FAX: 802 489 7400 Web: senix.com Specifications Optimum Range Deadband Case Material Temperature Humidity Compensation Resolution Repeatability Update Rate Voltage Output Current Loop #1 Current Loop #2 Sinking Switch Sourcing Switch RS-232, RS-485 SYNC feature Objects Connections e-mail: sales@senix.com 33 ft. (10 m) Max Range 50 ft. (15.2 m) Typ. < 12 inches (30.3 cm) Adjustment SenixVIEW software (included) 316 stainless steel or PVC Configuration Stored in non-volatile memory -40 to 158 F (-40 to 70 C) Outputs Five selectable, plus serial data 0 to 100% operating Transducer Ruggedized piezoelectric Temperature compensated Protection NEMA-4X, NEMA-6P, IP68 Serial data: 0.0135 in. (0.3438 mm); Analog steps: 4099 (0-10 VDC), 3279 (4-20 mA) Nominal 0.2% of range @ constant temp. Affected by target, distance, environment 5 Hz (200 ms), SenixVIEW adjustable; affected by SenixVIEW filter selections 0-10, 0-5 VDC or PC customized; 10 mA max. (*) Current sourcing 4-20 mA or SenixVIEW adjustable, max. loop 450Ω (*) Current sinking 4-20 mA or SenixVIEW adjustable, max. loop 450Ω (*) 150 mA max. @ 40 VDC max., adjustable set point & polarity, fault indication 150 mA max. @ input voltage, adjustable set point & polarity, fault indication Modbus protocol, 9600-115200 baud (selectable), 8 data bits, 1 stop, no parity Permits up to 32 sensors to operate in close proximity without interaction Target Requirements Detects flat or curved objects. Surface must reflect ultrasound back to sensor. Max. Distance Affected by size, shape, orientation of target (sound level reflected back to sensor), environment Restrict use to Optimum Range when using over a wide range of environmental conditions Orientation Optical Flat surfaces should be oriented perpendicular to sensor output beam Unaffected by target color, transparency, light, or other optical characteristics Cable Connection Power Ground Voltage Output * Current Loop Output * Current Loop Output * Switch #1 Output Switch #2 Output RS-232 out / RS-485RS-232 in / RS-485+ Wire Brown Blue Violet Green Orange Black White Gray Yellow Description 10-30 VDC @ 70 mA maximum; Typical: 45 mA @ 24 VDC (**) Power and interface common 0-10 VDC, 0-5 VDC or custom end values between 0 and 10 VDC 4-20 mA sourcing (adjustabled end values between 4 and 20 mA) 4-20 mA sinking (adjustabled end values between 4 and 20 mA) Sinking ("NPN") or Sourcing ("PNP"), user selected Sinking ("NPN") or Sourcing ("PNP"), user selected Serial data connection (depends on model - see model selection) Serial data connection (depends on model - see model selection) (*) Analog outputs share common distance endpoints. Both 4-20 mA outputs share the same adjustable max / min end values. The max. loop resistance is derated below 15 VDC input voltage. (**) At default update rate. Output currents not included. Part Numbers Dimensions Model Number TSPC-21S-232 TSPC-21S-485 TSPC-21SRM-232 TSPC-21SRM-485 TSPC-25P-232 TSPC-25P-485 Description Clamp mounted, 316SS housing, serial RS-232 interface (PC COM port compatible) Clamp mounted, 316SS housing, serial RS-485 interface (allows multi-sensor networking) Rear mount 1.5" NPT thread, SS316 housing, serial RS-232 interface (PC COM port compatible) Rear mount 1.5" NPT thread, SS316 housing, serial RS-485 interface (allows multi-sensor networking) Threaded 2.5" NPT front and rear, PVC housing, serial RS-232 interface (PC COM port compatible) Threaded 2.5" NPT front & rear, PVC housing, serial RS-485 interface (allows multi-sensor networking) ToughSonic 50 models are also available with only the serial data interface Senix also offers interconnection, communication, mounting, and display components Model TSPC-21S 21S with Rear Mount Length x Diameter 4.8 in (122 mm) x 2.312 in (59mm) 5.9 in (150 mm) x 2.50 in (63 mm) Weight 29.9 oz (0.82 kg) 31.5 oz (0.89 kg) TSPC-25P 5.0 in (127 mm) x 2.5 in (63.5mm) 29.1 oz (0.82 kg) All have 6.5 ft (2m) shielded cable attached. Other lengths available 1 July 2019 Rev L Copyright Senix Corporation. All rights reserved. Specifications subject to change without notice. This Senix product is not recommended for applications with hazardous or explosive materials, or as a primary device for personal safety.
TSPC-25P-485 价格&库存
很抱歉,暂时无法提供与“TSPC-25P-485”相匹配的价格&库存,您可以联系我们找货
