Datasheet SFM3400-AW
Preliminary Datasheet SFM3400-D
Digital Flow Meter for Neonatal/Pediatric Medical Applications
Flow range: ± 33slm (bidirectional)
Small dead space < 1ml
Re-use (-AW) version
Preliminary single-use (-D) version
Very fast update time (0.5ms)
Product Summary
The SFM3400 sensor series is Sensirion’s digital flow meter
designed for neonatal/pediatric medical applications. It
measures the flow rate of air, oxygen and other nonaggressive gases with superb accuracy. The special design
of the flow channel results in a very small dead space.
The SFM3400-AW is designed for multiple use with the
ability to withstand autoclave procedures. The single-use
version SFM3400-D is in development stage with preliminary
specifications identical to SFM3400-AW. Therefore, the
SFM3400 series is extremely well suited for proximal flow
measurements in neonatal/pediatric medical ventilation and
other respiratory applications.
Applications
The SFM3400 series has been designed with the use by
medical professionals in mind. It features medical cones
for pneumatic connection to standard breathing circuits and
a mechanical interface for easy and reliable electrical
reconnection. The sensor element, signal processing and
digital calibration are on a single microchip assuring very
fast signal processing time, best-in-class accuracy and
superior robustness to rough handling and adverse
conditions.
The well-proven and patented CMOSens® sensor
technology is perfectly suited for high-quality mass
production and is the ideal choice for demanding and costsensitive OEM applications.
Sensor chip
Proximal flow measurement for infants / neonates
Expiratory flow measurement for infants /
neonates
Ventilation & Anesthesia for infants / neonates
Respiratory measurements for infants / neonates
Metabolic Measurements for infants / neonates
The SFM3400 flow meter features a fifth-generation silicon
sensor chip. In addition to a thermal mass flow sensor
element, the chip contains an amplifier, A/D converter,
EEPROM memory, digital signal processing circuitry, and
interface. Due to seamless integration of signal acquisition
and processing on the single silicon die significant
performance and cost benefits are achieved.
OEM options
A variety of custom options can be implemented for highvolume OEM applications (custom flow rates, calibration for
other gases, different body form factor, disposable option
etc.). Contact us for more information.
www.sensirion.com
Version 1.0 – July 2017
1/7
1.1
Physical Specifications
Parameter
Flow Range
Accuracy
Unit
slm 2
-33 … +33
4, 8
Typical
±3 5
± 0.02 5
0.5% 9
0.005 9
Max 3
±10 6
± 0.05
3.5%
0.025
% m.v.7
slm 2
% m.v 7
slm 2
span
offset
span
offset
0.06 9
0.005 9
1%
0.01
0.2
0.01
% m.v./ 10˚C
slm / 10°C
% m.v. 7
slm 2
@ 5 slm
@ 10 slm
@ 25 slm
100 / 0.4 9
250 / 1.0 9
900 / 3.6 9
150 / 0.6
300 / 1.2
1500 / 6.0
Pa / inH2O
Pa / inH2O
Pa / inH2O
span
很抱歉,暂时无法提供与“SFM3400-33-AW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2060.56440
- 30+1944.00000
