006-1-0100
006-1-0100
    SENSEAIR
    二氧化碳(CO2) 传感器 I²C,UART
006-1-0100 数据手册
Senseair Sunlight CO2 World’s most power efficient CO2 sensor with NDIR technology Compliant with HVAC and building standards, we now launch Senseair Sunlight – the world’s most power efficient NDIR CO2 sensor. Sunlight can be used in a wide range of applications but is optimal for battery and wireless applications or in places where you want to secure a reliable and secure sensor with long lifetime. The module is designed for simple integration into products. The optical solid state design with no moving parts makes this sensor robust and resistant to vibrations. With our automatic baseline correction Sunlight is maintenance-free, which means that you can mount and forget your sensor during its whole lifetime and it will still be accurate. Standard specification Key benefits Article No. 006-1-0100 Measured gas Carbon dioxide (CO2) Operating principle Non-dispersive infrared Measurement range (CO2) 400–5000ppm; extended range up to 10000ppm Accuracy (CO2) ±50ppm ±3% of reading 1, 2 (extended range ±10% of reading) Average current 1–30µA Measurement period Default: 16s, 8 samples (adjustable by host) Peak current < 80mA Power supply 3.05–5.5V 3 Dimensions 34 x 21 x 12mm Weight 5g Life expectancy > 15 years Operating range 0–50 °C, 0–85% RH Storage temperature -40–70 °C • Ultra Low Power consumption • Compliant with ANSI/ ASHRAE Standard 62.1-2022 • Compliant with RESET grad B • Compliant with WELL Building Standard® (WELL v2™) • High Precision • Robust • Mass Production • Self-correcting Serial communication * Note 1: Note 2: Note 3: UART, I2C 15–35 °C, 0–80% RH, after 3 ABC (Automatic Baseline Correction) periods and default measurements settings. Specification is referenced to uncertainty of calibration gas mixtures (±1%). Unprotected against surges and reverse power supply polarity. Document: PSH12929   Rev: 7 ©2023 Senseair AB. All rights reserved.
006-1-0100 价格&库存
很抱歉,暂时无法提供与“006-1-0100”相匹配的价格&库存,您可以联系我们找货
