IAR1-1-52-15.0-AC-00
    SENSATA(森萨塔)
    CIR BRKR MAG-HYDR
IAR1-1-52-15.0-AC-00 数据手册
Introduction | 49 Poles & Terminals | 50 Configurations | 53 Delay Curves & Specs | 54 Operating Characteristics | 55 Hardware | 56 Decision Tables | 57 IAR/IUR/IER/CUR/CER [1RU] IAR/IUR/IER/CUR/CER Series “1RU” Magnetic Circuit Protectors IAR/IUR/IER/CUR/CER Series “1RU” Hydraulic Magnetic Circuit Protectors FEATURES • UL1077, TÜV, UL489A approved • Designed to fit in a “1RU” application • 5,000 AIC interrupt capacity (65/80VDC, 120/240VAC) • Series or mid-trip with auxiliary switch alarm options • Various delays including motor start • 1 to 2 poles, multiple termination options INTRODUCTION The Airpax™ IAR/IUR/IER/CUR/CER series is a snap-acting hydraulic-magnetic circuit breaker / protector that combines power switching and accurate, reliable circuit protection in one aesthetically pleasing, “1U” or “1RU” sized package. Designed for rack mount applications, the IAR/IUR/IER/CUR/CER series allows efficient use of rack space without sacrificing performance via proven hydraulic-magnetic technology that provides consistent operation from -40°C to 85°C, with a circuit interrupt capacity up to 5,000 AIC at 65/80 VDC and120/240 VAC. Available in series trip and mid-trip configurations, with auxiliary alarm switch options to provide monitoring of critical circuits. The CER series circuit breaker provides the necessary ratings for wireless and wired applications while meeting UL489A and TÜV requirements for approval. APPROVALS 49 Ratings Voltage A.I.C. Agency Approvals Poles 2 to 50 amps 65 VDC 5,000 UL489A & C-UL 1 2 to 50 amps 80 VDC 5,000 TÜV to EN60934 1 2 to 50 amps 250 VAC 2,000 UL1077 & TÜV to EN60934 1 2 to 50 amps 80 VDC 5,000 UL489A & TÜV to EN60934 2 2 to 30 amps 120 / 240 VAC 5,000 UL1077, C-UL, TÜV to EN60934 2 IAR/IUR/IER/CUR/CER Series - Introduction http://airpax.sensata.com/ IAR/IUR/IER/CUR/CER [1RU] TOGGLE ACTUATION MAGNETIC CIRCUIT PROTECTORS Panel Mounting Detail, Single Pole 0.755 [19.18] POLES & TERMINALS The Airpax™ IAR/IUR/IER/CUR/CER series is available with one or two poles with various bullet, stud and screw terminals. Engineered for safe, sure operation, the toggle handles may be specified in blue, white, red, orange, green, yellow or black. Single Pole Two Pole (with or without two handles) 2x 6-32 THREAD 0.140 [3.56] DEEP M3 ISO THREAD OPTIONAL 0.311 [7.90] 0.154 [3.91] 0.832 [21.13] 1.146 [29.11] 0.154 [3.91] 0.832 [21.13] 0.325 [8.26] 0.152 [3.86] 0.755 [19.18] 4X 0.156 Ø [3.96] 1.146 0.842 [29.11] [21.39] 0.152 [3.86] 1.146 [29.11] 0.750 [19.05] Panel Mounting Detail, Two Pole, Two Handles 0.325 [8.26] 0.250 [6.35] 1.530 [38.86] 0.400 [10.16] Auxiliary switch wires not shown for clarity http://airpax.sensata.com/ 0.156 Ø [3.96] 1.515 MAX [38.48] 0.750 MAX [19.05] 0.400 [10.16] 0.842 [21.39] Panel Mounting Detail, Two Pole, One Handle 2x 6-32 THREAD 0.140 [3.56] DEEP M3 ISO THREAD OPTIONAL 0.311 [7.90] 2X 1.146 [29.11] 1.146 [29.11] 4X 0.156 Ø [3.96] 0.842 [21.39] 0.152 [3.86] 0.750 [19.05] IAR/IUR/IER/CUR/CER Series - Poles & Terminals 50 Single Pole AUXILIARY SWITCH OUTPUT LEADS Two Pole (with or without 2nd handle) AUXILIARY SWITCH OUTPUT LEADS 0.297 [7.55] 1.90 [0.075] SEE TERMINAL OPTIONS 32° 1.458 MAX [37.03] 32° 0.250 RAD. x2 [6.35] 0.860 [21.83] SEE TABLE DIM. “A” 4.678 [118.81] 0.605 [15.37] SEE TABLE DIM. “B” DIMENSIONS 51 Bullet Type Dim. “A” Dim. “B” Dim. “C” 1/4” Bullet 4.778 [121.35] 5.019 [127.48] Ø 0.251 ± 0.001 Ø [6.38 ± 0.03] 5/16” Bullet 4.851 [123.22] 5.092 [129.35] Ø 0.312 ± 0.001 Ø [7.92 ± 0.03] IAR/IUR/IER/CUR/CER Series - Poles & Terminals Stud Type Dim. “E” Dim. “F” 10-32 0.545 [13.84] 0.622 [15.81] M5 0.510 [12.95] 0.588 [14.92] http://airpax.sensata.com/ 1/4” Bullet Terminals 0.265 [6.73] BULLET RECEIVING HOLE DIMENSIONS x2 DIM. “C” WITH 0.050 [1.27] x 45° CHAMFER ON ENTRY EDGE FINISH INSIDE SURFACE OF HOLES 0.860 ± 0.13 [21.84 ± 0.005] Two Pole Bullet Terminal Mounting Detail 0.860 ± 0.13 [21.84 ± 0.005] IAR/IUR/IER/CUR/CER [1RU] Single Pole Bullet Terminal Mounting Detail 0.275 [6.98] 0.205 [5.21] 5/16” Bullet Terminals 0.265 [6.73] BULLET RECEIVING HOLE DIMENSIONS x4 DIM. “C” WITH 0.050 [1.27] x 45° CHAMFER ON ENTRY EDGE FINISH INSIDE SURFACE OF HOLES 0.275 [6.98] 0.205 [5.21] 0.750 ± 0.13 [19.05 ± 0.005] 10-32 or M5 Screw Terminals 0.265 [6.73] 0.275 [6.98] 0.205 [5.21] 10-32 or M5 Stud Terminals 0.297 [7.54] DIM. “E” 0.860 [21.84] DIM. “F” http://airpax.sensata.com/ IAR/IUR/IER/CUR/CER Series - Poles & Terminals 52 10000 DELAY 51 1000 TIME IN SECONDS TIME IN SECONDS CONFIGURATIONS MAY TRIP 100 10000 10 1000 1 100 MAY TRIP Series Trip The most popular configuration for magnetic protectors is the series trip where the sensing coil and the contacts are in series with the load being protected. In addition to providing conventional overcurrent protection, it is simultaneously used as an on-off switch. .1 10 .01 1 .001 .1 0 100 150 200 125 300 100 150 200 125 300 .01 Single Pole, Series Trip Two Pole, Series Trip LOAD DELAY 51 .001 0 LOAD 400 500 600 700 800 900 1000 800 900 1000 900 1000 900 1000 800 900 1000 800 900 1000 900 1000 PERCENT OF RATED CURRENT 400 500 600 700 PERCENT OF RATED CURRENT 10000 Two Pole, Series Trip TIME IN SECONDS TIME IN SECONDS 100 10000 Two Pole, Series Trip Mid-Trip This is furnished as an integral part of a series pole in single LOAD LOAD or, multi-pole IsolatedLINE electrically from the LINE assemblies. Mid-Trip protector­s circuit, the switch works in unison with the power contacts and location of the LOADprovides indication at a remote LOAD 10000 protector’s ON-OFF status. LOAD 10 1000 .01 1 MAY TRIP .1 10 LOAD LINE LINE LOAD MAY TRIP Auxiliary Switch LINE LINE This is .001 furnished as200an300 integral part of single 0 100 150 400 500 600 a series 700 800pole 900in 1000 C 125 Breaker shown in ON position or Breaker shown in mid-trip position PERCENT OF RATED CURRENT or, multi-pole assemblies. Isolated electrically from the Auxiliary Switch NO manually turned OFF position (electrically tripped) protector­s circuit, theNCswitch works in unison with the power 10000 LOAD contacts and provides indication at a remote location of the protector’s ON-OFF status. LINE 1000 DELAY 52 TIME IN SECONDSTIME IN SECONDS 100 10000 C Breaker shown in OFF position NO Auxiliary Switch NC LOAD MAY TRIP 10 1000 1 100 LINE 100 150 200 125 300 100 150 200 125 300 600 700 800 400 500 600 700 53 800 PERCENT OF RATED CURRENT DELAY 53 .1 10 .001 .1 0 400 500 600 700 PERCENT OF RATED CURRENT .01 .001 0 400 500 600 700 PERCENT OF RATED CURRENT 10000 1000 DELAY 59 DELAY 59 1 100 .1 10 NC .01 1 LINE .001 .1 0 detail mounting tolerance 0.005 [0.13] 100 150 200of ± 300 400 500 600 700 shown in OFF position unless otherwise125 noted BreakerPERCENT OF RATED CURRENT 800 900 1000 .01 .001 300 500 1 100 10 1000 DELAY 52 .01 1 53 100 150 200 125 400 DELAY PERCENT OF RATED CURRENT 100 10000 mounting detail tolerance ofC ± 0.005 [0.13]in OFF position Breaker shown unless otherwise noted NO .1 10 0 300 100 150 200 125 .01 1 Breaker shown in ON position or Breaker shown in mid-trip position C C .001 manually (electrically tripped) 100 OFF 150 position 200 300 400 Switch 500 700 800 900 1000 NO .1 0 turned NO 600 Auxiliary 125 NC NC CURRENT PERCENT OF RATED .01 0 10 1000 C Breaker shown in mid-trip position NO (electrically tripped) NC LOAD 10000 .001 .1 100 10000 .001 DELAY 51 LINE C 1 Breaker NO100 shown in ON position or manually turned OFF position Mid-Trip NC .01 1 1000 .01 LOAD LINE .1 10 TIME IN SECONDSTIME IN SECONDS TIME IN SECONDSTIME IN SECONDS 10000 MAY TRIP Mid-Trip NO LINE NC 100 DELAY 51 C NO LINE NC 1 100 TIME IN SECONDSTIME IN SECONDS 1000 C DELAY 52 MAY TRIP 10 1000 Single Pole, Series Trip MAY TRIP LINE MAY TRIP LINE DELAY 52 MAY TRIP MAY LOAD MAY TRIP 1000 LOAD MAY TRIP MAY Single Pole, Series Trip .001 .1 0 100 150 200 125 300 100 150 200 125 300 400 500 600 700 800 PERCENT OF RATED CURRENT .01 125 IAR/IUR/IER/CUR/CER Series PERCENT OF RATED CURRENT - Configurations 0 100 150 200 300 400 mounting detail tolerance of ± 0.005 [0.13] 500 600 700 800 900 1000 .001 0 400 600 700 800 900 1000 http://airpax.sensata.com/ 500 PERCENT OF RATED CURRENT 10000 TIME IN SECONDS 10 1 .1 .01 MAY TRIP 1000 100 150 200 125 TIME IN SECONDS TIME IN SECONDS TIME IN SECONDS 100 10000 400 500 600 .1 10 1000 800 900 1000 DELAY 61 Trip Indication 1 10000 The operating handle moves forcibly and positively to the OFF .1 position on 1000overload. DELAY 69 DELAY 63 .01 1001 .01 300 400 500 600 700 800 900 1000 PERCENT OF RATED CURRENT .01 1 0 0 10 1000 MAY TRIP TIME IN SECONDSTIME IN SECONDSTIME IN SECONDS 100 10000 .001 100 150 200 125 MAY TRIP 1000 .01 100 150 200 125 300 400 500 600 700 800 PERCENT OF RATED CURRENT DELAY 300 400 500 600 700 900 1000 62 800 900 1000 PERCENT OF RATED CURRENT DELAY 63 .001 .1 0 100 150 200 125 300 100 150 200 125 300 MAY TRIP .01 1 300 400 500 600 700 800 900 1000 800 900 1000 800 900 1000 PERCENT OF RATED CURRENT 400 500 600 700 PERCENT OF RATED CURRENT .01 10000 .001 0 1000 400 500 600 700 PERCENT OF RATED CURRENT DELAY 69 TIME IN SECONDS 100 MAY TRIP 10 1 .01 0 100 150 200 125 DELAY 69 3,750 VAC 600 VAC 3,750 between main circuit breaker terminal and auxiliary switch terminal .1 Shock .01 Shall not trip when tested per MIL-STD-202, method 213, test condition .001 1 with 100% rated current applied to delayed units, except 100 150 200 300 400 500 600 700 800 900 1000 90% current 0in plane 4, (i.e. handle down). Instantaneous units shall 125 PERCENT OF RATED CURRENT have 80% rated current applied in all planes. Vibration Shall not trip when vibrated per MIL-STD-202, method 204, test condition A with 100% rated current applied to delayed units and 80% rated current to instantaneous units. Endurance In many applications contact wear due to the electrical load determines unit life. At maximum electrical ratings, the IAR/IUR/IER/ CUR/CER can perform 10,000 operations at rated current and voltage at a maximum rate of 6 operations per minute. .1 .001 Dielectric.01Strength 10000 Shall withstand AC voltage 60 Hz, for 60 seconds between all .001 0 100 150 200 300 400 500 600 700 800 900 1000 electrically isolated 125 terminals as described below. PERCENT OF RATED CURRENT TIME IN SECONDS DELAY 69 100 150 200 125 PERCENT OF RATED CURRENT 1 Insulation Resistance Not less than 100 megaohms at 500Vdc. .1 Series, switch only : 100 Auxiliary switches : 10 Series w/ auxiliary switch : 1 .01 1 100 .001 .1 10 0 125 1000 1 100 10000 .1 10 1000 MAY TRIP 100 150 200 125 100 Ambient Operation Operates .001 normally in200 temperatures +85°C. 10 0 100 150 300 400 500between 600 700–40° 800 C and 900 1000 MAY TRIP .001 .1 0 10 10000 .001 .1 10000 .001 Trip Free 0 100125150 200 300 400 500 600 700 800 900 1000 PERCENT OF RATED CURRENT 1000 DELAY 62 Will trip open on overload, even when forcibly held on. This prevents operator from damaging the circuit by holding handle in the ON 100 position. 10 DELAY 62 MAY TRIP 1 100 10000 700 PERCENT OF RATED CURRENT MAY TRIP 10 1000 300 MAY TRIP 0 TIME IN SECONDS 10000 .001 MAY TRIP 100 DELAY 62 DC, 50/60Hz Delay Curves (typ) A choice of10 delays is offered for DC and 50/60Hz applications. Delays 59 and 69 provide fast-acting, instantaneous trip and are often used 1 to protect sensitive electronic equipment (not recommended where known inrush exists). Delays 51 and 61 have a short delay for general .1 purpose applications. Delays 52 and 62 are long enough to start .01 certain types of motors and most transformer and capacitor loads. TIME IN SECONDS TIME IN SECONDS 100 DELAY CURVES & SPECIFICATIONS 1000 DELAY 61 MAY TRIP 1000 IAR/IUR/IER/CUR/CER [1RU] 10000 300 400 500 600 700 800 900 1000 PERCENT OF RATED CURRENT http://airpax.sensata.com/ IAR/IUR/IER/CUR/CER Series - Delay Curves & Specifications 54 OPERATING CHARACTERISTICS MAXIMUM DCR AND IMPEDANCE (APPROXIMATE VALUES) Inrush Pulse Tolerance Many circuit protector applications involve a transformer turn-on, an incandescent lamp load, or a capacitor charge from a DC source. Each of these applications has one common factor: a steep transient of very high current amplitude and short duration. This takes the form of a spike or a single pulse and is the cause of most nuisance tripping associated with magnetic circuit breakers. The IAR/IUR/IER/CUR/CER series will withstand, without tripping, a single pulse of 8 milliseconds duration (half sine wave configuration) and peak amplitude of 10 times its rating. Current Ratings (Amps) DC Resistance (Ohms) 51, 52, 53, 59 50/60Hz Impedance (Ohms) 61, 62, 63, 69 2.0 0.027 0.038 3.0 0.074 0.098 6.0 0.037 0.048 7.5 0.025 0.029 15.0 0.010 0.011 32.0 0.003 0.003 40.0 0.003 0.003 50.0 0.0024 0.0025 Tolerance: 2 to 2.5 amps ±20%; 2.6 to 20 amps ± 25%; 21 to 50 amps ±50% *Consult factory for special values and for coil impedance of delays not shown AUXILIARY SWITCH RATING APPROXIMATE WEIGHT PER POLE 10.0 amps @ 250 VAC, 60 Hz 3.0 amps @ 50 VDC 1.0 amps @ 80 VDC PULSE TOLERANCE 1 pole 134 grams Delay Pulse Tolerance 2 pole 263 grams 61, 62, 63 10 Times Rated Current PERCENTAGE OF RATED CURRENT VS TRIP TIME IN SECONDS AT +25°C (APPROXIMATE VALUES) 55 Delay 100% 125% 150% 200% 400% 600% 800% 1000% 51 No Trip 0.5 to 6.5 0.3 to 3 0.1 to 1.2 0.031 to 0.5 0.011 to 0.25 0.004 to 0.1 0.004 to 0.08 52 No Trip 2 to 60 1.8 to 30 1 to 10 0.15 to 2 0.015 to 1 0.008 to 0.5 0.006 to 0.1 53 No Trip 80 to 700 40 to 400 15 to 150 2 to 20 0.015 to 9 0.015 to 0.55 0.012 to 0.2 59 No Trip 0.120 max 0.1 max 0.05 max 0.022 max 0.017 max 0.017 max 0.017 max 61 No Trip 0.7 to 12 0.35 to 7 0.13 to 3 0.03 to 1 0.015 to 0.3 0.01 to 0.15 0.008 to 0.1 62 No Trip 10 to 120 6 to 60 2 to 20 0.2 to 3 0.015 to 2 0.015 to 0.8 0.01 to 0.25 63 No Trip 50 to 700 30 to 400 10 to 150 1.5 to 20 0.015 to 10 0.013 to 0.85 0.013 to 0.5 69 No Trip 0.12 max 0.1 max 0.05 max 0.022 max 0.017 max 0.017 max 0.017 max IAR/IUR/IER/CUR/CER Series - Operating Characteristics http://airpax.sensata.com/ Single Pole: RED = 762-600-7651 BLACK = 762-600-7650 Handle lock installed in factory will be mounted from the case side with logo on single pole Barrier (-B) HARDWARE Handle Lock 1.460 [37.08] Retainer (required f single pole 386-000-09 Handle Lock Single Pole: A handle lock option is available to prevent accidental RED = 762-600-7651 actuation of the handle. handle lock may be used in the BLACK = The 762-600-7650 ON or OFF position. Use of the handle lock on breakers with Handle lock installed alarm style auxiliary switches may defeat the alarm feature in factory will be on electrical trip. This option is available separately or mounted from the side with pre-assembled (oncase single polelogo constructions only). 1.715 [43.56] IAR/IUR/IER/CUR/CER [1RU] Handle Lock Retainer (required for single pole only) 386-000-0930 on single pole Bullets Barrier (-B) Socket 1/4-20 UNC-2A Order # 641-480-5032 (silver plated copper) Barrier (-B) 0.725 [18.42] 1.460 [37.08] 0.510 [12.95] 0.251 ± 0.001 Ø [6.38 ± 0.03] 0.375 [9.53] 1.715 [43.56] Retainer (required for Socket 1/4-20 UNC-2A single pole only) Order # 641-480-5032 386-000-0930 (silver plated copper) Handle Lock Single Pole: RED = 762-600-7651 BLACK = 762-600-7650 1.460 [37.08] Handle lock installed in factory will be mounted from the case side with logo on single pole Ø ON on siti Po 0.510 [12.95] 0.251 ± 0.001 1.715 [6.38 ± 0.03] [43.56] 0.375 0.438 [11.13] Socket 1/4-20 UNC-2A Order # 641-480-5030 The handle position indicates the status of the circuit Socket 1/4-20 UNC-2A (silver plated copper) breaker. In addition to #full ON and full OFF positions, there Order 641-480-5032 (silver plated copper) a middle “MID-TRIP” position indicating that the breaker 0.510 [12.95 Socket 1/4-20 UNC-2A Order # 641-480-5022 (silver plated copper) 0.510 [12.95] Socket 1/4-20 UNC-2A Order # 641-480-5030 (silver plated copper) ON 0.438 [11.13] Ø 0.156 [3.96] N n O0.725 o siti 0.510 [12.95 Po [18.42] 0.725 0.510 0.312 ± 0.001 Mid-Trip [18.42] Ø [7.92 ± 0.03]Position[12.95] 0.375 0.251 ± 0.001 [6.38 ± 0.03] Ø [9.52]OF Po F Nut 1/4-20 sUNC-2B itio n Order # 388-899-5010 (silver plated copper) 0.438 Socket 1/4-20 UNC-2A Order # 641-480-5022 [11.13] 0.156 [3.96] (silver plated copper) http://airpax.sensata.com/ is [9.53] n 0.312 itio± 0.001 Ø Pos [7.92 ± 0.03] Mid-Trip Position Nut 1/4-20 UNC-2B Order # 388-899-5010 (silver plated copper) O Po FF siti on Bullets 0.725 O Po FF siti on 0.725 [18.42] 0.438 [11.13] Mid-Trip has electrically tripped from an overload. It is available in [18.42] 0.725 per pole only) series 0.510 single pole and multi-pole (handle [12.95] in constructions. Switch only[18.42] configuration is not available 0.375 mid-trip build. An auxiliary switch be furnished as an 0.251can ± 0.001 Ø Ø [9.52] 0.251 ± 0.001breaker. integral part ofØthe mid-trip The switch provides an [6.38 ± 0.03] [6.38 ±location 0.03] indication at a remote when the circuit breaker has 0.375 electrically tripped and handle is in the mid-trip position. [9.52] Socket 1/4-20 UNC-2A Order # 641-480-5022 (silver plated copper) 0.510 [12.95 [9.53] Mid-Trip0.375 Ø Position 0.251 ± 0.001 [6.38 ± 0.03] 0.725 [18.42] Ø Socket 1/4-20 UNC-2A Order # 641-480-5030 (silver plated copper) 0.725 [18.42] Bullets 0.725 0.510 IAR/IUR/IER/CUR/CER Series - Hardware [18.42] [12.95] 56 HOW TO ORDER The ordering code for these circuit breakers / protectors may be determined by following the steps in the decision tables shown here. The example shown is the code for a UL1077 & TÜV approved circuit protector with series trip, one handle per unit, single pole circuit protector with 10-32 terminal screws standard and a mechanical auxiliary switch. This unit is designed with a slow DC time delay and a rating of 20 amperes with optional metric threads and optional 80VDC capability. Handle color is black with white markings, and is has been met all the selection criteria to obtain the TÜV approval. 1 First Decision First Choice: Type IAR Magnetic circuit protector, one handle per unit IARH Magnetic circuit protector, one handle per pole K 10-32 stud terminal IER UL1077 & TÜV, series trip, one handle per unit B 0.250” bullet terminal IERH UL1077 & TÜV, series trip, one handle per pole IUR UL1077, series trip, one handle per unit IURH UL1077, series trip, one handle per pole IMR UL1077 & TÜV, mid trip, one handle per unit IMRH UL1077 & TÜV, mid trip, one handle per pole CER UL489A & TÜV, series trip, one handle per unit CERH UL489A & TÜV, series trip, one handle per pole CUR UL489A, series trip, one handle per unit CURH UL489A, series trip, one handle per pole CMR UL489A & TÜV, mid trip, one handle per unit CMRH UL489A & TÜV, mid trip, one handle per pole To determine the ordering code for your particular unit, simply follow the steps shown, then fill in the letters and/or numbers in the boxes. Space is available on the circuit breaker label for your part number (up to 12 digits). You may then use your own part number to place an order or as a reference for further questions you may have. This option does require a factory assigned part number for traceability to your drawing or internal part number. 57 Second Choice: Terminal IAR/IUR/IER/CUR/CER Series - Decision Tables 10-32 screw terminal, standard (no entry) The shaded areas denote TÜV approval options. This approval requires the addition of a “T” at the end of the part number (8th decision). The “T” will automatically be added to any part number formed entirely from these shaded decisions. If non-shaded areas are selected, the unit will not be TÜV approved, but other approvals (if applicable) will still apply. IER 1 - 1REC4C - 52 - 20.0 - AD - 01 - T 1 2 2 Second Decision 3 4 5 6 7 8 TÜV Approval Per first decision’s description: The shaded areas denote TÜV approval options. This approval requires the addition of a “T” at the end of the part number (8th decision). 271 Number of Poles 1 11 231 Seventh Decision Handle Color & Markings Single pole -00 Black -01 Black w/ white markings (standard) Two pole -10 Yellow -11 Yellow w/ black markings -20 Red -21 Red w/ white markings -30 Blue -31 Blue w/ white markings -40 Green -41 Green w / white markings -60 Orange -61 Orange w/ black markings -90 White -91 White w/ black markings Third Decision Internal Configuration -1 Series trip -1REC4C Mechanical trip auxiliary switch* -1RS4C Electrical trip auxiliary switch* -1RLS4C Electrical trip auxiliary switch* (mid-trip only) -1REG4C Series trip with auxiliary switch* 0.110 quick-connects (gold contacts) -1REC40 Mechanical trip auxiliary switch** -1RS40 Electrical trip auxiliary switch* -1RLS40 Electrical trip auxiliary switch* (mid-trip only) -1REG40 Series trip with auxiliary switch* 0.110 quick-connects (gold contacts) * Alarms when circuit breaker closes ** Alarms when circuit breaker opens Only one auxiliary switch is normally supplied on two pole units. Switch is located in the right hand pole (viewed from terminal end) unless otherwise specified. 241 Eighth Decision Fourth Decision Frequency & Delay -51 DC short delay -52 DC long delay -53 DC motor start / extra long delay -59 DC 125% instant trip -61 50 - 60 Hz short delay -62 50 - 60 Hz Long Delay -63 50 - 60 Hz motor start / extra long delay (30A max) -69 50 - 60 Hz 125% instant trip http://airpax.sensata.com/ IAR/IUR/IER/CUR/CER [1RU] 8 261 Sixth Decision Optional -A Metric thread mounting (M3) & terminals (M5) -B Barrier (AC only) -C 65 VDC -D 80VDC -E 0.312” diameter bullet (standard is 0.250” when prefix with “B” is chosen in first decision) -F 250VAC -L Handle Lock Notes: 1. One or more descriptions may be used as required (for example, to get a barrier, 250VAC and handle lock, put -BFL) 2. When the sixth decision is not required, the seventh decision may be substituted and U.S. thread will be supplied 5 Fifth Decision Rated Current Use three numbers to print required current value between 2.00 amps minimum and 50.0 amps maximum. IAR/IUR/IER/CUR/CER Series - Decision Tables 58
IAR1-1-52-15.0-AC-00 价格&库存
很抱歉,暂时无法提供与“IAR1-1-52-15.0-AC-00”相匹配的价格&库存,您可以联系我们找货
