TSPC-30S1-485
TSPC-30S1-485
    SENIX
    圆柱形,有螺纹-M30
    TOUGHSONIC 14 M30 RS-485
TSPC-30S1-485 数据手册
ToughSonic®/PC Distance Sensor Windows PC or Button Setup, Waterproof, Multiple Outputs TSPC Button TEACH or PC Configured Non-Contact Ultrasonic Distance Measurement Level or Height sensors and SenixVIEW software put the power of ultrasonics in your hands yet retain the simplicity of push-button TEACH setup. You can quickly adjust, optimize, save and clone your applications without calibration! ToughSonic sensors contain a rugged transducer potted in a stainless steel housing for long life. Outputs respond to measured distance and non-contact technology means nothing touches your materials. Many applications exist in all industries. Contact Senix today to discuss your specific needs. TSPC-30S1 Series Up to 14-ft. (4.3 m) maximum range in IP68 rated 30 mm threaded housing SenixVIEW PC Software included! Features PC Setup Power! Output Selection Distance Measurements • Long range, short dead band • Unaffected by optical factors like color and transparency • PC or button “teachable” setup • Narrow beam with adjustments to optimize performance • Temperature compensated Packaging & Performance • Quick mounting • Durable sealed housing for wet or dirty applications • Short & overload protected I/O • Multi-sensor synchronization • Adjustable sensitivity • Rear status indicators (3) Free Functionality Use adjustable interface features like switch hysteresis and time delays to build complete solutions such as pump or material flow controllers. Save cost by eliminating PLCs, delay circuits and time delay relays! Use SenixVIEW software (see separate data sheet) to select and adjust all interfaces, timing parameters, filters and modes. Then view, analyze or log data to optimize your application. In addition to the model's serial data interface there are two SenixVIEW selected outputs that can be analogs or switches to suit your application. All outputs have configurable features including ranges, target responses and time delays. Voltage & Current Loop Select voltage, current or both in standard (0-10 VDC, 4-20 mA) or custom ranges. The outputs are fully configurable and the analog slope can be positive or negative with distance. Switches One or two switches can be selected. Either or both can be "PNP" or "NPN" type (sourcing or sinking). Each has adjustable set point, hysteresis, window, initial conditions, ON delay, OFF delay and loss of target response for ultimate flexibility. Distance-Proximity Several push-button "teach" features also provide common adjustments without the PC. Stock, repairs, OEMs Flexible configuration means fewer parts to stock and quick duplication! Higher volume OEM options are available. Dimension A-Tech Instruments Ltd. sales@a-tech.ca www.a-tech.ca Toronto: 416 754 7008 Montreal: 514 695 5147 Toll Free: 1 888 754 7008 Object Detection Senix® TSPC-30S1 ToughSonic® Distance Sensor Specifications Optimum Range Case Material Temperature Humidity Compensation Resolution Repeatability Update Rate Voltage Output Current Loop Sinking Switch Sourcing Switch Output Select RS-232, RS-485 SYNC feature 4 in. - 10 ft. (102 mm - 3 m) Max Range 14 feet (4.3 meters) 316 stainless steel Adjustment Button "teach" or SenixVIEW -40 to 158 F (-40 to 70 C) Configuration Stored in non-volatile memory 0 to 100% operating Transducer Ruggedized piezoelectric Temperature compensated Protection NEMA-4X, NEMA-6P, IP68 Digital: 0.0034 in. (0.086 mm); Analog:4099 steps (over full 0-10 VDC or 4-20 mA) Nominal 0.2% of range @ constant temp. Affected by target, distance, environment 20 Hz (50 ms), SenixVIEW adjustable; also affected by SenixVIEW filter selections 0-10, 0-5 VDC or PC customized, 10 mA max; Push-button teachable endpoints 4-20 mA or PC customized, current sourcing, max. loop 450Ω, teachable endpoints 150 mA max. @ 40 VDC max., teachable set point & polarity, fault indication 150 mA max. @ input voltage, teachable set point & polarity, fault indication Defaults are voltage & current loop; see Connections below for additional info Modbus protocol, 9600 to 115200 baud (selectable), 8 data bits, 1 stop, no parity Permits up to 32 sensors to operate in close proximity without interaction Target Requirements Objects Max. Distance Orientation Optical Connections Part Numbers Detects flat or curved objects. Surface must reflect ultrasound back to sensor. Affected by size, shape, orientation of target (sound level reflected back to sensor) Flat surfaces should be oriented perpendicular to sensor output beam Unaffected by target color, light, transparency or other optical characteristics Cable Connection Wire Description Power Brown 10-30 VDC @ 60 mA maximum; Typical: 45 mA @ 24 VDC (**) Ground Blue Power and interface common Voltage Output White * 0-10 VDC, 0-5 VDC or custom end values between 0 and 10 VDC Current Loop Output Black * 4-20 mA or user adjusted end values between 4 and 20 mA Switch #1 Output Black * Sinking ("NPN") or Sourcing ("PNP"), user selected Switch #2 Output White * Sinking ("NPN") or Sourcing ("PNP"), user selected RS-232 out / RS-485Gray Serial data connection (depends on model - see part numbers) RS-232 in / RS-485+ Yellow Serial data connection (depends on model - see part numbers) (*) Outputs on the black and white wires are SenixVIEW selected. The black wire options are 4-20 mA current loop or switch. White wire options are 0-10 VDC or switch. Switches can be sourcing or sinking. Max current loop resistance is derated below 15 VDC input voltage. (**) At default update rate. Output currents not included. Sensitivity reduced below 15 VDC input voltage. Model Number TSPC-30S1-232 TSPC-30S1-485 Description Serial RS-232 interface (PC COM port compatible) Serial RS-485 interface (allows addressable multi-sensor networks) Senix also offers interconnection, communications, mounting, and display components Dimensions Mechanical Dimensions are in inches (mm) Mounting Hole: 1.2 in. (30.5 mm) diameter Standard Cable: 6.5ft (2m) Ships with instructions and two 30mm stainless mounting nuts (other options available) Total Weight: 10.40 oz. (0.29 kg) January 2014 Rev T2 Senix products are not recommended for applications with hazardous or explosive materials, or as a primary device for personal safety. Copyright 2008-2014, Senix® Corporation. All rights reserved. Printed in U.S.A. A-Tech Instruments Ltd. sales@a-tech.ca www.a-tech.ca Toronto: 416 754 7008 Montreal: 514 695 5147 Toll Free: 1 888 754 7008
TSPC-30S1-485 价格&库存
很抱歉,暂时无法提供与“TSPC-30S1-485”相匹配的价格&库存,您可以联系我们找货
