TCW400-1213-005
TCW400-1213-005
    SENSATA(森萨塔)
    TCW4 MOD MULTITURN 5-30V SSI NO
TCW400-1213-005 数据手册
| TCW4 SSI SSI MULTI-TURN MODULAR Features •  With its two-part design, the ACW4 absolute single-turn offers maximum flexibility for installation •  Rugged and excellent resistance to shock and vibration •  Robust, proven magnetic technology •  Environmentally resistant, IP 67 standard (IP69K option) •  Extended operating range from -20° C to 85° C •  Uses universal supply 5 to 30 VDC – SSI Output •  Available resolution 12 bits per turn and up to 13 bits of turns counting. •  Variety of magnet holders available Applications •  Factory Automation •  Process Automation SPECIFICATIONS Mechanical Terminations PUR cable with M12 5 pin connector Housing Macromelt PA638 Weight 0,150 kg Electrical Electrical Angle 360° Output Function SSI, 10% to 90% Duty Cycle Minimal Cycle Time 1ms Resolution Resolution 12 bits per turn and up to 13 bits of turns counting Accuracy +/-0.3% on 360° Repeatability +/-0.1% on 360° Supply Voltage 5V to 30 Vdc Start-up < 1s Response time < 10 ms Recommended Load > 10 kOhms Isolation 500 Veff Current Requirements < 40mA Protection Overvoltage Protection: Yes Reverse Polarity Protection: Yes Short Circuit Protection: Yes EMC IEC 61000-4-2 Electrostatic discharge (ESD) 4 kV, 8 kV IEC 61000-4-3 Electromagnetic fields 10 V/m (80MHz - 1GHz), 3V/m (1.4GHz - 2GHz), 1V/m (2GHz - 2.7GHz) IEC 61000-4-4 Electrical fast transients (burst) 1 kV IEC 61000-4-6 Conducted disturbances, induced by RF-fields 10 Veff. Page 1 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com SSI Transmission Transmission Transmission up to 400m* at 100kHz in function of the cable characteristics. Cable High security of transmission by using shielded cable and twisted pairs. * Consult us for length > 100m. Note: Connect DIRECTION and RAZ/RAX to a potential (RAZ at 0V if not used) DIMENSIONS All Dimensions are in millimeters. Shaft system with magnet to be ordered separately (see Accessories). 52 38 0.02 A 11,2
TCW400-1213-005 价格&库存
很抱歉,暂时无法提供与“TCW400-1213-005”相匹配的价格&库存,您可以联系我们找货
